So many lights… what to do?
Discussion in '5th Gen 4Runners (2010-2024)' started by Hagglethorn, Feb 26, 2026.
  1. Feb 26, 2026 at 1:37 PM
    Hagglethorn
    Hagglethorn [OP] New Member
    Russellville, AR
    2019 TRD Off-Road Premium
    Bought these when I had my Bronco. I had planned to put 3 pair in the modular bumper and I had ditch light mounts that fit 2 lights each.
    I’ve got the D-Switch from Diode Dynamics to make these all work. Still trying to figure out how to mount it. I heard a company was working on it, but I forget who. What would you do?
    Henry J and djwantke like this.
  2. Feb 26, 2026 at 10:33 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I would not permanently mount any lights that cannot be run thru a car wash. Ditch lights seem the most useful and I think mounted in a way they can be attached and plugged into a power connection under the hood. So permanently mount the light brackets but have the lights removable. Prepping for an outing requires lots of stuff and adding one more things is fine with me.
  3. Feb 27, 2026 at 9:32 AM
    Kezin
    Kezin New Member I guess?
    Washington
    ‘21 and ‘17 Limiteds
    Hagglethorn[OP] likes this.
  4. Feb 27, 2026 at 9:48 AM
    2019 TRDP w/Kangs brah!
    Behind the grill mount for square pods. DD makes a mount.
    djwantke likes this.
  5. Feb 27, 2026 at 10:53 AM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    Put the Pro fogs on the bumper and sell the rest? If you aren't doing high speed offroad, 1 pair plus your normal factory lights is plenty.
    I have a pair of the pod lights in front of my grill, bolted to plastic bumper cover. No special mount needed.
    The C2 Pros do make good ditch lights and the size is right for reverse lights but brightness of Pro is overkill for reverse.
  6. Feb 27, 2026 at 2:23 PM
    Hagglethorn
    Russellville, AR
    Kezin[QUOTED] and ToyotaDude99 like this.
  7. Feb 27, 2026 at 2:30 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    aw yeah do the double ditches lol
  8. Feb 27, 2026 at 2:34 PM
    Hagglethorn
    Russellville, AR
  9. Feb 27, 2026 at 6:40 PM
    Kezin
    Washington
    Yessir. I forgot your second set of SS3s. Lower grille for them IMO. I’d swap lenses too so you can run them on road in the upper and lower grille
  10. Feb 28, 2026 at 9:25 AM
    WRunner
    WRunner New Member
    Jason
    23’ 4Runner
    No Idea.
    For the DSwitch doesn’t it come with a bracket plate to mount it to? Not sure if they make anything for Runners but contact 813 Designs. They may be able to come up with something if you send them some pics and measurements. Top notch small business.
    For the lights go drive a trail at night without them and figure out what you want to see that you can’t see clearly. Then mount them based on that.
  11. Feb 28, 2026 at 10:51 AM
    Hagglethorn
    Russellville, AR
    It probably does. I haven't even opened the box... I was talking about something specific to the 4Runner to mount the switchpad in the cab somewhere. Thanks for the suggestion on 813 Designs!
  12. Feb 28, 2026 at 2:36 PM
    WRunner
    WRunner New Member
    Jason
    23’ 4Runner
    No Idea.
  13. Mar 3, 2026 at 6:09 AM
    Hagglethorn
    Russellville, AR
    Kezin likes this.
  14. Mar 3, 2026 at 1:26 PM
    Kezin
    Washington
    Do you mind taking some pics of the install when it arrives? I mounted my wife’s D switch pad to the left of the steering wheel but the original plan was to mount it up top in that exact spot. As long as it doesn’t destroy the overhead console with the install, I’d rather move it there. I see the instructions say it requires a small notch so just curious how small that notch is
  15. Mar 4, 2026 at 5:11 AM
    Hagglethorn
    Russellville, AR
    I don’t even see where the instructions are. :laugh: But I’ll let you know how it goes.
    Kezin likes this.
  16. Mar 6, 2026 at 11:46 AM
    Kezin
    Washington
    I had some time on my hands. Designed and printed my own version. It’s a solid place to have the pad and much prefer it to the left of the driver’s spotIMG_3775.jpg
