Side Door Molding
Discussion in '5th Gen 4Runners (2010-2024)' started by KineticSunset, Feb 28, 2026.
  1. Feb 28, 2026 at 7:43 PM
    KineticSunset
    KineticSunset [OP] New Member
    2023 TRD Pro
    Nothing worse than coming out to see the clown that parked next to you was too weak to stop their door from hitting your baby… :mad:
    How do you feel about adding side door moldings on your 4Runner?
    Who has done it and how do you like them?
    Did you get aftermarket or go to Toyota for OEMs?
    Thanks everyone!
  2. Feb 28, 2026 at 9:54 PM
    I prefer sliders, which work to prevent most door dings, just not full-size pickup trucks. I try not to get near those.
    Toy4X4, TrueTexas, Henry J and 2 others like this.
  3. Feb 28, 2026 at 11:49 PM
    4runningMan
    4runningMan New Member
    New Mexico
    The problem is there are infinity hights, sizes, and shapes of vehicle doors. As well as the angles and distances at which vehicles park next to you. The odds of a door hitting directly on the protective molding strip are probably slim.
    You apply the molding and odds are you're gonna get a door ding right above or below it.
    KineticSunset[OP] likes this.
  4. Mar 1, 2026 at 5:05 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    I don’t think there is a factory OEM protective body side molding kit option for 4Runners, is there?
    I’ve never noticed body side moldings on a fifth gen 4Runner. If there is such a thing, please enlighten. I mean, there’s always after-market choices, but I’m just not aware of OEM for 4Runners.
    When we bought our pre-owned / certified 2023 RAV4 XLE Premium Hybrid AWD, it did not have body side moldings on it. I ordered the OEM kit from our Toyota dealer parts dept. and installed these on the wife’s car.
    I agree they may not stop all door dings, but, better than doing nothing I guess. So far, no door dings on the RAV4. We both try to park selectively, but ultimately, there’s frequently some inconsiderate / uncaring asshole to worry about when you return to your vehicle.
    A few weeks ago I came back out to my T4R in the HEB grocery store parking lot and there was a grocery cart touching up against the rear vinyl wheel well molding above the left rear tire on my vehicle. No damage
    The cart corral was like 25’ away. Lazy sons a bitches. Yes, I wheeled that cart and mine over in to the corral.
  5. Mar 1, 2026 at 8:42 AM
    FlyinV
    FlyinV 2018 4Runner Limited
    West Coast
    My 4Runner was missing some door edge trim on the passenger side.
    First I ordered factory door edge guards -- Nope not it -- Very different from the drivers side trim.
    The old owners must have done something aftermarket. (but I suspect the dealer did it as an add on)
    I finally found the trim they used here:
    Colored Door Edge Guard L Shape Molding 12 foot Kit With 3M Tape – TrueLine Automotive
    Very happy with it and it matches the color 100% - Easy to install and secure. While it won't stop a person from hitting my door it does protect the edge of the door from hitting something.
  6. Mar 1, 2026 at 2:09 PM
    KineticSunset
    2023 TRD Pro
    @Rick G. - not sure. Nice job on your RAV4, looks great!
  7. Mar 1, 2026 at 2:11 PM
    KineticSunset
    2023 TRD Pro
  8. Mar 1, 2026 at 2:37 PM
    Any number of aftermarket providers, check out the 5th gen Armor section.
  9. Mar 1, 2026 at 3:23 PM
    I just park away from the masses.
  10. Mar 1, 2026 at 6:18 PM
    KineticSunset
    2023 TRD Pro
    @glwood54 - I think I may like those better than the drop steps I currently have.
  11. Mar 4, 2026 at 11:05 AM
    golfpilot
    golfpilot New Member
    David
    Switzerland
    2019 TRD Off Road Premium
    Mine already has these door protectors (plastic strips). Unfortunately, I can't say where they're from or who makes them. I only noticed them when someone mentioned them here in the forum. In terms of shape and paintwork i would say OEM. But so far, I haven't found any pictures from other 4R's with these moldings.
  12. Mar 4, 2026 at 11:37 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    :spending:
  13. Mar 4, 2026 at 11:38 AM
    ToyotaDude99
    ToyotaDude99 Obsessed with 4Runners... And anything Toyota
    Sliders are the little metal prongs with rubber boots on the ends that control the climate control settings in a 2nd gen 4Runner. All later gens used knobs. I love my sliders. :D
    Just kidding (sorta!) on that one. Sliders protect your vehicle when off roading. Say like if you went over a big rock, the slider would hit and scrape the rock instead of your vehicle getting scraped
  14. Mar 4, 2026 at 1:19 PM
    If some clueless RAV4 passenger (there are several million of them) opens their rear door with the wheel arch cutout, no molding is high enough to stop a door ding:
    You can wrap your whole vehicle in PPF (~$6k every five years) or coat your vehicle in Line-X Ultra:
    117406871_2750615615191723_2231637148317_b1354cf4e7141ccc5633f0691b0e18ad1ae06130.jpg
  15. Mar 4, 2026 at 3:20 PM
    hossler1788
    hossler1788 DADWAGON
    Joshua
    Central Pa
    2020 4runner
    Ive said it before, you have a great looking 4runner
    ToyotaDude99 likes this.
  16. Mar 5, 2026 at 5:57 AM
    Looks like these: https://www.dawn-ent.com/FE2-4RUN-Toyota-4Runner-Painted-Body-Side-Molding
  17. Mar 5, 2026 at 9:40 AM
    KineticSunset
    2023 TRD Pro
    @3JOH22A - these look like they could work… thanks for the link!
  18. Mar 5, 2026 at 9:40 AM
    KineticSunset
    2023 TRD Pro
  19. Mar 5, 2026 at 11:09 AM
    They provide very little coverage, but if you want to spend money, this forum is very good at advising you where to spend it!
  20. Mar 5, 2026 at 11:27 AM
    water
    water New Member
    brian
    Portland, OR
    2019 4runner
    Yes
    This should work:
    I am sure it is OEM :)
  21. Mar 5, 2026 at 1:31 PM
    KineticSunset
    2023 TRD Pro
    @water - that’s a friggin riot!!! Love that :muscleflexing:
  22. Mar 6, 2026 at 10:45 AM
    golfpilot
    David
    Switzerland
    That's also a solution, just build higher than everyone else an no one will hammer a door into your side :D;)
  23. Mar 7, 2026 at 6:11 AM
    Curlystooge
    Curlystooge Member
    Flyover
    2022 limited in magnetic grey
