Shifter upgrade
Discussion in '5th Gen 4Runners (2010-2024)' started by BASE0608, Mar 19, 2024.
  1. Mar 19, 2024 at 5:15 PM
    BASE0608
    BASE0608 [OP] New Member
    2024 TRD ORP KDSS
    I thought I'd share my shifter upgrade. I replaced the poor quality boot for the transfer case shifter with a nice red stitched one from Amazon. For some reason, the OEM t-case boot reminds me of foam packing sheets. After I replaced that boot, I decided to order another one and add a boot to the trans shifter as well. I replaced the silver knob with a black one. I am happy with the way it turned out. Now I need to order the black t-case knob to complete the look.
    If anyone is interested, this is the boot that I used. I just removed the silver piece.
    sloatek, T in Texas, MeefZah and 4 others like this.
  2. Mar 19, 2024 at 11:08 PM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Looks good! How did you tuck it all in the shift gate?
    BASE0608[OP] and ualfltdispatch like this.
  3. Mar 20, 2024 at 5:41 AM
    ualfltdispatch
    ualfltdispatch New Member
    2023 TRD Off Road Premium
    When you have $160 burning a hole in your pocket, upgrade again. Proper tank-like match.
    https://www.ellisprecision.ca/produ...4runner-shift-knob-set-automatic-transmission
  4. Mar 20, 2024 at 3:24 PM
    BASE0608
    2024 TRD ORP KDSS
    Thanks. I personally think it makes the interior look a little more modern. I removed the console top cover, folded one side of the boot, and then used a strip of 3M double-sided tape to stick it next to the PRND letters. The top, bottom, and right side are secured with 3M tape as well, but they are attached to the shifter bezel under the console cover. Once the cover was snapped back into place, the boot is nice and tight. The T-case boot was super easy. The old boot was secured to a plastic frame with staples. I removed the staples and then attached the new boot and snapped the frame back into place on the bottom side of the console cover.
  5. Mar 20, 2024 at 3:31 PM
    BASE0608
    2024 TRD ORP KDSS
    I like that combo, but I couldn't justify spending that much on shifters at the moment. I just got a cheap OEM-style one for now. Since I'm getting a level (Bilsteins), wheels, and tires next month, I figured I should limit my spending on upgrades at the moment. The wife already doesn't understand why I need to spend money for upgrades on a brand new vehicle. :D
  6. Mar 22, 2024 at 4:34 AM
    spyder918
    2019 TRD ORP MGM
    When you say remove the console top cover, do you mean the entire center console or just the area around the shifter?
  7. Mar 22, 2024 at 8:08 AM
    steelevo
    Utah
    Looks good
    BASE0608[OP] likes this.
  8. Mar 22, 2024 at 4:19 PM
    BASE0608
    2024 TRD ORP KDSS
    The entire console top piece. The bezel around the shifter (the part with PRND) is what I double-sided tapped the boot to. Since the shifter bezel sits under the main console piece, the boot stays tucked in very well. I had a co-worker tell me today that they would have never known it didn't come that way from the factory. If you don't care about leaving the gear indicator letters exposed, you could tuck the boot in at all 4 sides around the bezel. But I think the way I did it works very well too.
    *I'd be happy to pop the console off and take pictures of the underside around the shifter if you would like.
  9. Mar 22, 2024 at 10:15 PM
    spyder918
    2019 TRD ORP MGM
    Ok I think I got it..thanks!
    BASE0608[QUOTED][OP] likes this.
  10. Jun 13, 2024 at 6:42 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    I would appreciate that pic, if you're still in the mood to do it...
    how did you get the transfer shift knob off? my shifter just twists right off, but transfer case knob seems locked in place.
    how did you attach the new transfer case boot? I was thinking of using safety wire in same places as the staples were
  11. Jun 13, 2024 at 6:57 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    The transfer case knob unscrews with a fair amount of resistance, but you don't need ape-like strength.
  12. Jun 13, 2024 at 7:06 PM
    T in Texas
    FEMA Region 6
    thank you, do I need to remove the cap on top first?
    I got a new knob, but would hate to break the new factory one...
  13. Jun 13, 2024 at 7:18 PM
    backpacker
    2023 TRD ORP
    You don't need to remove the cap if you're unscrewing, but take care not to go too far when screwing back on.
    T in Texas[QUOTED] likes this.
  14. Jun 14, 2024 at 4:14 PM
    BASE0608
    2024 TRD ORP KDSS
    Hey man. I have added a few more pics. I just removed the staples and the old T lever boot from the frame and then just wedged the new boot between the frame and the console top. It clips back in and holds the boot in place. It has worked very well.
    roooo, pebips and T in Texas[QUOTED] like this.
  15. Jun 14, 2024 at 6:00 PM
    T in Texas
    FEMA Region 6
    thank you for the pics,
    I like that shifter boot added to the transmission
    I bought one to change out my transfer case shifter, but never thought about adding one for the trans...
    Im having katzkin seats made now, in grey leather with red stitching...
    I got a grey shift boot with red baseball stitching, and had grey leather knobs, also with red baseball stitching made...
    hope to fit this weekend, and gonna check to see how the transfer boot I got will fit over the transmission lever
    I got mine here
    https://www.redlinegoods.com/4runne...ift/2010-24-Toyota-4runner-transfer-case-boot
  16. Jun 15, 2024 at 8:38 AM
    T in Texas
    FEMA Region 6
    here is what Im installing, hopefully this weekend...
    pebips and Netloop like this.
  17. Jun 15, 2024 at 9:20 AM
    JChiz
    JChiz Old Member
    South Of Tucson, AZ
    Nice upgrade and information.
  18. Jun 18, 2024 at 11:07 AM
    T in Texas
    FEMA Region 6
    Well, I got my transfer case shifter upgraded...
    still thinking about a matching boot for the transmission...
    I got the leather boot made here,
    I found redline on another thread, but OP rage deleted it all so posting on this shifter upgrade thread rather than a new one
    One can chose color of leather, or more than one color, color and style of stitching..
    One color and regular stitching is $49
    I got light grey with red baseball stitching and it was $75 for the boot
    I found a guy on Etsy in Lithuania to make the dove grey shift knobs with red baseball stitches...
    I'm getting Katzkin leather seats, black bases, with dove grey faces with red stitching and TRD PRO in red on all four backrests...
    The dove grey matches the headliner very well...
    I think the interior will tie together nicely...and be unique
    before and after...
    roooo and pebips like this.
  19. Jun 18, 2024 at 11:47 AM
    LetsTacoboutit
    Adobe
    For some reason I hear “Wild Thing” playing in Major League. Looks like a couple of baseballs.
  20. Jun 18, 2024 at 12:22 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    I did something similar as well but did not like how it looked with my FJ Cruiser knob so I removed it.
  21. May 29, 2025 at 8:20 PM
    tpotnoc
    tpotnoc New Member
    Unmolested ORP
    Looks good. How did you get the boot to stay up around the shiftknob? The 4Runner knobs don't have little clips to hold up the boot, and you removed the silver ring. So how does it stay up nice and tight on the knob?
  22. May 29, 2025 at 8:21 PM
    tpotnoc
    tpotnoc New Member
    Unmolested ORP
    Same question as above--How does the boot stay up high and tight on the knob without little clips holding it?
  23. May 29, 2025 at 8:51 PM
    tpotnoc likes this.
  24. May 30, 2025 at 11:19 AM
    Emmantik
    Emmantik New Member
    I can't remember exactly but I'm pretty sure I used a small cable tie. The shaft of the FJ Cruiser shift knob is removable.
