Shifting out of 4wd
Discussion in '3rd Gen 4Runners (1996-2002)' started by Silliw98, Jan 2, 2022.
  1. Jan 2, 2022 at 10:13 PM
    Silliw98
    Silliw98 [OP] New Member
    Willis
    98 white 4runner 4WD
    Im getting a boom clunk shifting out of 4wd?
  2. Jan 2, 2022 at 10:20 PM
    Northern 4runner
    Northern 4runner New Member
    2020 tundra trd sport premium, 2005 Tacoma trd off road, 2022 Tacoma on order
    Ko2’s and bilsteins/OME
    My 2005 will make a little “boom” if under load when shifting out. If I do it while coasting a little or even in reverse it doesn’t do it. One of the things I live with given it’s 17 years old, yours is 24 years old, be easy on the old girl.
  3. Jan 3, 2022 at 6:10 AM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    You shouldn't.
    All joints, bushings, etc good underneath?
  4. Jan 3, 2022 at 7:06 AM
    Northern 4runner
    if there’s tension on the driveline you’ll get a little sound, guess it depends on what he’s describing
  5. Jan 4, 2022 at 1:07 AM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    I have a 97, you shouldn't get a boom clunk at all. Diff fluid been changed recently?
  6. Jan 4, 2022 at 6:33 PM
    still
    still New Member
    1997 4runner Limited
    My 97 limited did the same thing. I just started shifting into neutral before disengaging 4wd...
  7. Jan 4, 2022 at 6:37 PM
    Doubleduty
    3rd gen ltd and 5th gen SR5
    Has always happened with me and no worse for the wear. This includes my 1st gen, my 3rd gen and my 5th gen. I would not worry about it!
  8. Jan 4, 2022 at 6:40 PM
    Xero
    Xero New Member
    22 Toyota 4Runner Trail, 18 Tacoma TRD OR
    Both my Tacoma and 4R have a mechanical sounds when going in and out of 4x4.
    I wouldn’t say a boom but mechanical clicks and a clunk.
    Doubleduty likes this.
  9. Jan 4, 2022 at 6:45 PM
    Doubleduty
    Exactly...it only makes sense that there would be a transition noise. No problem!
    Get over it. All three of my Runners have always made a noise when shifting from 2wd to 4wd and the reverse.
    Xero[QUOTED] likes this.
  10. Jan 5, 2022 at 7:20 AM
    Northern 4runner
    If you take the tension off the driveline it’ll be much smoother. I do it on my 2005 as it has 300k on it and I don’t need anything adding more stress on it than necessary. The smoothest shift out of 4wd happens when slowly rolling in reverse, comes out smooth like butter!
