Smart Handle? And Experiment Please.
Discussion in '5th Gen Builds (2010-2024)' started by Rngr188, Nov 4, 2020.
  1. Nov 4, 2020 at 11:27 AM
    Rngr188
    Rngr188 [OP] New Member
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    Ok so I have a 20 Tundra 1794 and a 20 4runner TRD ORP which both have the smart handle. On my Tundra I can lock by grabbing the handle and putting my thumb over the 3 lines but I can't on the 4runner, is that normal? Either way I learned a trick on Tundras.com to open all doors when you grab one handle to get in. Unfortunately our 4runner is in the body shop so could someone try this for me? Have your doors locked and while standing next to the vehicle hold the lock and unlock button on the fob simultaneously for 5 seconds until you hear two beeps. If it does this on the 4runner like it did on my Tundra then all doors should unlock when you grab any smart handle instead of just that door.
  2. Nov 4, 2020 at 11:35 AM
    travelinscout
    travelinscout New Member
    2020 TRD ORP MGM
    On my 20 ORP, I just use 2 fingers on the three little lines on the handle, and all the doors lock. I don't remember if it came this way, or if I programmed it using the remote.
  3. Nov 4, 2020 at 11:58 AM
    Rngr188
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    Does yours only unlock the door that you grab? Mine does and so did my Tundra but I just tried the method mentioned above and now all doors unlock. I was wondering if this works for the 4runner but unfortunately ours is at the body shop so I can't test it.
  4. Nov 4, 2020 at 12:01 PM
    travelinscout
    2020 TRD ORP MGM
    All of my doors lock and unlock this way.
  5. Nov 4, 2020 at 12:04 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    '24 ORP
    What's a 1794 Tundra? Does it come with a triangle hat or something?
    glwood54 likes this.
  6. Nov 4, 2020 at 12:26 PM
    Rngr188
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    So when you're vehicle is locked and you grab your driver's handle all doors unlock? Mine only unlocks the door I grab. My Tundra did the same until I did this "trick".
  7. Nov 4, 2020 at 12:27 PM
    Rngr188
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    1794 and Platinum are the top trim levels for Tundra.
  8. Nov 4, 2020 at 12:47 PM
    travelinscout
    2020 TRD ORP MGM
    Now that I think about it, I did do the trick with the 2 beeps to make all doors unlock and lock.
  9. Dec 2, 2020 at 5:31 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Idk about pre 2020 but in the radio is a setting that you change for all doors to unlock when you grab the handle. If that helps. I’ll try and grab a pic of the screen. Mine lights up when I get near the truck with my fob and then when I grab the handles all 5 doors unlock.
  10. Dec 3, 2020 at 9:40 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    My ‘16 limited can unlock/lock all doors with drivers/passenger door.
    but I can’t open all 4 with the fob with one click. Need to double click.
  11. Dec 4, 2020 at 6:50 AM
    Rngr188
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    Finally got the ride back and did the fob trick now all doors open when I grab one.
