Running Boards for 2021 4Runner Nightshade
Discussion in '5th Gen 4Runners (2010-2024)' started by nightshade SFC, Aug 31, 2021.
  1. Aug 31, 2021 at 10:53 AM
    nightshade SFC
    nightshade SFC [OP] New Member
    2021 4Runner 4x4 Nightshade
    I just purchased a 2021 4Runner Nightshade... I thought it would be easy enough to add on some aftermarket/OEM running boards but that doesnt seem to be the case. Apparently the nightshades have special running board brackets to fit the extra body flares?
    I wanted to purchase the board below (Part # PT925-89190) but apparently they dont fit given my VIN#. Various Dealership Parts Depts have told that only these will fit my vehicle (Part # PT93889100) but those clearly look like theyre for the TRD/Trail models. Any suggestions/recommendations are greatly appreciated.
  2. Aug 31, 2021 at 12:39 PM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    sorry don't know part # but all the running boards are the same its the brackets that attaches them to the body of the car are different since you the limited night shade the brackets should be longer because of your rockers are different thats it, the limited rockers are longer than any other model or should i say you have plastic cover over your rockers hope this makes sense
    there was a guy here that had the dealer instal running boards on his SR5 and the dealer had used the one from the limited and the hong like 2 to 3 inches farther down
    https://www.youtube.com/watch?v=3QQVQ8qsNn8
    toy33 likes this.
  3. Aug 31, 2021 at 2:38 PM
    Dick_Hammerbusch
    Dick_Hammerbusch New Member
    We are Championship
    21 Pho Runnah Nighshade
    None
    Have you considered Nerfs? This is what I have on mine. Check out Nfab's site as they have a wide selection of options, types, purposes, etc.
    MaschineRun4 and natekam like this.
  4. Aug 31, 2021 at 2:58 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    ^^^ I've got those on my Tacoma and they've been very nice. Good recommendation.
    Dick_Hammerbusch likes this.
  5. Aug 31, 2021 at 2:59 PM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    If I'm not mistaken, it has to do with the Limited/Nightshade specific brackets (assuming they mount the boards lower/further from the body?).
    Take a read through this thread:
  6. Nov 20, 2021 at 6:10 PM
    KayCeeC
    KayCeeC New Member
    I reserved 2022 SR5 that showed it came with nightshade running boards before it arrived at dealer it wasn't listed anymore so I bought the boards from another Toyota dealer and they were installed today. After search tonight I now know why they are so low with a big gap. Can I buy shorter brackets and still use the same boards so they are higher? Part number? Thank you.
  7. Nov 20, 2021 at 9:11 PM
    MaschineRun4
    MaschineRun4 New Member
    ‘14 4Runner Ltd
    @Dick_Hammerbusch is nfab the full name of MFG? Just trying to narrow down my Google search.
  8. Nov 20, 2021 at 10:15 PM
    You definitely got the running boards for a Limited/Nightshade. Can you return those to the dealer for a set of SR5 boards? Should be the same boards, just shorter brackets. I'm not sure if Toyota sells just the brackets.
  9. Nov 21, 2021 at 3:27 AM
    KayCeeC
    KayCeeC New Member
    @glwood54 unfortunately i can't return. I had verified with them part PT925-89190 was compatible but first timer here didn't even consider the fact they may work but look wonky!
  10. Nov 21, 2021 at 1:43 PM
    edgesalon
    Te
    18 FunRunner :-)
  11. Nov 21, 2021 at 6:29 PM
    Jemplyr77
    Jemplyr77 New Member
    Brian
    Oklahoma
    2019 MGM Nightshade
    Tinted windows. USR tail lights.
    I have the nightshade running boards on mine. I believe the ones you identified in your initial post are correct.
  12. Nov 22, 2021 at 11:08 AM
    Dick_Hammerbusch
    We are Championship
    None
    MaschineRun4[QUOTED] likes this.
  13. Nov 23, 2021 at 8:09 PM
    MaschineRun4
    ‘14 4Runner Ltd
    Thank you!!!
  14. Mar 11, 2022 at 3:43 PM
    Empusa
    Empusa New Member
    Interestingly, I was just told that this is the part that fits my VIN. The part number is for Limited and Nightshade. My VIN is for an SR5 Premium, but that they sent the following part number that is described for a limited only.
    (00016-89880)
  15. Mar 12, 2022 at 8:44 AM
    edgesalon
    Te
    18 FunRunner :-)
    all running boards are the same except the brackets that attaches them to the vehicle the Limited model has a longer bracket to allow for the side moldings hope this help
  16. Mar 12, 2022 at 9:07 AM
    That looks like Limited part. This is how SR5/TRD Running board should look like (Pic from my SR5)
  17. Mar 14, 2022 at 5:52 PM
    Empusa
    Empusa New Member
    I understand this may be the case, but it would be an unwarranted hassle for a new purchase that was represented to be a fit for your vehicle.
  18. Mar 16, 2022 at 7:41 PM
    Mikey8
    Mikey8 New Member
    The nightshade running board on my trd sport model
    grizzlypath and LarryDavid like this.
  19. Apr 3, 2022 at 5:56 PM
    LarryDavid
    LarryDavid New Member
    My dad just bought a ‘22 Lunar Rock TRD Sport this past November and he asked me if I can help him find running boards. Is your 4Runner a ‘22? Can you confirm if the part number is PT925-89190?
    I’ve been having a hard time finding which running boards he can install that does not require removing the trim underneath the doors.
