Seat cushion wrinkles
Discussion in '5th Gen 4Runners (2010-2024)' started by Steve40th, Apr 10, 2024.
  1. Apr 10, 2024 at 10:39 AM
    Steve40th
    Steve40th [OP] New Member
    sTEVE
    I have seen a few seats like this. Is there a fix?
  2. Apr 10, 2024 at 4:53 PM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    Remove the cover and add more foam. Maybe replace the cover too
    djwantke likes this.
  3. Apr 10, 2024 at 5:51 PM
    Startrek
    Startrek New Member
    all used cars have same seat damage. when driver gets into car, he seat first on an edge, then move butt in a middle of seat, or driver leaning left elbow on door support, therefore shifting body weight to the edge. or some people just heavy and have wide butt. Toyota sells seat cover only.
  4. Apr 10, 2024 at 6:24 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Leather? How many miles on the vehicle?
  5. Apr 10, 2024 at 6:30 PM
    Steve40th
    sTEVE
    70000 miles.
  6. Apr 10, 2024 at 6:30 PM
    Steve40th
    sTEVE
    Just pull it up and stuff it?
  7. Apr 10, 2024 at 7:06 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Weight loss?
    Rocko9999 and Noodles like this.
  8. Apr 10, 2024 at 7:10 PM
    Steve40th
    sTEVE
    Sure, thnx
  9. Apr 10, 2024 at 7:14 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey OP
    Good suggestions
    Looks like the leather is flaking where it's creased too?
    My seat will need this eventually especially cuz of my wife, so I'm interested
    some people do have wide butts don't they
  10. Apr 10, 2024 at 7:24 PM
    Steve40th
    sTEVE
    I know the Limited isnt raised, but I need to lift up to get over the edge of the seat, otherwise, I do drag my butt across it. That is a big problem.
    I do have steps to get in and a grab handle to assist, but, it is too late, as it is flaking too.
    I saw how to take this apart, its a time consuming job to do..
  11. Apr 10, 2024 at 7:28 PM
    This guy does....
  12. Apr 10, 2024 at 7:32 PM
    Steve40th
    sTEVE
    I am 5'10" 210. Not too fat, but it is what it is. I think the girl who owned it before me was a chubby chick. A lot of candy was found after the fact in the carpet under the seat, drivers seat.. Its a clue, not absolute.
    3JOH22A likes this.
  13. Apr 10, 2024 at 7:41 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    I wasn't saying it was you. Possibly the PO?
    Steve40th[QUOTED][OP] likes this.
  14. Apr 10, 2024 at 7:44 PM
    Pretty much every used 4Runner you come across is going to be like this. You can hide it with a form-fitting seat cover, like Wet Okole.
  15. Apr 11, 2024 at 3:30 AM
    Steve40th
    sTEVE
    I will look into that. Shouldnt have to, but it seems to be the way to go..
  16. Apr 11, 2024 at 4:02 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    My 18 Limited is no different. I plan on driving it until it won’t drive anymore. While it bothers me a little it doesn’t bother me enough to throw money at it yet.
  17. Apr 11, 2024 at 4:54 AM
    Kezin
    You’ll have to remove and dismantle the seat to be able to remove the leather “skin” and then get some seat foam and cut/sculpt it to fill that area again. A vehicle upholstery shop could do it for you as well
  18. Apr 11, 2024 at 5:31 AM
    Steve40th
    sTEVE
    I watched a video. Looks like a lot of work. Or take the plastic off and see if I can squeeze foam in there.
    Or, put a patch on it. With something cool written. Or just seat cover
  19. Apr 11, 2024 at 5:40 AM
    Kezin
    It is quite a bit of work but not super difficult. Up to you as the owner if it’s worth it. I would let the leather wear out a bit more and replace the skin at the same time. Katzkin or Leatherseats can sell you replacements
  20. Apr 11, 2024 at 7:22 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    But, 5'10" and 210# is going to be a lot wider than 6'3" and 210#. So, in theory it's going to put a lot more stress on the bolsters.
    Noodles likes this.
  21. Apr 11, 2024 at 8:14 AM
    Steve40th
    sTEVE
    Okay. I am now obese, lol.
    What if I was a powerlifter, or a body builder. Differet physics for different builds. I wear 34 29 pants.
  22. Apr 11, 2024 at 10:14 AM
    Steve40th
    sTEVE
    Seriously. When you get in, you rub against the edge of the seat, squishing that part of the seat that creases. It is super thin and very poor quality, as it flakes very easy..
  23. Apr 11, 2024 at 10:17 AM
    It's a Japanese vehicle not designed for fat American asses. :D
    Slopemaster likes this.
  24. Apr 11, 2024 at 11:18 AM
    First dip into this thread. It turned out to be a lot more entertaining than I expected. :popcorn:
    Harringbr99 likes this.
  25. Apr 11, 2024 at 12:54 PM
    Steve40th
    sTEVE
    Yep, no fat Japanese people, and thwy are all short too
  26. Apr 11, 2024 at 4:46 PM
    That's a JDM option :devil:
  27. Apr 12, 2024 at 6:20 AM
    Harringbr99
    Harringbr99 New Member
    Brian
    Kentucky
    2021 Barcelona Red Limited
    I am planning to find an try one of the leather repair kits to fix the issue before it gets worse for me. I can send pics / updates on the outcome of that work.
