Roof Top Tent
Discussion in '5th Gen 4Runners (2010-2024)' started by b6793, May 9, 2025.
  1. May 9, 2025 at 10:27 AM
    b6793
    b6793 [OP] New Member
    (2020 4runner) I am looking at purchasing a used roof top tent, but the seller is saying that the stock side rails may not be adequate for the weight of the tent. I have looked around and find that the side rails are rated for carrying a max weight of 165#. The tent weight is 175# on its own. But looking thru some other conversations about roof support I have come across some that say you can put up to 300# on the roof without an issue. Can anyone help me confirm the max weight the stock side rails are good for? I know i may need to get other cross bars than what i currently have on it.Thanks
  2. May 9, 2025 at 10:33 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    You are going to get differing opinions but in my actual experience - yes, the side rails are fine. I ran a Roam which weighed around 100 lb on them with "upgraded" crossbars (Inno square bars and towers) and it was rock solid.
    I didn't much like a RTT (my musings on it can be found via search of you really care LOL) so it was short lived, but problem free on those rails.
    The guy I sold it to mounted it to the OEM curved crossbars on his truck at time of sale and it didn't appear to disintegrate as he drove away...
    1SilverRunner and b6793[OP] like this.
  3. May 9, 2025 at 10:38 AM
    b6793
    MeefZah, Thanks for your comment. Yea, i am sure i will get comments on peoples preferences that have nothing to do with my actual question. If i purchase the RTT it will be the 2nd i've owned and a different style all together.
    MeefZah likes this.
  4. May 9, 2025 at 10:39 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Get some LFD cross bars or something similar to what @MeefZah had.
    The OEM cross bars aren't great but the side rails are solid.
    Schlappesepple and b6793[OP] like this.
  5. May 9, 2025 at 1:53 PM
    blksubykid
    blksubykid New Member
    I mounted my first RTT, Tepui Ayer, which weighed at most…100lbs…onto LFD crossbars. I ran this config for a couple of years and hit a ton of trails with it. No issues
    b6793[OP] likes this.
  6. May 9, 2025 at 3:29 PM
    thomason84
    thomason84 New Member
    2022 supercharged and lifted 4Runner
    Bilstein 8112 lift Magnuson Supercharger YotaWerx Stryker+ tune Sherpa Crestone rack Lots of other small stuff
    It’s more that the dynamic rating of the factory bars isn’t much. I have a 230lb tent and got a Sherpa rack, thing is super solid. My factory rails would move with two kayaks on them so it’s all about where you drive, how fast you take turns, and if you need to suddenly stop will the roof rails hold the weight.
  7. May 9, 2025 at 8:12 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    The weight rating would be secondary concern of mine. Getting into the RTT after a few cocktails and the ensuing 3 a.m. pee is enough to realize an RTT isn't for me.
    AmericanGI, McSpazatron and MeefZah like this.
  8. May 10, 2025 at 7:42 AM
    Beachguy
    2024 TRP ORP
    This
  9. May 10, 2025 at 7:47 AM
    thomason84
    That’s real easy to say until you have a tent flying off your rig or hanging off of it. The dynamic weight rating is the most important rating you have when it comes to a RTT. Would you use a 5k lb winch to recover a 10k lb rig? No, for obvious reasons.
  10. May 10, 2025 at 7:50 AM
    Beachguy
    2024 TRP ORP
    No I wouldn’t. But I think you misinterpreted my response. I’m never using a rtt because I’m not crawling up and down, especially in the middle of the night to pee. Which is frequent as I get older.
    Edit to say, for me it’s not being drunk. Just not my gig.
    AmericanGI and Stoney Ranger like this.
  11. May 10, 2025 at 7:53 AM
    thomason84
    No I didn’t. Why comment on a thread asking about a RTT and worried about weight ratings. I wanted to be clear, dynamic weight ratings are the most important and your message give the opposite message and having hidden meanings leads to people getting in bad situations.
  12. May 10, 2025 at 7:58 AM
    Beachguy
    2024 TRP ORP
    Yes “secondary concerns” have hidden meanings.
    Stoney Ranger likes this.
  13. May 10, 2025 at 8:04 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Your factory roof rails would move, or your crossbars would move? Because I have never experienced the roof rails moving. OP asking about the rails, not crossbars.
  14. May 10, 2025 at 8:08 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    The opinion of the RTT boyz back in the day was you should keep a dedicated large mouth Nalgene bottle up there to pee in; keep you from falling off the ladder with ripped up feet at 0'dark thirty.
    My thought was that any activity that required me to bottle my own urine probably stopped being fun about the same time I deployed my dick to do so.
  15. May 10, 2025 at 4:31 PM
    thomason84
    it was the bars and rails, slight side to side movement. Probably because of the soft washers ¯\_(ツ)_/¯
    My kayaks are heavy and long though. I thought about just getting stronger bars but decided to get a Sherpa Crestone instead.
