Sagging rear on 2018 4runner
Discussion in '5th Gen 4Runners (2010-2024)' started by rockybird, Oct 6, 2018.
  1. Oct 6, 2018 at 4:07 PM
    rockybird
    rockybird [OP] New Member
    2018 Trd Pro
    I love my TRD pro, but the rear doesnt look as perky as the front. It almost looks like it sags. Someone at work parked a 4runner next to mine that was higher and looked great from the back. Is a leveling kit what I should ask for from the dealer? Will it make much higher for entry into the vehicle? I dont do 4 wheeling but I want my 4runner to look great. Thank you!
    76F40730-A41C-4048-B6AD-DDA7AC4F9E77.jpg 1DABB6F7-EA9E-41AD-A453-1E25FFDCBBAF.jpg
  2. Oct 6, 2018 at 4:40 PM
    JBTRD
    Jeremy
    Ohio
    2016 (The Real) Trail Edition
    Usually the front sags due to engine weight. Level kits only help front end sag. Don't have your dealer do lifts or level kits. Measure vehicle hight at each wheel well. That will confirm if the rear sags. (Make sure to measure on level surface). Pro models do have a tiny spacer in the front to help level vehicle but should not make the front higher than the rear. If you do measure and the rear and with no added weight of cargo or people it sags then go to the dealer to check things out. Other members with stock pros can chime in their height so you can compare as well.
    rockybird[OP] likes this.
  3. Oct 6, 2018 at 7:17 PM
    yardsale
    yardsale New Member
    Pro comes an inch higher in the front, stock. You probably saw a Trail or SR5 model without the stock front lift. Because of the rake on the one you saw, it probably looked higher in the back than yours, but in reality they are all the same stock hieght in the rear.
    rockybird[OP] and rsimi72 like this.
  4. Oct 7, 2018 at 7:06 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    That is weird. How many miles are on your Pro? Mine seems to be higher in the rear.
  5. Oct 7, 2018 at 12:41 PM
    rockybird
    2018 Trd Pro
    Thanks guys! From the side, the car looks even. It just looks low from the back. I havent measured but it does appear symmetrical from the side...but see how the back looks?
    I have 1500 miles on it.
    448C1DA6-8151-4786-883B-8B4599658E06.jpg D197E0AC-4C5C-4026-851B-23AB59144237.jpg
  6. Oct 7, 2018 at 2:19 PM
    RusPro17
    Don
    Pa.
    A6267226-771D-44C8-9CFB-42BCE82B4BDB.jpg My 17 has 4600 miles it looks the same as yours. Depending where the vehicle is parked. I think you get a different stance.
  7. Oct 7, 2018 at 2:49 PM
    JBTRD
    Jeremy
    Ohio
    Looks normal to me
    rockybird[QUOTED][OP] likes this.
  8. Oct 7, 2018 at 7:37 PM
    rockybird
    2018 Trd Pro
    Thanks guys. I think you are right...I’m over reacting. The back really doesnt look that great to me, but I guess that’s how they are.
  9. Oct 8, 2018 at 5:20 PM
    JosephMehta
    JosephMehta New Member
    Zombocalypse
    Shrockworks Front Bumper, CBI Rear Swing Away with dual Jerry Cans and full size spare, Full Shrockworks Armor, Warn 9.5 Synthetic, PIAA Lighting on roof rack and front bumper, Rear lighting wired to vehicle's reverse gear, Dobisons dual slide out rear bay storage with sliding top and refrigerator tie-downs, Limb Risers, Gobi Rack w/mounted Powertank, Fire Extinguisher, Jack, Axe, and Shovel, 33" Nitto Grapplers (295/70/17), Body Mount Chop, Icon Stage 7 Billet w/S2 Stage 3 Secondary adjustable front suspension, 3.5 inch Icon Stage 7 Billet with Billet Upper and Lower Links, Icon Bump Stop, 3.0 inch Icon Overland Rear Coils, ARB Front and Rear Air Locker with ARB Differential Breather (relocated to engine bay), ARB Twin Compressor mounted in engine bay, 360 degree, 4-camera system with DVR with monitor mounted on the dash, Dual Rear Headrest Monitors w/DVD and gaming capability Future mods in 2019: Magnusson Supercharger w/Catback system and possibly an roof mounted, solar heated shower and water storage
    Overland (Heavy Duty) rear coils will help. I have ICON Stage 7 (billet) with the heavy duty rear coils, and it keeps the back end lifted the way I want. OME and Toytech have their version; certainly other suspension companies do too. I have a lot of weight on the vehicle, and the coils were necessary (for me).
  10. Oct 9, 2018 at 10:53 PM
    rockybird
    2018 Trd Pro
