Show us your mounted antennas!
Discussion in '5th Gen 4Runners (2010-2024)' started by Thacrow, Jan 29, 2024.
  1. Jan 29, 2024 at 8:58 PM
    Thacrow
    Thacrow [OP] New Member
    2021 ORP
    Speed holes
    I want a temp antenna for off road camping with buddies. We do hand helds now and maybe that's good enough but I wanna get the antenna outside for a little better range / reception.
    Seems like a bull bar mount would be best to get the antenna away from the the vehicle. Of course roof would be best but branches and what knot.
    What has everyone done? We'd love to see it!
    I would thinking about making a bracket that would clamp to where D-rings go on my bumper to avoid a bull bar clamp maybe scratching the bar. This would be temporary and only used when camping. Would love input and suggestions.
    djwantke likes this.
  2. Jan 30, 2024 at 6:18 AM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP, 2019 Audi RS5
    Magnuson Supercharger etc.
    Unless you put the antenna up top at the highest point you will not gain much if anything over the handheld. I would use one of those short ones with magnetic mount and just stick it on the roof.
    Ripper238 and BearBio like this.
  3. Jan 30, 2024 at 8:01 AM
    Nothing fancy. Just MXT 275 with stock antenna and Midland T71 inside the house.
    djwantke and Ripper238 like this.
  4. Jan 30, 2024 at 9:37 AM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
  5. Jan 30, 2024 at 9:44 AM
    Hi BearBio, does this antenna require a serious ground? If I use 3M tape on my spoiler like I used my GMRS antenna it would be bad? I have met with some Jeep folks in the past who use CBs. Like to add a cheap CB and maybe pay a little for tuning? Last time I met with a CB tuner he was very suborn and wanted a huge antenna.
  6. Jan 30, 2024 at 10:46 AM
    Thacrow
    2021 ORP
    Speed holes
    I went ahead and got a MXT275 and maybe I'm over thinking it. For Temporary use I should do exactly what you're doing. I was a little worried about having pelican cases in my room rack in front of the antenna.
    How is the 275? I was messing around with it in my house and it seems LOUD on the lowest volume. REALLY loud.
  7. Jan 30, 2024 at 11:11 AM
    True lowest volume is little loud especially listening to weather. you can disable main unit speaker if needed so you only hear from the handheld.
    I like the 275. A nice balance in power. Its strong yet I can power it from a wire tap behind the cigarette lighter. (The more powerful ones you need a dedicated wire to the battery.)
    Thacrow[QUOTED][OP] likes this.
  8. Jan 30, 2024 at 11:56 AM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Not really=it's a glorified hand-held. Plugs into the "lighter" port or can use batteries. hook up to antenna and stick it on the roof. I like the mobility in case of emergency and no cell coverage!
    kmeeg[QUOTED] likes this.
  9. Jan 30, 2024 at 12:05 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I have my Midland mounted here:
    And the magnetic mount with ghost antenna or 6db whip depending on my off roading on the roof. Up high is key!
    djwantke, Thacrow[OP] and BearBio like this.
  10. Jan 30, 2024 at 3:40 PM
    grizzlypath
    grizzlypath New Member
    2020 ORP-KDSS
    I have the same set-up as kmeeg, but I have mine magnet mounted to my ditch light bracket which works alright.
  11. Feb 7, 2024 at 6:48 PM
    DRH
    DRH TRD Broverlander Extraordinaire
    Dave
    Santa Clarita, Ca
    2020 ORP
    I put my antenna on the gobi rack and mounted the radio in the center console just in front of the add on tray. An easy install, just needed one more KC wire hider and a single hole drilled in the front of the console.
    The handset is stored in a stuff sack in the console when the radio is not needed.
  12. Feb 7, 2024 at 6:57 PM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    2 radios and antennas for chasing races in Baja. I bought these for the base:
    Anina 3/4 Inch Hole Mount NMO L... https://www.amazon.com/dp/B0CFFC2CBR?ref=ppx_pop_mob_ap_share
    and
    PCI antennas:
    https://www.pciraceradios.com/products/no-ground-plane-antenna?variant=1194047116&currency=USD&gclid=CjwKCAiA8YyuBhBSEiwA5R3-E-JSxxE4ODfDQRQ-BTW66ETeKQp52X7nDxOOHjzAqapK-QvmkZNVTxoCgP8QAvD_BwE
    I just got them wired up and had problems last week programming the radios. Heading down to San Felipe next month. Hopefully everything is dialed in by then.
    One of my radios is a Yaesu FT2980R and the other is a Icom IC-2730A. I ran one cable out the passenger boot (not the provided hole, the actual rubber boot) and the other out the driver side taillight.
  13. Mar 7, 2025 at 7:58 PM
    live4swell
    live4swell New Member
    2020 Nautical Blue 4Runner TRD OffRoad
    i mounted my antenna in the same exact spot, do you find that the wire gets pinched a little when opening and closing the hatch?
    also, did you run the wire over the weatherstripping and in or under it? I ran it under but it seems to bulge a bit in the spot where the wire crosses over to get inside
  14. Mar 7, 2025 at 8:35 PM
    live4swell likes this.
  15. Mar 8, 2025 at 7:34 AM
    Ripper238
    2019 TRD OR
    Mine doesn't really get pinched since its a thin cable, but i did use a split wire loom cover my Comet mount that also is thin and it pinches that a bit. I did it over the weatherstripping since i was not happy with running it underneath and loosing the seal. Though i did run under the weatherstripping for my ditch lights (cut into metal to help fit), and it did effect the seal under the weather striping bad, only a slight pinch on the outside, totally fine.
