side window motor is fine but will only go down
Discussion in '2nd Gen 4Runners (1990-1995)' started by altomckee, Aug 11, 2022.
  1. Aug 11, 2022 at 7:01 AM
    altomckee
    altomckee [OP] New Member
    1993 4runner
    I took out the rear driver side window motor and tested it on another windows power and it works find but will only go down when i use the switch. I cleaned the switch and it still persisted and then I switched switches completely with another window and the same thing happened. Is it a wire? any help would be appreciated
  2. Aug 11, 2022 at 7:37 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    Your regulator is more than likely dying. Going down = no resistance. Going up meets all kinds of resistance. Time to replace it. Buy two and do both fronts to save you the headache later.
