Skid plate ease of installation?
Discussion in '6th Gen 4Runners (2025+)' started by Axefan88, Apr 15, 2026.
  1. Apr 15, 2026 at 1:35 PM
    Axefan88
    Axefan88 [OP] New Member
    2026 4 Runner XP
    I have a question. What would be a good skid plate to add to my 2026 4Runner XP ?
    And are they easy to install ?
    I just got the vehicle and thought it might be a good thing to add.
    Thanks
  2. Apr 15, 2026 at 4:27 PM
    Brian
  3. Apr 16, 2026 at 7:44 AM
  4. Apr 16, 2026 at 11:50 AM
    If it were me I'd look to see if there's any take-off's for sale near you from someone with a higher trim that swapped theirs out for aftermarket.
    Blufin likes this.
  5. Apr 16, 2026 at 12:57 PM
    Blufin
    Blufin New Member
    Cape Cawd
    26 WCP 4R Platinum & 23 WCP Tundra Capstone
    factory TRD exhaust
    Welcome aboard from MA.
  6. Apr 17, 2026 at 10:34 AM
    Axefan88
    2026 4 Runner XP
    Thank you all for the welcomes and the advice. !
    Very appreciated
  7. Apr 17, 2026 at 11:56 AM
    the term "easy to install" is a loaded question. Yes they are easy to install and line up perfectly to existing holes on the frame. However, they are heavy and awkward to lift. I use a floor jack to get it in place then HAND TIGHTEN for 3-4 threads before finishing with a ratchet. Resist the urge to use an impact. Cross threading bolts is easy to do when installing a skid plate
  8. Apr 17, 2026 at 12:42 PM
    Axefan88
    2026 4 Runner XP
    Ad this skid plate blocks oil filter access ? Just learning as I go here.
  9. Apr 18, 2026 at 12:50 AM
    milsuper
    milsuper New Member
    Yes, the Toyota OEM TRD skid plate in the front blocks oil filter access...very annoying design for this 6G that you gotta deal with every 5K oil change. I'm sure Toyota was trying to give better underbody protection with current TRD skid plate design....if you look at the positive side.
    I suppose I'm spoiled from the previous gen Tacoma and 4Runner (they left you with good access for oil filter directly or by opening a small hatch).
  10. Apr 18, 2026 at 4:50 AM
    Welcome from Wisconsin!
  11. Apr 18, 2026 at 4:53 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    I don't recall the TRD plate having a hatch for oil filter access.
  12. Apr 18, 2026 at 12:30 PM
    What guidelines do you have for your use? Do you need aluminum for weight reduction/limited use or steel for heavy duty off roading.
    Help us help you!
    Toy4X4 likes this.
  13. Apr 18, 2026 at 12:42 PM
    L
    20 Venture/17 Taco
    If you have acess to a lift it would be easy. Else get ready to be on the floor and for a while.
    BS67 and icebear like this.
  14. Apr 18, 2026 at 1:36 PM
    whistle while you work....
  15. Apr 19, 2026 at 7:02 PM
    milsuper
    milsuper New Member
  16. Apr 21, 2026 at 9:44 AM
    milsuper
    milsuper New Member
    The installation/taking off of the TRD Front Skid Plate for 6G is not all that difficult. There are two bolts (A in the diagram) that aid in temporarily "hanging" the plate first. You just have to slide the Skid Plate a bit before you either take off or re-install the skid plate. It's more work though vs. simply opening the access hatch.
    IMPORTANT: Never Over-Tighten the Bolts! Torque only to 27 ft-lb (less than the bolt for your oil change plug)!
  17. Apr 23, 2026 at 7:24 AM
    Rotor-RPM
    Rotor-RPM New Member
    Canada
    2025 SR5
    Timed myself removing and installing both the engine and transmission/tcase skid, using the hanging bolts and driving up on ramps to make room it took me 15 min.