    GMRS backup
    Ditch lights, only a slight pinch even though its a thicker wire.
    2M 70CM
    Comet mount with thinner end wire:
    My other GMRS antenna:
  16. Mar 8, 2025 at 7:49 AM
    live4swell
    Thanks for all the info!
    this is where I put it but I may readjust how and where it enters the rear cargo area.
    https://ibb.co/7t12BpT9
  17. Mar 8, 2025 at 8:03 AM
    Ripper238
    2019 TRD OR
    That's really fine, center of the front part of the roof is best. But that will come when you decide to upgrade your antenna for big gains.
  18. Mar 8, 2025 at 8:07 AM
    live4swell
    Thank you. I will leave it for now.
    Do you think I should be concerned with this section of weatherstripping where the wire enters? I covered in RTV just in case. I went a little heavy on the RTV just to make sure lol
    https://ibb.co/KBJ5CY3
    https://ibb.co/V0mPFZ95
  19. Mar 8, 2025 at 8:32 AM
    Ripper238
    2019 TRD OR
    That should be fine, i did similar. Just check it every year.
    Eventually i was getting some leaking after ~2 years, but i just taped the entire top of the weatherstripping and no issues now. Going to redo this spring.
    live4swell[QUOTED] likes this.
  20. Mar 8, 2025 at 10:02 AM
    Just took some pics. Now I have the ghost antenna. The wire is way more thicker than the stock antenna. Not my taste. So far the wire does not seem to have any pinching but have scratches with hatch open and close.
    Will do a detail video when time permits.
    Top view -hatch closed
    Rear view - Hatch closed - Already showing signs of sun burn
    Top view - How antenna is mounted to roof rack -
    (Due to high crime rate here in Denver I mount the antenna inside on roof rack so it's less visible and hopefully thieves won't be tempted to steal.)
    Top view - Hatch fully closed
    Inside view - Hatch half way closed - Can see some scratches on the wire
    Bottom view where the wire go inside the car - Can see some scratches but no pinching on the wire but rubber weather strip is pinched.
    live4swell[QUOTED] and Ripper238 like this.
  21. Mar 8, 2025 at 11:40 AM
    live4swell
    Thanks guys, appreciate the help!
  22. Mar 8, 2025 at 11:59 AM
    Thacrow
    2021 ORP
    Speed holes
    I ended up getting myself and my buddies matching MXT 275's and we just close our rear doors on the cord and magnet to our roof or roof racks.
    I was overthinking this and just looking for more projects.
    One of my buddies is in law enforcement. Says he likes the 275 more than the radio in his squad car. Not a bad endorsement.
    Photon_Chaser and live4swell like this.
  23. Mar 9, 2025 at 5:53 PM
    scottiezilla
    scottiezilla New Member
    I just installed my radio today
    Now with anyone familiar with midlands or possibly any NMO?…my ?s
    I was gifted ditch light brackets by a forum member when I bought something else from him, n the intention was always to use them for antenna…I’m going to sand powder coat off
    (Stock img)
    Essentially the tall, skinnie threaded part fits PERFECTLY through ditch light hole n then on top of ditch light(sandwiching it) I thread the fat threaded part? So do I have that oriented correctly
    second
    Do I need to utilize these parts?
    Spacer kinda plastic thing n then the metal tooth clamp?IMG_6243.jpg i turned on the radio, even without the sanded bracket, n reception was clear but i just wanna make sure i have it in the right order per say or if need to put the spacer on, meaning i drill the bracket hole a lil bigger or what?
    Thacrow[OP] likes this.
  24. Mar 9, 2025 at 7:08 PM
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    Wilson 5000 magnetic to a cobra 29 ltd CB tuned by CB shop to max legal 4W power. Orientation to passenger side rear puts antenna pattern to forward slightly left into oncoming traffic. SWR 1.1 to 1
  25. Mar 9, 2025 at 8:06 PM
    West Coast
    I’ll be installing the Ghost Antenna for my MXT275 high up on the roof rack (protected by the cargo boxes.)
  26. Mar 9, 2025 at 9:13 PM
    Thacrow
    2021 ORP
    Speed holes
    You shoukd post this on reddit /r amateurradio should get a very quick and accurate answer
  27. Mar 9, 2025 at 11:05 PM
    scottiezilla
    Yeah…N IM FRICKIN TERRIFIED OF THE MATRIX RADIO JARGIN ANSWER I’LL GET!!!
    haha I’m still learning allllll the terminology; however, I feel like someone’s gonna say “dude, it’s a plastic spacer…toss it you schmuck”
    side note:
    I’d have to start a new thread on here just to find out how to post on Reddit…
    2 side note: please someone step up n not let that happen lol
  28. Mar 9, 2025 at 11:11 PM
    Thacrow
    2021 ORP
    Speed holes
    You're hilarious. That black thing makes me think that it insulates the antena from the car. But I don't know. The nerds in the subreddit will set you straight real quick. They'd be thrilled to help.
    scottiezilla[QUOTED] likes this.
  29. Mar 10, 2025 at 7:11 AM
    Ripper238
    2019 TRD OR
    Shouldn't need to drill the bracket hole out more if it slides through. Picture of it finished?
    Should be like this:
  30. Mar 10, 2025 at 7:48 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I have the Midland ghost antenna mounted next to my ditch lights.
    My radio nerd friend told me it won't work there... Then it out performed his MXTA26 which is mounted correctly... So we agreed it worked just fine.
    Sad hams are funny.
