Running wire through the firewall...
Discussion in '5th Gen 4Runners (2010-2024)' started by vthoky, Jan 12, 2025.
  1. Jan 12, 2025 at 4:56 PM
    vthoky [OP] A mighty curious fellow
    ... how many "reasonably accessible" places are there for a wire pass-through?
    I've used the easy-to-find one, in the area behind (ahead of?) the brake pedal and fuse box. I need to run another cable (three wires) through, and I'm wondering if there are more pass-throughs that are as easy to deal with as that one.
    Anyone got guidance to give? Thanks, all.
  2. Jan 12, 2025 at 5:04 PM
    You have two main options:
    Passenger side grommet:
    https://www.youtube.com/watch?v=94yyWXuUDC4&t=72s
    Drivers side grommet:
    https://www.youtube.com/watch?v=AF4FpuLROwc&t=1s
  3. Jan 12, 2025 at 5:15 PM
    Thanks, BL!
    I've used the one JP shows on the driver's side. There may be room still to get this cable through, but I'm trying to make a Plan B before I get started.
  4. Jan 12, 2025 at 5:55 PM
    yotahead858
    yotahead858 New Member
    2023 4Runner Limited
    I used the rubber grommet where the harness passes through. There's a "nipple" on the grommet I sliced to feed my auxbeam cable.
    I'm saving the one shown in the video above when I decide to run a power cable to the trunk for an amp/ subwoofer set up.
  5. Jan 13, 2025 at 10:07 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    The grommet you describe on the driver's side behind the fuse box is large enough to get multiple cables through. I've passed a PL-259 antenna connector through it, albeit tightly, and with Windex on it as lube. That's about 1" diameter.
  6. Jan 13, 2025 at 10:59 AM
    The rubber grommet. Here is a tip though. Take a long screwdriver and push from the engine bay inward. Push hard. You have padding on the inside you need to clear out of the way. My grommet hole was covered with padding. Simple push with flat base screwdriver cleared it out.
  7. Jan 13, 2025 at 11:12 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    I used the D/S punch a hole W/scribe then pulled 0.041 SS safety wire through. Made a "J" hook wrapped pwr wires for Bright box Anytime driving lights & for Raptor lights. wrapped like a bullet W/electrical tape, DC-4 & grabbed W/pilers inside pulled all through, then smeared some black RTV on Eng. side of fire wall grommet.
  8. Jan 13, 2025 at 12:38 PM
    Lost Woods
    Lost Woods New Member
    The nipple on the wiring harness is large enough to pull a 6awg cable through without issue. You can get a standard 15mm or 5/8" wire grommet in the larger hole with 4 awg or even 2 awg. Un-split corrugated loom is also really good if you are just running a few wires and want it better sealed.
    This dude is king when running through the larger hole. Punched through the inner rubber liner like butter. Just punch through from the outside, run your fish wire, remove the tool, and pull whatever through.
    https://www.amazon.com/gp/product/B073WZCL8Q
  9. Jan 13, 2025 at 3:01 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Thanks for this
  10. Jan 13, 2025 at 3:03 PM
  11. Jan 14, 2025 at 2:13 AM
    Thank you all! And thanks dj for the link and videos.
    I've got some work to do this weekend... :^)
  12. Jan 16, 2025 at 4:55 PM
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    The big grommet that is on the drivers side is a great place.
    jeepster09 likes this.
  13. Jan 16, 2025 at 7:01 PM
    4Daughters
    4Daughters It’s how I know God has a sense of humor
    Ken
    Powder Springs, Ga
    2022 TRD ORP; Silver; too many port options...Ah well...
    TBD
    When I installed a front facing camera, had to run the wire through the grommet on the passenger side. It’s easy to see under the hood, low on the passenger side. I made a slit with a razor; very nerve wracking! Using a wire fish (fish tape) is a must.
