shifter rattles
Discussion in '5th Gen 4Runners (2010-2024)' started by nick604, Nov 29, 2021.
  1. Nov 29, 2021 at 10:59 AM
    nick604
    nick604 [OP] New Member
    my shifter rattles in my 18 limited unless I put my hand on it while accelerating. any ideas?
  2. Nov 29, 2021 at 5:26 PM
    Sandbuster
    Sandbuster Breaking Wind
    Central Florida
    2019 TRD Offroad
    No such issue with my trans shifter but I do notice that my 4wd shifter has a high frequency vibration all the time but only notice it if my sunglasses end up next to it..
  3. Nov 29, 2021 at 5:35 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Rattles or moves around?
  4. Nov 30, 2021 at 3:10 AM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    The t-case shifter is mounted directly to the t-case. So engine torque/vibes etc will automatically be transmitted to the shifter. The tranny shifter is not, there's got to be something loose in your gearshift assembly IMHO
  5. Nov 30, 2021 at 3:23 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Doesn't the limited only have the lame dial for low range? Or can you get it with a lever also.
    Slopemaster likes this.
  6. Dec 2, 2021 at 11:08 AM
    Yes, I thought the 4wd lever comes only on the Off Road and Pro trims, and everything else got the dial selector that controls an electro-mechanical actuator on the t-case.
    Regarding OP’s post, if your transmission gear selector is rattling, that is weird. I think there are only cables between it and the transmission, so vibes shouldnt be transmitted to the lever. You might have some foreign object in the shifter, so you might need to take off the center console to look.
    If there are vibes coming to the cabin in general causing rattles, might not be a bad idea to take a look at the engine, trans, t-case mounts.
    OverRunner likes this.
