Rock sliders 0 degrees or 20?
Discussion in '5th Gen 4Runners (2010-2024)' started by tekman, Sep 18, 2021.
  1. Sep 18, 2021 at 6:55 AM
    tekman
    tekman [OP] New Member
    Troy
    2021 4Runner
    N/A
    Looking to order a set of Wescott Designs Rock sliders for my new 4 Runner.
    Only question, which is more comfortable to use a 0 Degree, (Flat) or a 20 Degree angled set>
    I live in Missouri not Arizona, so not like I can go check them out.
    For those that have a set or similar, which do you prefer for comfort of stepping in and out? Mostly the stepping part is for my wife and kids since they are shorter than me.
    Thanks for your input.
    Troy
  2. Sep 18, 2021 at 6:59 AM
    If you want the best function as a step, the 0° sliders will be best. They'll sit a tad lower and further have more usable surface area to step on. That said, I have angled RSG sliders and they are ok to step on.
    Han4Run, DRobs, 7385 and 2 others like this.
  3. Sep 18, 2021 at 7:22 AM
    If using as a step is important, 0 degree.
    7385 and Thatbassguy like this.
  4. Sep 18, 2021 at 7:49 AM
    This is with the angled.
    tekman[OP] and 7385 like this.
  5. Sep 18, 2021 at 8:02 AM
    revans1009
    revans1009 New Member
    2021 TRD Pro Lunar Rock
    Those look like my schrockworks sliders. I don't need the step but my wife and kids all use it and haven't complained. For me, it provides just enough (barely) if I go toe-forward and I've found just turning my foot to the side (as if I were kicking a soccer ball) provides a more stable/suitable footing. I see comments stating to go flat if you want a more adequate step surface (great point). Another way to look at it is that unless you are doing a lot of off-roading, I am not sure there is a huge benefit to the angle. That's really intended to maximize clearance if I am not mistaken which is a nominal gain and may not be important. Other than those two points, looks would be the final factor. I chose the angled myself because I liked the sleeker look, seems just a bit more rugged in a sense. Really no other reason.
  6. Sep 18, 2021 at 8:19 AM
    tekman
    Troy
    2021 4Runner
    N/A
    Awesome feedback. Thanks, I think the flat is the best option. I won't off-road a ton.
  7. Sep 18, 2021 at 8:34 AM
    4R21
    4R21 New Member
    AK
    Land of Cheese
    Very Nice ! Maybe tires first for me :D :hattip:
  8. Sep 18, 2021 at 8:59 AM
    T4Rrunning
    T4Rrunning New Member
    What sliders are these? I think angled look better.
  9. Sep 18, 2021 at 9:02 AM
    They are RSG sliders.
    2Toys, Robruns and 4R21 like this.
  10. Sep 18, 2021 at 9:06 AM
    T4Rrunning
    Those look sweet. The only downside is the 6-8 week lead time :annoyed:
  11. Sep 18, 2021 at 10:25 AM
    Marchy
    Marchy New Member
    Sean
    Seattle
    2021 4 Runner Venture
    the downtime is a bit, however they are so soo worth the wait. I have the RSG 0 degree with top plate, I wanted/needed a step and I think they are perfect and have already saved a door :woot:
    5aCep6z-E3Ux9Npa52-etJNy8ac_qA44zg9-Fx-3_6048c46b2e37f12f5bb802a43fe532f583482730.jpg
  12. Sep 18, 2021 at 4:01 PM
    MAXIM
    MAXIM New Member
    My schrockworks angled and tucked in nicely while still plenty of room to serve as a step.
    -and-lt;-and-lt;-and-lt;-and-lt;-albums-_d9fb75e14680c81af209143d5501fa8ea221bbb7.jpg
    T4Rrunning likes this.
  13. Sep 18, 2021 at 4:09 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    Here is my Westcott design 20 degree. If you don’t off-road and want to use them as a step then I would get the 0 degree. I barely am able to step on them when getting in and out of the 4Runner when in the front. However, the rear allows for a good step in the back.
    2Toys, tekman[OP] and T4Rrunning like this.
  14. Sep 18, 2021 at 5:45 PM
    T4R13
    T4R13 New Member
    Clarksburg wv
    19 sr5p
    I have rsg flats. More practical if you have kids and a wife. Works great as a step. Unles your looking for every inch of clearance off-road I’d get flat ones. Imo Your likely to make contact with frame rails and body before the sliders with angled up. I’ve been in multiple situations where more than likely would have got into my lower doors and slid on my frame rails if I had the angled up vs the 0degree
    GodOfDirt, tekman[OP] and DRobs like this.
