RRW Rims on 24 TRD Pro lets see those offsets
Discussion in '5th Gen 4Runners (2010-2024)' started by trl1990561, Jan 13, 2024.
  1. Jan 13, 2024 at 7:58 PM
    trl1990561
    trl1990561 [OP] New Member
    Jupiter, FL
    2024 TRD Pro Underground
    I'm coming from a 21 TRD Pro Tacoma RRW 7 -12 offset. Let's see them on the 4runner with stock tires and suspension. Not sure on the 4runner whether to go with the -12 or -25? Looking for a .5"-1" poke.
    djwantke likes this.
  2. Jan 15, 2024 at 8:35 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I'm in the same boat. Looking for info on RRW 17x8.5 -25 wheels. I'm debating getting the -12 version or the -25.
    donnermel and djwantke like this.
  3. Jan 16, 2024 at 7:15 AM
    1SilverRunner
    Tejas
    So I pulled the trigger yesterday. RR6-H 17x8.5 -12. There are plenty of forum posts on this exact topic. My two cents is if you're wanted really aggressive poke, go with the -25. The -12 looks to provide a little poke but not overly aggressive.
  4. Jan 16, 2024 at 1:32 PM
    trl1990561
    Jupiter, FL
    Do you have a Pro ? If so looking forward to pictures of the -12
  5. Jan 16, 2024 at 1:44 PM
    1SilverRunner
    Tejas
    I have a TRD Off Road Premium with an OME 3" lift. I used WillTheyFit.com to compare and contrast tire sizes I've seen on the Web.
    Looks like the 17x8.5 -12 with 285/70/17 should offer very minimal poke. Did hours and hours of research before deciding the -25 was a little too much for me personally.
    donnermel likes this.
  6. Jan 16, 2024 at 1:48 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @trl1990561
    @1SilverRunner
    If it helps visualize, see poke photos below
    (can ignore that I have a 3/2 suspension lift)
    #1: 0 offset
    #2: -32 offset
  7. Jan 16, 2024 at 1:53 PM
    1SilverRunner
    Tejas
  8. Jan 16, 2024 at 2:07 PM
    Sorry, they're 17x9
  9. Jan 16, 2024 at 2:27 PM
    1SilverRunner
    Tejas
    Looks sweet man!
    Here's a couple pictures for OP. This is a TRD Pro with 17x8.5 -12 wrapped in 285/70/17 tires. Looks fairly flush. Not too much poke.
    The -25 version would be 13mm (1/2") more poke.
  10. Jan 16, 2024 at 4:20 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    These are 17x8.5 rrw rrv5 -12
    If I could redo...I'd go -25. Other then that i love them, they held up great after 4 years.
  11. Jan 16, 2024 at 4:26 PM
    trl1990561
    Jupiter, FL
    Yea -12 look more aggressive on the Tacoma than the 4 runner might have to go -25
  12. Jan 16, 2024 at 4:35 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I originally bought mine for my 2016 tacoma. Then when I sold that I transferred them over to the 4runner. I think they sit perfectly flush on the 4runner. But id like a little more. 17x8.5 -25 or 17x9 -38 would be awesome.
  13. Jan 16, 2024 at 4:36 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Same wheels on my old tacoma
  14. Jan 17, 2024 at 12:43 PM
    trl1990561
    Jupiter, FL
    Looks like I want a -25 offset. I awesome I'll have a bit of rubbing with the -25 on stock tire sizes.
    djwantke[QUOTED] likes this.
  15. Jan 17, 2024 at 1:11 PM
    Nice, ya I agree; do the -25. Thanks Hossler, def looks like you get more poke on a Tacoma with the same tire.
    When I was running 0 offset, 9" wide 285/70 wheels, the poke was virtually flush. I was anticipating more poke, wasn't happy with that. At -32 offset I'm content.
    Regarding rubbing.
    I think TRD Pro 4Rs come with approx 1.5" lift in the front (conflicting Google information on the rear lift).
    Which can help a little.
    Are you purchasing a PRO or have a PRO @trl1990561
  16. Jan 17, 2024 at 3:05 PM
    trl1990561
    Jupiter, FL
    purchasing a pro should be here the beginning of next month
  17. Jan 17, 2024 at 3:14 PM
    Wow nice, heck of a machine
  18. Jan 17, 2024 at 3:14 PM
    A 2024 PRO will be in a museum one day
  19. Feb 5, 2024 at 8:17 AM
    1SilverRunner
    Tejas
    Finally got the wheels put on. Super happy with the fitment. The wheel itself is flush with the fender but the tires are able to poke about 1/2" -1" outside the fender. (285/70/17 Nitto RG's)
    This fitment is ideal imo.
    Visible tire poke but not excessive.
    Simple BMC and fender liner mod means I don't rub even under compression.
    Not worried about slingling rocks and mud on the body work.
    If you like a lot of tire poke go with the -25. You'll get another half inch of poke. For my rig, I'm very happy with the 17x8.5 -12.
  20. Feb 5, 2024 at 12:12 PM
    :popcorn:
    1SilverRunner likes this.
  21. Feb 5, 2024 at 5:35 PM
    trl1990561
    Jupiter, FL
    Brought her home today
  22. Feb 5, 2024 at 5:36 PM
    Congrats!
  23. Feb 5, 2024 at 5:38 PM
    Nick4RNR
    Nick4RNR New Member
    Welcome and congrats!
  24. Feb 5, 2024 at 6:34 PM
    Ho-ly! Stoked for you
  25. Feb 5, 2024 at 6:43 PM
    That's a killer look!
    I wanted a blacked out silver 4R but my wife said naw, we're doing white.
    You got lift springs or spacers? good lookin lift on it
  26. Feb 5, 2024 at 7:02 PM
  27. Feb 6, 2024 at 5:16 AM
    1SilverRunner
    Tejas
    Nice badge :cheers:
    And thanks man! It's a OME 3" lift.
    I'm excited to see what OP will do with his. The Pro suspension is already very good. I bet a set of RRWs w/ 33s will look great on it. And selling the Pro wheels should help recoup some cost.
