Scam??
Discussion in '5th Gen 4Runners (2010-2024)' started by LCJ77, Mar 3, 2026.
  1. Mar 3, 2026 at 2:36 PM
    LCJ77
    LCJ77 [OP] New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    I received in USPS today a Post card & A letter about coverage of my 2023 Toyota 2023
    Motor Vehicle Notification
    Bunch of letters. PH # 1-888-535-0247 for Immediate Responses on Post card, Then Letter states bunch of BS that my coverage will end 13-Mar-2026. The vehicle was purchased 20-Nov-23. Freakin Scammers!!
  2. Mar 3, 2026 at 2:54 PM
    LCJ77
    Gilbertsville,Pa.
    I just called there . When I told him had 12,XXX on my 2023 h was taken back. Didn't sound like scam center, didn't talk long enough to confirm. Anyone else get this??:notsure:
  3. Mar 3, 2026 at 2:57 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    2021 Venture, 2024 Limited 4WD, 1979 FJ40
    Not that exact one, but similar. Sad thing is that some people actually fall for it.
    Toy4X4 likes this.
  4. Mar 3, 2026 at 2:58 PM
    Photon_Chaser 65,322 smiles and counting…
    West Coast!
  5. Mar 3, 2026 at 3:44 PM
    Sin4R
    2024 4Runner Limited
    Mall crawling kit.
    Unfortunately you just confirmed your phone number with scammers by calling them. Be prepared for more and better targeted scams.
    Ripper238, 5thToy, Whammo and 6 others like this.
  6. Mar 3, 2026 at 3:50 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    you should have blurred out your license plate on 4Runners .com!
  7. Mar 3, 2026 at 3:52 PM
    im joking
    LCJ77[OP] and ToyotaDude99 like this.
  8. Mar 3, 2026 at 4:06 PM
    It sounds like an extended warranty company.
  9. Mar 3, 2026 at 4:25 PM
    UncleShorty
    UncleShorty New Member
    Get an Android phone. Put the people you want talk with in your contact list. Go to the Do not Disturb settings and turn it on, "until I turn it off". Allow "Contacts" to ring through.
    Now any calls that are not contacts go straight to voice mail.
    Legitimate callers from non contacts will leave a voice mail. Scammers and telemarketers seldom do. Add those numbers to your "blocked" list. Identify computer calls because they will be partial voice mails that start in the middle of their spiel. Block them too.
    It won't stop everything but it will be a good indicator of legit vs. spam calls.
    Oh, and remember, every time you register your vehicle, renew your license or have a state inspection the STATE sells your info... Nice, huh?
    R1200Jedi and Saker like this.
  10. Mar 3, 2026 at 4:31 PM
    It sounds like an advertisement to sell mechanical repair insurance (which these companies like to call “extended warranties”). They probably guess on your purchase date based on public data.
    They write it vague and with official-sounding language, but technically speaking they are correct that your three year warranty will be expiring soon.
    Doesn’t matter though, I wouldn’t buy extra mechanical breakdown insurance anyway, especially from a random company. Even if it’s a legit company, the insurance terms probably suck.
    LCJ77[QUOTED][OP] likes this.
  11. Mar 3, 2026 at 4:34 PM
    Look for the very fine print indicating solicitation. Groups are good at mimicking forms/sites to get additional information.
  12. Mar 3, 2026 at 4:38 PM
    This thread brought by RickG's cousin
    Jk jk please dont let scammers scam and always err on the side of caution
    nimby, ToyotaDude99 and LCJ77[OP] like this.
  13. Mar 3, 2026 at 9:25 PM
    Pretty sure scammers love AI now. They can use it to search millions of data points in a very short period of time for more potential targets.
    ToyotaDude99 and Toy4X4 like this.
  14. Mar 4, 2026 at 5:59 AM
    LCJ77
    Gilbertsville,Pa.
    Yeah at the very bottom last sentence states "US Automotive Protection Services is not affiliated with any auto dealer or manufacturer" I told him I purchased it 20-Nov-2023 & it's not 3 yrs old & have 12xxx miles on it. I used my land line & I get all kinds of BS calls that I either let go or hit answer buttom & End buttom. Yes have a land line because my Verizon cell connection is not very good & drops calls just sitting still.
    ToyotaDude99 and NB4x4 like this.
  15. Mar 4, 2026 at 6:13 AM
    Snow Packed
    Snow Packed New Member
    I received one of those similarly worded threats on my vehicle coverage last week. It’s an occasional thing for us at the house and it was promptly disposed of in the shredder. If you save the monthly amount you’re paying for the warranty over a short period you’ll have a nice nest egg and not have to deal with some company that is excellent for denying coverage.
    NB4x4 and LCJ77[OP] like this.
  16. Mar 4, 2026 at 6:22 AM
    LCJ77
    Gilbertsville,Pa.
    I use all bills & stuff like this for fire starter in fireplace
    roooo, 2Toys and NB4x4 like this.
  17. Mar 4, 2026 at 6:42 AM
    SCMountaineer
    SCMountaineer New Member
    Upstate South Carolina
    On my fourth 5th gen-- white 2024 TRD Off Road Premium
    None yet
    I get these all the time for cars I dont even have anymore.
    roooo, 5thToy, NB4x4 and 1 other person like this.
  18. Mar 4, 2026 at 7:15 AM
    LCJ77
    Gilbertsville,Pa.
    This is the 1st one I ever got. Now I do get from dealer asking if I want to trade an older vehicle that I already traded from time to time.
    NB4x4 likes this.
  19. Mar 4, 2026 at 7:28 AM
    UncleShorty
    ALL "mail" I find in my snail mail box that doesn't have First Class postage, stamped or metered, goes immediately in the trash, unopened.
    It's all junk mail. Been doing that for 40 years. Haven't missed anything important yet...
    R1200Jedi, Saker and roooo like this.
  20. Mar 5, 2026 at 11:55 AM
    R1200Jedi
    R1200Jedi New Member
    2022 4Runner ORP
    Some scams actually put a smile on my face. Like the emails I occasionally get from "Social Security Administration?" ...where they literally put a question mark at the end of the title...like they aren't even sure if they are the social security administration. :rofl:
    Saker and ToyotaDude99 like this.
  21. Mar 5, 2026 at 12:28 PM
    Today I got a text that I failed to pay a toll, yada, yada, and that failing to submit payment through the provided link would lead to "serious consequences" etc. There are no toll roads or highways in NM, and I haven't been out of the state for a couple of years...
    Saker and LCJ77[OP] like this.
