Rotation algorithm?
Discussion in 'Wheels & Tires' started by DZee, Jan 17, 2021.
  1. Jan 17, 2021 at 12:10 PM
    DZee
    DZee [OP] New Member
    DZ
    2002 4RUNNER
    Leveling kit, shocks upgrade, 5 BF Goodrich KO2s
    Hello, I’m a newbie. 2002 4RUNNER and 2004 Tacoma. I have 5 fresh BF Goodrich, KO2s on each truck. Both have matching alloy spare wheels. What do you think about a mileage routine for rotation to maximize even wear for the 5 tires? The tire guys say 3500, based on 4 tire sets. Thanx!
  2. Jan 17, 2021 at 1:02 PM
    kbp810
    kbp810 rebmem wen
    I go about every 5,000 miles
    HondaKen likes this.
  3. Jan 17, 2021 at 1:48 PM
    Welcome DZ, i do 5k.
    doublewide and HondaKen like this.
  4. Jan 17, 2021 at 2:20 PM
    Welcome! I also do 5K intervals as that's when I change my oil. I had a set of KO2's for 29K miles and they had 80% of their original tread when I went to bigger tires. They're on a friend's truck now.
    I don't rotate the spare in, but it's not a bad idea. Just pick a sequence and stick with it.
    HondaKen, a47chuck and SR5 Limited like this.
  5. Jan 18, 2021 at 2:42 AM
    Welcome from Wisconsin! 5000 here.
  6. Jan 18, 2021 at 12:46 PM
    Tuco S.
    Tuco S. New Member
    KO2's have a 50,000 mile tread life warranty, which is based on a set of 4 tires. A set of 5 should increase the expected lifecycle of the set to 62,500. An easy way to figure it out is to divide the expected lifecycle by 20 (5 tires x 4 complete cycles of rotations, such that each tire spends the same amount of miles at each corner). Rotating every 3,125 miles should maximize your set of 5.
    And for reference, if you use a 4 tire rotation, divide the 50,000 mile expected lifecycle by 8 (4 tires x 2 corners, as these rotate front-to-back and back-to-front). Using a 4 tire rotation, you would want to rotate every 6,250 miles to maximize tread life.
