Roof Box Clearance above antenna?
Discussion in '5th Gen 4Runners (2010-2024)' started by Govbud NH, May 6, 2022.
  1. May 6, 2022 at 3:35 PM
    Govbud NH
    Govbud NH [OP] New Member
    jeff
    2000 4 runner
    expedition
    Just bought 2018 LTD and it did not come with crossbars. I plan on a roofbox, would there be clearance problems above the antenna? The OEM crossbars mount midway on the rails. If so, maybe raised Thule crossbars that mount around the rails would raise the box? Has anyone dealt with this?
  2. May 7, 2022 at 10:43 AM
    humble4r
    humble4r New Member
    2022 orp still stock
    I had to craft extra long “U” brackets for my model Thule and use small spacer blocks to clear the antenna. It’s only an inch that is needed so perhaps cross bars that sit above would work well instead of the factory ones I have.
  3. May 7, 2022 at 7:09 PM
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    I use a Thule MotionXT on the stock crossbars. The box *just* clears the shark fin, I mean it's like you could get a piece of paper in between. But several hundred, if not thousand or so miles with it on, and no problems.
  4. May 9, 2022 at 8:35 AM
    Govbud NH
    jeff
    2000 4 runner
    expedition
    Was driving up to Franconia Notch, NH on weekend and 4 Runner went by. (Maybe a forum member?) This would be next purchase. Any thoughts on which Thule box this was? A full length ski box is not needed. Just for gear and baggage. I see a full length rack however perhaps only clamp on Thule cross bars would work. Thanks for any suggestions and experience. I've searched internet and get that this is not a cheap setup (like the ebay knock 4 Runner Thule.jpg offs) Long term purchase so I'd like to do this right. Thanks
  5. Jun 30, 2022 at 11:14 AM
    Govbud NH
    jeff
    2000 4 runner
    expedition
    Just back from 3000 mile drive from NH to Alabama and back. Roof system by Thule works great all around. No clearance issues. Went with smaller box as older Thule ski box too long and low. Good for skiis but not camping gear.
    ChessGuy likes this.
  6. Jun 30, 2022 at 7:00 PM
    Beautiful color and so clean looking truck.
  7. Jul 1, 2022 at 5:36 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    Any cargo box long enough to handle snowboards, let alone skis, doesn't work very well with the factory rack because it will hang over the back far enough to interfere with the tailgate opening. The shorter pods are great for smaller gear though. BTW, rugged crossbars for the factory rails like Victory and LFD make give you more fore and aft positioning than the stock crossbars, plus lower the pod a bit more making it easier to load.