  15. Sep 18, 2021 at 6:16 PM
    can0nfan2379
    can0nfan2379 New Member
    Arid-zona
    2019 T4R ORP...2013 TRD OR DCSB Tacoma
    3D29F40C-EA06-4E5B-9ACA-C82CC473F73B.jpg BAMF sliders split the difference - 10 degrees
    tekman[OP] and Thatbassguy like this.
  16. Sep 18, 2021 at 7:12 PM
    EglSctAndy
    EglSctAndy New Member
    Andrew
    2021 Nautical Blue Venture Edition
    Wescott Designs Lift, Toyo AT3 285/70/17
    As others have said, if using as a step then the 0 degree is the way to go IMHO. I have the 0 degree Wescott sliders with top plates and I’m very happy with them. They look awesome and are very functional. They make getting into our lifted T4R much easier for my wife and kids.
    LostHusker and tekman[OP] like this.
  17. Sep 19, 2021 at 6:03 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    My Shrockworks sliders are flat 0Deg. I feel they offer more protection for my door panels off road vs angled.
  18. Sep 19, 2021 at 11:18 AM
    Zal4R
    Zal4R New Member
    ‘21 LR TRD Pro
    Eibach TRD Pro Springs RCI Skids
    I love my 0degree caliraised sliders. Kid uses them as a step, they hold up well off-road, have the kick out, etc. they are also local so I could just drive in and pick them up, which was nice.
    Thatbassguy, DRobs and tekman[OP] like this.
  19. Sep 30, 2021 at 10:14 AM
    T4Rrunning
    Reviving this thread. I am currently looking to orders sliders but man lead times are killing me haha
    Anyone know of a good slider that doesn't have crazy long lead times? I am in socal so it can be local too.
  20. Sep 30, 2021 at 10:31 AM
    beedee
    beedee Member
  21. Sep 30, 2021 at 11:43 AM
    ToddD
    ToddD New Member
    ATL
    2021 PRO LR
    https://heftyfab.com/collections/4runner-2010/products/2010-4runner-rock-sliders
    Sale may still be going on. Site says 8-10 weeks to be shipped. I was ok with this and placed my order. 1.5-2 weeks go by and I get a notification that they shipped. May be worth it to give them a call and see if they are still 8-10 weeks or if this has been reduced. I like them, they are heavy duty, and they flare out at the rear portion so it provides a good step for the kiddos.
    Keirik likes this.
  22. Sep 30, 2021 at 12:11 PM
    Just to add to this conversation, last week i had a vehicle ram into the side of me. I was going about 35-40 mph. I would say the sliders paid for themselves, the Mazda that hit me was not so lucky.
  23. Sep 30, 2021 at 12:45 PM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Call Shrockworks. I got the feeling they some in stock a year or 2 when I ordered mine from them. Mine shipped fast.
    https://www.shrockworks.com/5th-Gen-Toyota-4Runner-Rock-Sliders-2010-2019-pr-16256.html
  24. Sep 30, 2021 at 2:27 PM
    JayTD
    JayTD New Member
    Jason
    St. Louis
    2022 ORP
    I ordered a set of these heftyfabs based on your post mainly. Ordered on Sept. 9th hoping to have them for when my vehicle arrived. They shipped on the 23rd. I have them in my garage now and am still waiting for delivery of my 4runner. This is arguably the better position to be in!
    2Toys, DRobs and SlvrSlug like this.
  25. Sep 30, 2021 at 2:32 PM
    I wish you guys would STOP posting about your sliders. It makes me want a set. ;)
    If I was gonna get sliders, the 0 degree/straight out ones would be my choice.
  26. Sep 30, 2021 at 2:33 PM
    I think you need to just break out the 'ol cc and put in your order.
    7385 likes this.
  27. Sep 30, 2021 at 2:39 PM
    Well then explain it to my wife. ;)
    I think those Caliraised sliders look so cool on you guys rigs.
    2Toys, DRobs and 7385 like this.
  28. Sep 30, 2021 at 2:45 PM
    Show her my pic. of getting hit from the side with very minimal damage = sold.
  29. Sep 30, 2021 at 2:47 PM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I'd also try Caliraised.
  30. Sep 30, 2021 at 3:04 PM
    brownersd
    Sean
    Humble / Kingwood, Texas
    I vote Cali Raised as well. Ordered 31st May, 2021, and shipped 15th June, 2021. Great customer service from the team, because God only knows I had a million questions before biting the bullet.
    Cheers,
    Sean
    DRobs and Slopemaster like this.
