Running larger bore wheels
Discussion in '5th Gen 4Runners (2010-2024)' started by Try Harder, Apr 13, 2024.
  1. Apr 13, 2024 at 4:28 PM
    Try Harder
    Try Harder [OP] New Member
    Steve
    15 4runner limited
    None yet.... emphasis on yet
    Is anyone running aftermarket wheels with a bore larger than 106.1? How's the experience? Thanks
  2. Apr 13, 2024 at 6:07 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    I am not, but I'm not sure that I would. You'd be putting a helluva lot of faith in your wheel studs and lug nuts, turning them into the primary mechanism of vehicle support. Hub-centric wheels are designed to fit perfectly onto the vehicle’s hub, using it as the central point and bearing the vehicle’s weight. Lug-centric wheels rely on the lug nuts and studs for centering and bearing the vehicle’s weight. I think I want the primary support to be on the hub with the lug nuts as secondary support and making sure the wheel stays on. I also think you could end up with more potential for vibrations with a lug-centric set up. Why chance it? And, there are literally hundreds, if not thousands of wheels that have the 106.1 bore.
  3. Apr 13, 2024 at 6:23 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    I have 106.25 bore Methods, no issues at all. Lugg centric? Yes but there are no problems. Just the usual caveats. As stated.
    Try Harder[OP] likes this.
  4. Apr 13, 2024 at 9:23 PM
    You can get hubcentric rings with 108mm or 110mm OD and 106.1mm ID. Those will ensure the wheels stay true on the hubs when you torque down the lugnuts.
  5. Apr 14, 2024 at 5:08 AM
    Try Harder
    Steve
    15 4runner limited
    Yeah, I own a machine shop, I was considering buying some Chevy wheels and making some sleeves.... I wasn't aware they were available. This site is awesome. Thanks all
  6. Apr 14, 2024 at 5:13 AM
    Try Harder
    Steve
    15 4runner limited
    Technically, the support comes from the evenly torqued surface contact across the face of the flange. The shear point of a single lug stud exceeds the weight of the truck. You could hang it from a crane by the wheel with a solitary lug tight, I was more concerned with the absolute concentric nature and if the lugs alone would properly center it. But the wealth of knowledge here has pointed out that premade rings are available....
    3JOH22A likes this.
  7. Apr 14, 2024 at 5:21 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    I tried lug centric wheels on my old Tacoma and could never fully get ride of a slight vibration. Sold the wheels, purchased hub centric wheels and smooth as butter for the rest of the time I owned the vehicle. Lesson learned, I have always kept hub centric wheels on my Toyota trucks.
