Spacer lift question
Discussion in 'Suspension' started by bobk9, Jan 31, 2019.
  1. Jan 31, 2019 at 6:20 PM
    bobk9
    bobk9 [OP] New Member
    Bob
    2013 SR5
    I already purchased the Readylift 3" front / 2" rear spacer kit, I'm going more for the look as a start then maybe later I'll get a real kit.
    1 question I have is the rear shocks, as I'm now learning that I need longer shocks is this true?
    Next, this kit says up to 3" lift in front but the spacer is only about 1 1/2"?
    Then if I'm doing all this work can anyone recommend a front shock that will help with the body roll and dipping when applying the breaks?
    I hope I wont have to replace upper control arms with the spacer kit.
    Seems kinda like I should have looked into an entry level kit if I need shocks and UCA's?
    Thanks!
  2. Feb 1, 2019 at 12:26 PM
    Should get new shocks for the full travel.
    UCA's some people say they needed um some said they didn't. I would of gotten them anyways to be on the safe side.
    Would never recommend spacer lifts personally.
    bobk9[OP] likes this.
