Some minor issues.. please advise
Discussion in '4th Gen 4Runners (2003-2009)' started by Bobbychow305, Dec 1, 2022.
  1. Dec 1, 2022 at 6:12 PM
    Bobbychow305
    Bobbychow305 [OP] New Member
    Hey gang
    Need some input
    1) loud noise like I'm driving on gravel/ vibrations at 35-40 mph then it goes away.
    2) when it starts, noise sounds like buzzing from radio then goes away.
    3) no air on feet but airflow works everywhere
  2. Dec 1, 2022 at 6:17 PM
    1- sounds like you might have a bad needle bearing. This is a known issue with some 4runners. Find a straight stretch of road, and throw it in four-wheel drive at about 30 mph and see if the noise stops. If it does, it is the needle bearing.
    2- sounds like the EVAP pump. Emission stuff. It runs for about 10 or 15 seconds. When you start up, then it shuts off. Then, it also runs for a few seconds after you shut it off.
    3. :notsure:
  3. Dec 1, 2022 at 6:44 PM
    wdsteven
    wdsteven New Member
    2nd this and the Needle bearing is a rather easy fix if you have a lift available even better this is where I have purchased a few from ... https://eastcoastgearsupply.com/i-8536125-toyota-8-clamshell-bushing-eliminates-needle-bearing.html
    Toy4X4 and Thatbassguy[QUOTED] like this.
  4. Dec 1, 2022 at 7:42 PM
    Bobbychow305
    1) I don't 4x4 it's 4x2. Is it expensive to get fix at local mechanic? I'm total noob.
    2) EVA pump, can this be big trouble later?
    3) i guess I don't need to dry my stinky feet!
  5. Dec 1, 2022 at 7:46 PM
    -The needle bearing makes noise in 2wd (mostly). Putting it in 4wd helps diagnose the problem.
    -It's tough to tell if we're talking about the same thing. But, there is a pump that makes noise when you first start, and also after you shut it off. It's not a problem. That's what it's supposed to do.
    Toy4X4 likes this.
  6. Dec 2, 2022 at 3:49 AM
    Bobbychow305
    Got it. I don't 4x4 mode so it must be it. Can it be bad if I don't fix it? I wonder how much it will cost?
  7. Dec 2, 2022 at 5:29 AM
    ToyoTaco25
    ToyoTaco25 New Member
    Chris
    North Carolina
    2017 Blizzard Pearl Limited
    If you have a 2wd only 4Runner, then you don’t have a needle bearing, so that is not your issue.
    wdsteven likes this.
  8. Dec 12, 2022 at 6:35 PM
    Bobbychow305
    Oh! What is issue do you think? Goes away after 40mph
  9. Dec 13, 2022 at 5:33 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Wheels out of balance. Wheel bearing issue. Loose LCA. Failing CV... could be a ton of things. We need more info from you. Whatve you looked at? Pictures? Recent changes?
  10. Dec 18, 2022 at 8:37 AM
    spencermarkd
    spencermarkd New Member
    Spencer
    Pullman, WA
    2007 Driftwood Pearl SR5
    Do you have an aftermarket roof rack or a basket or something? I get a huge harmonic hum off mine at about 35mph. Surprisingly loud.
