Side marker light bracket broke
Discussion in '3rd Gen 4Runners (1996-2002)' started by Trekker, May 27, 2021.
  1. May 27, 2021 at 12:33 AM
    Trekker
    Trekker [OP] Regular Member
    1997 3rz 5spd
    A few months ago I asked for a part number for the retaining ring that holds the side marker on. Well got around to ordering the part, unfortunately its not the only thing that broke.
    https://imgur.com/a/5acM4vv
    The bracket that holds the retaining ring also broke. Here is a photo of the part that broke, the red line shows the part that also broke. Anyone have a part number for this bracket for the side marker light?
    I'll get a photo of the actual part that broke tomorrow to get a more clear image of what broke
    EDIT May 23: Had to reuploaded image because imgur changed TOS
  2. May 27, 2021 at 1:56 AM
    PorkRunner99
    PorkRunner99 CQ DX !
    Angie
    So Cal - Inland Empire and SGV
    99 4Runner SR5 2WD / 250K mile
    Lifted 2” and new wheels and tires soon
    Try contacting 'Japanese Truck Dismantling' in Wilmington, CA. Talk to them and describe the part or email them a pic. They're super knowledgeable over there. They'll probably have the part you need.
  3. Nov 28, 2021 at 3:02 PM
    Trekker
    1997 3rz 5spd
    Update: I fixed this a long time ago but I'll add what I did learn.
    The part that broke was the plastic housing that holds the lens + reflector in place. Its about 50$ from Toyota, and it'll take around an hour to replace. You have to remove the plastic grill which isn't too hard, and there are a few 10 mm bolts you'll have to undo. The hardest part was getting the stabilizing spring back in place on the new part (you'll know what part I am referring to when you see it). While the plastic grommet I ordered wasn't my issue, it was nice to not reuse the old one.
    The relevant part numbers are:
    81105-35231 Housing sub assembly
    90189-06111 Grommet
