Rookie here. Offset question
Discussion in '5th Gen 4Runners (2010-2024)' started by BayStYat, Jun 21, 2021.
  1. Jun 21, 2021 at 3:15 PM
    BayStYat
    BayStYat [OP] New Member
    I have a 2016 SR5 4wd. Bilstein 5100 1.75 front 1.5 rear with 275/70/17 BFGs
    i would like to replace my wheels but unsure of the offset I need. I Would like the tires to sit just an inch outside of the wheel wells. It’s a T Force package so it has the fender flares.
    What range of offset would you recommend?
  2. Jun 22, 2021 at 2:22 AM
    Welcome from Wisconsin! In the column on the left side are a bunch of threads, one of them is 'tires and wheels', try clicking on that, you should be able to get some info on that subject there. I'm going to take a guess at the offset; -15 offset, like I said this is only a guess. You can also try the 'search' area in the upper right.
    Mtbpsych and 7385 like this.
  3. Jun 22, 2021 at 5:58 AM
    BayStYat
    Thank you sir.
    Toy4X4 and 7385 like this.
  4. Jun 22, 2021 at 6:51 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    -15 to -25
    Toy4X4 likes this.
  5. Jun 22, 2021 at 6:55 AM
    BayStYat
    Thank you sir
  6. Jun 22, 2021 at 12:56 PM
    Yoda_4RGirl
    Yoda_4RGirl New Member
    Amie
    SE New Mexico
    2021 Magnetic Grey TRD Off Road Premium
    3" ARB OME Lift, 285/70/17 Milestar Patagona MT's; 17x9 -12 Fuel Heater Wheels; UpTop Bravo Roof Rack, Predator Steps and more to come
    I wanted a real aggressive look. Some Runners I've envied have -38 offset and that's what I wanted with some 295's, but did not want to do a BCM or any fender trimming. I went with a -12 offset and the tire is about an inch past the fender and I didn't have to do any trimming. It only rubs a tab bit on my mud flap, but I'm actually fixing that by drilling 2 small holes and using a zip tie to pull them back. Saw someone do it on YouTube. So if you don't mind any trimming, or fender mods then the more offset you go the more it will stick out.
    Toy4X4 and SlvrSlug like this.
  7. Jun 22, 2021 at 5:07 PM
    BayStYat
    Thank you! I found a set I like but they are -10. The -12 were 17x9. I have 275s and don’t want to put them on 9” rim. The -10 are an 8” rim.
  8. Jun 23, 2021 at 2:32 AM
    We had a very slight rub on mud flap, just did the exact mod you're talking about.... it works.
