Rusted OEM parts on 2019 4Runner or replacement parts?
Discussion in '5th Gen 4Runners (2010-2024)' started by BeachgirlTX, Aug 29, 2023.
  1. Aug 29, 2023 at 5:30 PM
    BeachgirlTX
    BeachgirlTX [OP] New Member
    OEM Rusty Parts?
    2019 4Runner
    I just recently had a small back fender plastic rip due to tire blow out.
    Body shop had my 2019 4Runner for over 20 days and I noticed my remote on key had a white sticker over what I now found out would cover my FCC ID #. Red flag then the grill in front I never saw rust before peered caught my eye. I tried to open my car with second backup remote key with FCC ID and the car doors would not open.
    My car has generic remote with my key. My gut says look under the SUV
    Go to a garage lifted up and was shocked at pictures attached. Can someone confirm these rusted parts have been exchanged out for generic or flooded parts from a different vehicle?
    I see caps or bolts which have no rust
    Not sure if these parts labeled are OEM?
    I confronted the insurance company and the body shop.
    Need backup advice to confirm these parts are not from my 2019 4Runner?
    All advice and feedback will help me to figure out what I must do next.
    Ty
    MSJ
    mrmike7189 likes this.
  2. Aug 29, 2023 at 5:48 PM
    Startrek
    Startrek New Member
    It's your vehicle and it is your rust.
  3. Aug 29, 2023 at 6:04 PM
    4Runners tend to rust pretty easily. Judging by your name, I'm thinking you spend a lot of time at the beach? Salt air, and especially salt water, is not good for steel.
    I don't know about the keys, but I highly doubt that anyone would have switched out any of those parts while you' 4Runner was at the shop.
  4. Aug 29, 2023 at 6:08 PM
    Mojave
    Mojave New Member
    zeak
    az
    5Th Gen 4Runner trd off Road
    do you live in the rust belt ?
  5. Aug 29, 2023 at 6:13 PM
    Hi @BeachgirlTX and welcome to the forum. Can you flesh out the issue with the keys? Do you have aftermarket remote key fobs? And after you got your car back the key had a sticker on it, and the spare key didnt work? Maybe connect the dots a little bit.
    As for the rust, go through the shop invoice in detail and confirm that parts they say they replaced are rusty. Also look under the rest of the car and see what the “ambient” amount of rust is, and whether the new parts are particularly rusty.
  6. Aug 29, 2023 at 7:00 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    nothing underneath appears to have been swapped. condition of the wheels and the front sub-frame tells the story. .
  7. Aug 29, 2023 at 7:14 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    That all looks factory and it looks like the vehicle has spent some time in a salty environment.
    Judging by how dirty the wheel barrels are it would be a good idea to occasionally clean your car, including the underside.
  8. Aug 29, 2023 at 7:16 PM
    A lot of questions arise - where do you live? Did you buy new or used? If used, do you know where it was before you bought it? Any maintenance records? Is this the first time inspecting underneath the vehicle? Without more information, it's hard to form an opinion.
  9. Aug 29, 2023 at 7:39 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey welcome here! @BeachgirlTX
    When it comes to the rust, which there's quite a lot of, it's somewhat never too late to start restoring and rust proofing. I wish got at it earlier under my 2016, living in British Columbia near ocean. Highly recommend you start looking under there more often, rinse and wash, and invest in rust proofing as soon as you can afford anything at all.
    Good luck !
    Han4Run, Mojave and BeachgirlTX[OP] like this.
  10. Aug 30, 2023 at 3:44 AM
    Matt83
    Matt83 New Member
    Northeast
    Wool Wax
    BeachgirlTX[OP] and Startrek like this.
  11. Aug 30, 2023 at 10:14 AM
    It’s a curse or something. It’s not 100% of the time, but there have been so many times that I’ve responded to a first time poster with a problem, and then they vaporize, never to be seen again. My online aura must be uniquely repellant to new posters.
    Han4Run, MeefZah and Saker like this.
  12. Aug 30, 2023 at 10:22 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    It must have been a terrible disappointment to see that much degradation in such a young vehicle. I figure it was too painful to engage further on the topic.
  13. Aug 30, 2023 at 10:32 AM
    This post is a little confusing and hard to follow.
    It sounds like you had a tire blow out and cause damage? You said it damaged a small back fender? How small? Was it just a mudflap, or was there extensive body damage from the blown tire?
    You have pictures of most of your undercarriage? Where was the repair work done? What did they tell you was replaced or repaired? Got any pictures of those areas specifically?
    As to the rest of the undercarriage, it looks like a typical 4runner that gets exposed to salt and doesn’t get rinsed off very frequently.
    mrmike7189, MeefZah and 5thToy like this.
  14. Aug 30, 2023 at 10:42 AM
    Honestly though, the rust does NOT look that bad. All she needs to do is make sure it gets rinsed off really well, then coat the frame with woolwax or fluid film. I’d spray some of the thinner fluid film first on all areas that have deeper rust, and the insides of the frame rails and crossmembers. That will make sure it penetrates the rust well. Then coat the entire frame with wool wax.
