Running 6" lift, help leveling the front
Discussion in 'Suspension' started by Overland4runner, Jul 9, 2020.
  1. Jul 9, 2020 at 10:42 PM
    Overland4runner
    Overland4runner [OP] New Member
    Charles
    07 grey 4runner
    6" fj lift
    I'm new to 4runner world....I bought an 07 toyota 4runner with a 6" fj lift. The front is sagging about 2" I was wondering can I take out the shock and spring and spacer with the lift and put in an adjustable coilover with a spacer to get the front level or close to level
  2. Jul 10, 2020 at 6:37 AM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Tricky question, most people don't have 6" lifts, which typically come with replaced cross members and sometimes some custom fab work. Such a high lift changes geometry kinda extreme, such as lift spindles, etc. I'd first determine exactly what lift you have, such as a Rough Country, etc. Then I'd reach out to them to explain the question and ask what they recommend.
    I'm not sure you can just bolt in an adjustable strut with that much modification without considering spindles, shock travel and CV angles and stuff.
  3. Jul 10, 2020 at 8:44 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    2.5" Fox Suspension
    Like mentioned above... need to know more. If you're not sure, post up some photos. Also scared and curious how you're getting a 6" lift in the rear.
  4. Jul 10, 2020 at 1:22 PM
    Welcome to the forum.
  5. Jul 10, 2020 at 3:48 PM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    Yeah, I’d like to see a 6” lift on a 4 Runner. Not common, that’s for sure. It might be easier just to bring the whole thing back to a more practical lift using go to parts and methods.
  6. Jul 10, 2020 at 5:02 PM
    Ass-Highbinder
    Ass-Highbinder New Member
    Ass-high like an alley cat in heat.
    17" rear lift. 0" front lift.
    You know what ya'll need? Ya'll need 17" of lift in the ass end, like me.
    Just weld a few coils together and add some big ass spacers top and bottom. Then put a body lift on the ass end only.
    Done.
    Your welcome.
  7. Jul 11, 2020 at 4:19 AM
    Overland4runner
    Charles
    07 grey 4runner
    6" fj lift
    It's a 6" lift for an fj cruiser it was on it when I bought ot..the front has a spacer and the rear is springs with a spacer ..
    It's made by rough country from what I've researched
    Oldtoyotaguy likes this.
  8. Jul 11, 2020 at 7:50 AM
    Oldtoyotaguy
    The answer to your question, Overland4runner, is probably not, at least I’ve never seen a commercially available suspension kit that you could buy off the shelf that would do what you are asking. I’m not saying it doesn’t exist, only that I’m not aware of it. Could you reproduce what you have now, using some hybrid system you folk engineer yourself? Sure. Go for it. But unless this is a dedicated off road rig, purpose built for that much ground clearance for a specific application, a lot could be improved by putting a high quality after market suspension on it that still preserves your need for ground clearance and would also give you better integrity and driveability on the highway. There’s lots of options if you go this route.
    7385 and Thatbassguy like this.
  9. Jul 11, 2020 at 4:09 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Question OP, what are you looking for? You interested in keeping that much lift or coming down to say, 3" of lift?
  10. Jul 11, 2020 at 5:03 PM
    Overland4runner
    Charles
    07 grey 4runner
    6" fj lift
    I'm looking to clear 34s or 35s and not rub...I dont do hardcore offroad but I like to do some 4 wheeling
  11. Jul 11, 2020 at 7:05 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    So you can do a 34" on a 3" lift and do pretty well, which is a big bonus of lowering your center of gravity and being generally easier to work on, and you lift options open up immensely.
    35's is gonna require some cab mount relocates, mild tubbing and stuff. In the end, a 295/70/17 is like a 33.8 or 34" and will roll over most things a 35" would, considering it's only 1/2" less ground clearance.
    Do some research on 35's and what's needed, might not be worth the hassle, might be. Just know you're doing a lot of work for that one size up.
    Regarding your existing lift, sounds like it needs maintained so either way and evaluation is in order because there's going to be something that needs to be done, even to the existing ones. Care to post some pics so we can see the innards?
  12. Jul 11, 2020 at 7:13 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Does yours look like this? aby5y6uq_4b443ccd6afa9d6ce88d90163481b982bc101cb1.jpg
  13. Jul 11, 2020 at 7:49 PM
    Faux_Pro
    Faux_Pro New Member
    Jon
    2015 MGM SR5P
    OP, lets just confirm your lift. How may inches between your hub center and bottom of the fender... all 4 corners.
