Side mirror mud lights
Discussion in '5th Gen 4Runners (2010-2024)' started by mmuy888, Dec 24, 2022.
  1. Dec 24, 2022 at 5:50 AM
    mmuy888
    mmuy888 [OP] New Member
    Classic Silver 2023 TRD Off Road Premium 4runner, TERRA 2024 TRD Pro
    Anyone changed their mud lights in their side mirror to a led bulb? When i tried swapping mine last night i noticed that the led light has a very weak voltage because it is lit up even not activated yet ( still in lock) and when i unlock it it lights up normally. You can not see the weak led light if you place the bulb in the housing only when it is still out. Any advice will be helpful. Tnx
  2. Dec 26, 2022 at 2:06 PM
    mmuy888
    Anyone?
  3. Dec 26, 2022 at 6:08 PM
    ValK83
    ValK83 New Member
    Andrew
    2018 TRD Off Road
    MESO makes custom puddle lights. I haven’t tried changing mine yet.
  4. Dec 26, 2022 at 6:31 PM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    VLeds makes a drop in replacement bulb for the factory unit. Probably not as bright as the Meso pod but I installed them and it’s a definite step up.
  5. Dec 27, 2022 at 3:10 PM
    mmuy888
    First picture. Look at my led they are slightly lit up even i have not activated the unlock button and the key is far away
  6. Dec 27, 2022 at 3:34 PM
    I went Meso. They are really good.
  7. Dec 27, 2022 at 4:37 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I recall that when I installed Philips 168 LED bulbs they also were slightly illuminated when “off”. The line that drives the mirror footlights comes directly from the Main Body ECU. I don’t know what that actual circuit looks like but it seems that it supplies a little bit of current which is just enough to slightly bias the LEDs on. I wouldn’t worry about it.
    I ultimately installed the MESO puddle pods (highly recommended) which do not light up when in the “off” mode. It’s a larger array of diodes which probably requires much more current to light up.
    They sell out fast so if you’re interested get notified by email when they’re back in stock, then order them quickly.
    https://mesocustoms.com/collections...s/4-runner-puddle-pods?variant=29414804717681
    Saker likes this.
  8. Dec 27, 2022 at 5:03 PM
    mmuy888
    Thank you for your info. I was afraid that it will drain my battery, and i tried another brand of led and it was the same result Will sign up for meso
  9. Dec 27, 2022 at 8:01 PM
    Fisch
    Fisch New Member
    Jacksonville, Fl
    2018 TRD ORP
    Empty wallet
    Still waiting for my email from Meso
    j4unner likes this.
  10. Dec 28, 2022 at 7:07 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Please don't hold your breadth. Same boat here. :)
    j4unner likes this.
  11. Dec 30, 2022 at 4:25 AM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    Interesting. I have changed mine, but hadn’t noticed any glow. I’ll have to check it out without my key fob on me.
  12. Dec 30, 2022 at 12:36 PM
    mmuy888
    let me know once you find out. Tnx