    The owner should understand that a woolwax coating looks ugly after it gets run through dusty, or muddy conditions. But that’s the price to pay to keep the 4runner from getting structural rust that will make it worthless in 10-15 years.
    Technologic80 likes this.
  15. Aug 30, 2023 at 10:43 AM
    Yes. She’s posted pictures of both the front and rear axles and it all looks pretty uniform regarding the degree of corrosion.
  16. Aug 30, 2023 at 10:49 AM
    backpacker
    2023 TRD ORP
    I agree. It looks early enough to prevent lasting consequences if dealt with in a timely manner.
  17. Aug 30, 2023 at 11:09 AM
    4Runner_Patrick
    4Runner_Patrick New Member
    2023 TRD PRO Black
    That looks similar to my 2016 with 136 K. Live close to ocean and salt in winter.
  18. Aug 30, 2023 at 11:44 AM
    Username Beachgirl.
    I'm assuming takes 4R to beach.
    mrmike7189 and MeefZah like this.
  19. Aug 30, 2023 at 11:44 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    She needs a second pair of experienced eyes on the ground.
    If this vehicle had this much rust before the service. She would have noticed. The T4R sets high up the ground.
    Seems those stickers were taped.
    Wouldn't want a keep a vehicle like this
  20. Aug 30, 2023 at 12:07 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    a lot of what is pictured isn't easily seen unless you start crawling under there which i doubt is the norm for this person.
    look at the photo of the frame where the LCAs are bolted. the rust on the frame matches rust everywhere else. are we saying a full body/frame swap was done to this truck?
  21. Aug 30, 2023 at 12:20 PM
    I agree that OP is shocked, not only to find the rust under there upon looking at it for the first time, but also that everyone is pretty much saying she owns that rust, no one swapped an entire suspension and drivetrain onto her 4R while fixing the plastic panel. Too painful to respond, apparently.
  22. Aug 30, 2023 at 3:33 PM
    No just no.
    No one is going to swap all that shit get real. You cannot see what is posted without going under there.
  23. Sep 2, 2023 at 7:27 AM
    BeachgirlTX
    OEM Rusty Parts?
    2019 4Runner
  24. Sep 2, 2023 at 7:40 AM
    BeachgirlTX
    OEM Rusty Parts?
    2019 4Runner
    My 4Runner bought new one time owner
    Both sets of keys came with FCC ID numbers
    Upon return of my vehicle the remote with my car key has been changed to a remote without the FCC ID # this caused me to question the rust peering behind the front grill
    I had never noticed before 2nd red flag.
    my backup OEM remote does not work on opening the suv.
    The shop neglected telling about me about the new remote and reprogramming my locks.
    Why would they steal my FCC ID remote?
    when I confronted them they asked me to bring my second key into shop as they said they did not swap out my remote.
    I live close to the beach but I take care of my 4R.
    Then there’s the front frame rust not there before.
  25. Sep 2, 2023 at 7:40 AM
    BeachgirlTX
    OEM Rusty Parts?
    2019 4Runner
  26. Sep 2, 2023 at 7:59 AM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    they probably lost your key and purged all the remote and immobilizer codes.
    what rust prevention measures have you taken on your 4R? do you have record of the undercarriage not having rust before you took it to the body shop?
  27. Sep 2, 2023 at 8:05 AM
    BeachgirlTX
    OEM Rusty Parts?
    2019 4Runner
    The remote was a red flag as was the rust appearing out of nowhere behind my front grill from the frame.
    After placing the suv on the rack and viewing parts that are rusty. Why are their new bolts holding some of the undercarriage rusty parts in place?
    It may seem like a lot of work to swap out a total body frame but in Texas, there are thieves that walk away with excavators and catalytic converters in minutes.
    Some thieves can work after hours and over twenty days in the shop for a small tear on backside of my passenger plastic fender, may have been ample time to get the switch or parts or total body frame replaced.
    My 4 Runner looks like a 4Runner used with a boat. I don't own boat but I do believe I need a professional set of eyes to make a determination on my 4 Runner’s undercarriage as it’s only 4 years old.
    I have yet to check the Engine block to see if my numbers match up to my owners manual.
    A professional legal inspector of auto should be able to make a positive confirmation either way.
    If it’s my rust I’ll treat it
    but my gut and eyes and knowing my vehicle plus the remote being the first red flag, tells me to get a legal inspector to file a claim with an attorney if I am right.
  28. Sep 2, 2023 at 8:13 AM
    BeachgirlTX
    OEM Rusty Parts?
    2019 4Runner
  29. Sep 2, 2023 at 8:17 AM
    BeachgirlTX
    OEM Rusty Parts?
    2019 4Runner
  30. Sep 2, 2023 at 8:26 AM
    BeachgirlTX
    OEM Rusty Parts?
    2019 4Runner
    Sorry Captain on just now replying back to all on forum. Just got out of the cloud of three day flu. I appreciate everyone’s feedback
    Was out due to flu and will take everyone
    Opinions with a second pair of professional eyes to inspect my 4Runner to include all under my hood engine included.
    Need to make sure my numbers matchup to my manual. Thieves in TX go beyond what seems like a norm plus new bolts on old rusted parts not making sense.
