Safe tire pressure when airing down
Discussion in '5th Gen 4Runners (2010-2024)' started by Opie-IN, Mar 22, 2024.
  1. Mar 22, 2024 at 9:15 AM
    Opie-IN
    Opie-IN [OP] New Member
    2023 ORP Magnetic Gray
    I am running stock size 265/70/17 SL rated Ridge Grapplers on stock 17x7.5 ORP wheels. When airing down for sandy beaches or light trails with loose soil, what would be a safe pressure to air down to? Thanks!
  2. Mar 22, 2024 at 9:31 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I won't go below 15 psi. Some here are more aggressive, but getting a bead back on is no fun. I've only reseated a regular tire, which was bad enough. An AT tire is a lot harder.
    HuskyMike likes this.
  3. Mar 22, 2024 at 9:32 AM
    For sand you can go down to as little as 6 psi. Usually the ground clearance tradeoff becomes too severe. If you went this low rock crawling you'd most likely debead a tire without beadlock wheels. Some sand dune ORV parks like Silver Lake requires airing down to 15 psi or lower.
    If you have a good air pump, you can seat a tire bead with a ratchet strap around the tire without using starter fluid or non-chlorinated brake cleaner.
    Some tires like the Cooper STMaxx likes to collect debris in the bead area when aired down. Seen it with 3 trucks in my off-road club. It's related to the tire mold geometry in the bead area. I don't know if Ridge Grapplers have this quirk or not. The tires I've run (GY Duratrac, Kenda Klever RT) don't seem to have this issue.
    Ripper238 likes this.
  4. Mar 22, 2024 at 9:46 AM
    Opie-IN
    OK, appreciate the input so far. I do not want to get into any situations where I pop the bead and have to reseat the tire.
  5. Mar 22, 2024 at 10:05 AM
    ID_Yeti
    ID_Yeti New Member
    2024 ORP
    I am a 15psi'er as well.
  6. Mar 22, 2024 at 10:09 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    For me its very dependent on the trail, anywhere from 15psi to 25psi. On a beach i would go lower, but I like the woods.
  7. Mar 22, 2024 at 11:31 AM
    For light trails I'd say it's up to you. I hit the easiest trails at a nearby off-road park at street pressure out of curiosity and it was still softer than the ol' crossover at 22-25ish psi. Footprint/grip/rocks wasn't a concern so it would've been a question of comfort.
    Something bumpier, rockier I'd start somewhere in the 20's and see how it goes.
  8. Mar 22, 2024 at 11:39 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    For me
    18-20 psi is typically enough to soften the ride up and let the tire deform over obstacles.
    Wouldn't go lower than 15 unless I was in snow or sand and really needed that extra traction.
    18PSI 285/70/17 on a 8.5" wheel:
    bobby4runner and icebear like this.
  9. Mar 22, 2024 at 1:28 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    That's what I do (stock tire size)
    20-23 dirt roads
    18-20 light off roading
    17-18 crawling (nothing too crazy)
    15 in sand or really struggles and need to get over an obstacle (rare that I have to go that low though)
    I personally wouldnt go any lower without beadlocks
  10. Mar 22, 2024 at 2:44 PM
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    One air pressure in sand does not necessarily fit all. With over 50+ years driving in deep soft sand around Cape Hatteras, here is a general rule that works for most stock radials in sand.
    General rule is with vehicle loaded like it will be on the sand, including people, and vehicle on level pavement and tire pressure at recommended cold street pressure, measure the height from pavement to edge of rim. Then lower pressure until the height is ¾ of street pressure height. For my T4R this ranges from 18-20 psi. Recommended cold street pressure being 32 psi. Again it depends on load.
    This gives the optimum flat footprint. Going much below that adds little in traction and makes it much more likely to break a bead.
    I learned this from an old desert rat out west. It has done well for me.
    ElectroBoy, 3JOH22A and icebear like this.
