Skid plate hole
Discussion in '5th Gen 4Runners (2010-2024)' started by Tolipnug, Jan 2, 2025.
  1. Jan 2, 2025 at 8:30 PM
    Tolipnug
    Tolipnug [OP] New Member
    Rick
    2024 4runner off road premium
    Anyone just cut a hole in the engine skid plate to access oil filter. I never go off road.
  2. Jan 2, 2025 at 11:05 PM
    No, but I off-road.
    Prepare yourself, you’ll probably get about 20-30 replies stating OE skids are junk and you MUST upgrade to aftermarket skids with a filter access hole to be worthy on this forum. ;)
    Rocko9999, alittleoff, Saker and 2 others like this.
  3. Jan 2, 2025 at 11:31 PM
    It’s easy enough to remove. Just unbolt it.
    icebear and Slopemaster like this.
  4. Jan 3, 2025 at 5:42 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    I've thought about removing my skid plate, cutting the hole, & putting it back on. I might do that this spring.
  5. Jan 3, 2025 at 7:02 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    After you do it a few times it only takes about 3 minutes. Besides, it gives you an opportunity to look at other parts that can't be seen from the top.
    alittleoff and Slopemaster like this.
  6. Jan 3, 2025 at 7:30 AM
    If nothing particularly soft is exposed I’d consider just getting rid of the front plate you’re talking about.
    You’ll still have the oil pan skid too.
  7. Jan 3, 2025 at 8:14 AM
    I wonder if trouble of cutting is worth vs spending 260-300 bucks for an aftermarket skid plate with maintenance removable plate?
  8. Jan 3, 2025 at 8:17 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Idk. Cutting a hole is free.
    I was considering cutting a couple holes in my RCI skid to make transmission and transfer case fluid changes easier :poking:
    The RCI skids make engine oil changes easy. But everything else requires dropping the skids, which is a huge pita.
    kmeeg[QUOTED] likes this.
  9. Jan 3, 2025 at 8:31 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Meh. Every 30K. Averages every 2-3 years for most people. It's a good trade off.
  10. Jan 3, 2025 at 8:55 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I have c4 skids. Has holes. I stopped screwing the cover plate back on for those holes.
    Grandpawmoses likes this.
  11. Jan 3, 2025 at 9:33 AM
    I just bought a $120 eBay knockoff aluminum skid. Still 4 bolts, but lighter and easier to handle. Removing the skid lets me remove the whole cap without fiddling with the snap-in drain spigot. As the saying goes, choose your "hard".
  12. Jan 3, 2025 at 10:24 AM
    1SilverRunner
    Tejas
    That's true for most people. But I change my transmission fluid every time it goes over 250F. Which is every summer in Texas.
    Two simple drain holes would make this a lot easier of a job.
    One day, I'll stop complaining and just cut the damn holes... and add a transmission cooler.
  13. Jan 3, 2025 at 10:46 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    What about greasing drive shafts? Are you only doing that every 30k? That's the main hassle I have needing to drop the skids more frequently.
    3JOH22A likes this.
  14. Jan 3, 2025 at 10:56 AM
    ^Do you remove your skids before each winter to touch up rock scars? Just grease the driveshafts then.
  15. Jan 3, 2025 at 10:59 AM
    2021venture
    Todd
    2021 Venture
    I lube the driveshafts and UCA with a few pumps every oil change. So easy other than my skid remove and replace.
    Yes on the touch up of sliders but my front skids are RCI aluminum so nothing to touch up.
  16. Jan 3, 2025 at 11:22 AM
    Glad we don't use horses anymore for transportation.
  17. Jan 3, 2025 at 11:30 AM
    Tolipnug
    Rick
    Thanks for the replies guys. I'm gonna cut the hole.
    1SilverRunner likes this.
  18. Jan 3, 2025 at 1:43 PM
    Don't be an ass
    icebear, Shredder and 1SilverRunner like this.
  19. Jan 3, 2025 at 2:38 PM
    Startrek
    Startrek New Member
    I think new Sequoia has fiberpaper front skid protection from highway debris only. weight reduction.
  20. Jan 3, 2025 at 3:28 PM
    It’s 4 bolts. I wouldn’t cut a hole. Plus when I drop it I just do a visual inspection.
    alittleoff and glwood54 like this.
  21. Jan 3, 2025 at 5:03 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Nope. Doing it every 5K with oil changes. I have had good success with a needle attachment and whip hose on my grease gun. Granted, the drive shafts need to be perfectly set, but it's totally possible. I have full RCI skids.
  22. Jan 3, 2025 at 9:48 PM
    Having a access hole is tempting, but I would worry about something like a stick jamming up in there. If filter access is a priority without pulling the skid then I would fabricate a cover plate.
  23. Jan 4, 2025 at 6:06 AM
    Grandpawmoses
    David
    2024 4R TRD Pro
    On my 2021 Tacoma, the Toyota service department left that cover plate off after an oil change. I went back and made them find it & the screws but I didn't waste an hour letting them put it back on for me. I never did put it back on either.
    Thacrow[QUOTED] likes this.
  24. Jan 4, 2025 at 7:59 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Skid plate hole. lol
  25. Jan 4, 2025 at 9:14 AM
    Thacrow and Ripper238[QUOTED] like this.
  26. Jan 5, 2025 at 6:29 PM
    You realize next time you off-road, a big branch is going to go straight into that opening and punch a hole clean through the oil pan…right?
    Ok, the chances are pretty low that would ever happen….unless it does
    :boink:
  27. Jan 5, 2025 at 7:54 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Yeah or get caught on a rock and stop my car instantly
  28. Jan 5, 2025 at 11:01 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    McSpazatron likes this.
  29. Jan 6, 2025 at 6:06 PM
    Tolipnug
    Rick
    I decided to remove the front skid for access and left off.engine skid is still on and will stay on. It seems the filter is now easy to change and well tucked up behind the radiator. Shop told me they usually leave them off unless the customers insist they put back on. Most say leave off and has never had a customer have a road trash or rock damage it.