  14. Jul 12, 2020 at 5:39 PM
    Overland4runner
    Charles
    07 grey 4runner
    6" fj lift
    This is what I have now
    Oldtoyotaguy and ForRun like this.
  15. Jul 12, 2020 at 6:58 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    If I were you I’d get rid of that junk and go bilstein or OEM
    7385 and Oldtoyotaguy like this.
  16. Jul 12, 2020 at 7:08 PM
    Overland4runner
    Charles
    07 grey 4runner
    6" fj lift
    I have 25" from center of front hub to bottom of front fender and 36" in the rear
  17. Jul 12, 2020 at 9:23 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Ok so here's some data from looking at the photos:
    1. That's an aftermarket lift spindle 100%.
    2. Rear shocks are non-descript but likely just whatever comes with the Rough Country if that's what it is.
    3. Your rear has factory bump stops and no inner bumps in the coils. You can easily bottom the shock and bend up some stuff if you venture away from the pavement on that setup. I recommend ensuring the uptravel of the shock will not bottom out before the bump stops in the rear are engaged.
    4. I can't see it, but likely that means your front bumps are factory too.
    5. Front is likely a Rough country strut, or OEM strut with a gigantic spacers. That's the filler between the spring and the top of the shock mount. Mostly for show, but I know a few guys who have wheeled with them pretty hard and lift spindles. He tends to break stuff more often than the rest of us.
    6. That much lift might not have a aftermarket, longer driveshaft, but the angles are likely bad, especially if it's a 1-piece driveshaft. Can you confirm if you have a 1 or 2 piece rear driveshaft, and if there's play in the carrier bearing if you have a 2 piece?
    7. A photo from the front showing the CV angles would be helpful, I suspect they are likely ok if the lift spindle is doing it's job. Side note, wheeling hard with lift spindles, they tend to crack. Some people have reinforced them successfully, others not. I don't have any advice here, just know that they could be a weakness so inspect them.
    8. Couraga tires are made by Federal, in my opinion not a quality tire, but a nice looking one. If they aren't too old and not too worn they will do you just fine, so please don't take that as an insult, but they tend to dryrot quickly, so inspect in between the treads on the tire surface (not just the sidewall), to ensure it's still ok.
    9. The wheels look nice, but you won't be able to air down for both comfort and increased grip on those wheels, a 16" or 17" wheel will allow you to put more rubber on the sidewall, providing better offloading experiences.
    10. The Upper Control arms on the front are pretty decent and much beefier than OEM, if they are in good repair I'd not bother upgrading them.
    11. Could be camera angle, is your front sway bar contacting your frame?
    12. Frame looks good, I believe you have a solid platform on which to build.
    Back to my other question, what's your goal? Looks, rocks, baja, weekend warrioring? That will determine the advice worth taking from the rest of us.
    7385 likes this.
  18. Jul 13, 2020 at 5:24 AM
    Overland4runner
    Charles
    07 grey 4runner
    6" fj lift
    I'm wanting it to be functional not just for looks, not really wanting to rock crawl I've done that in heels for years just wanting more of a weekend warrior I guess but also a daily driver. Wanting to do some overlanding,camping and some I guess you'd say light 4 wheeling
  19. Jul 13, 2020 at 5:48 AM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Ok, ran into something interesting while trying to research info for my next round of questions.
    If you have an FJ suspension on your 4th gen 4Runner, it's possible someone has modified the suspension on the truck, or more specifically, the truck itself to accept the suspension modifications.
    Mainly, if you look at the connection of the shock at the bottom of the front suspension, does it appear there's any grinded parts?
  20. Jul 16, 2020 at 4:31 AM
    Overland4runner
    Charles
    07 grey 4runner
    6" fj lift
    It looks factory underneath no grinding...the guy I bought it from said he bought it while he worked at Toyota and 07 - 09 4runners and fjs used the same suspension..I'm not sure though
  21. Sep 22, 2020 at 5:03 PM
    SouthFloridaFJ
    SouthFloridaFJ New Member
    Radflo makes front coil overs for that lift. I had them on my 08 FJ with the RC lift. Get rid of the those rear RC shocks on the rear and it will make a huge difference in the ride quality. I used the Gas cellular shocks from Fabtech 6" lift for the rear.
  22. Sep 22, 2020 at 5:11 PM
    SouthFloridaFJ
