Road salt from hell
Discussion in 'General 4Runner Talk' started by djwantke, Dec 1, 2025.
  1. Dec 1, 2025 at 5:44 PM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I snapped photos today of an evil amount of road salt the spreader truck dumped in front of my garage.
    Share experiences with salt use & rust
    Han4Run and Shredder like this.
  2. Dec 1, 2025 at 5:55 PM
    Highways here in Nebraska are white from the salt put down with our 2" of snow. Wish I could get a good pic to post up.
    Shredder likes this.
  3. Dec 1, 2025 at 6:14 PM
    Salt? Snow? You mean it’s not sunny and 82 like it is here in Florida? I only have a month left here then I return home to the frozen tundra of Chicagoland
  4. Dec 1, 2025 at 7:05 PM
    Oh shit Bruce dont take it off the lot godamn salt crippling the entire environment
  5. Dec 1, 2025 at 8:26 PM
    Around here they use a liquid brine solution. Last year I was behind a truck that dispenses this brine. It sprays it out in a fan shape, enough to cover around a lane and a half width.
    Anywho, it was dispensing during the day, traffic was moderate on a 4 lane city road.. Traffic approached a stop light, where the truck stopped in one lane, and minivan right next to it.
    The truck’s dispenser was supposed to shut off while stopped, but not this time. It hosed the side of the poor minivan in a high pressure brine stream for 20-30 seconds until the light turned. I felt like I was witnessing the destruction of a vehicle. Poor vehicle probably drove home, parked, and had all the doors, and wheels immediately fall off.
    BS67, Turd Ferguson and djwantke[OP] like this.
  6. Dec 1, 2025 at 8:38 PM
    no way!
  7. Dec 1, 2025 at 9:05 PM
    Salt and ice melt sucks. It’s definitely going to kill my 4Runner long before the engine dies.
    Whammo and BS67 like this.
  8. Dec 1, 2025 at 9:28 PM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    ^^^Indeed, some people don't like the mess rustproofing makes.
  9. Dec 1, 2025 at 10:17 PM
    Way.
    It was bad. What I saw I can’t unsee.
  10. Dec 2, 2025 at 5:27 AM
    jwctaco
    S.W. Michigan
    23’ T4R
    Get it rustproofed, or DYI , rust never sleeps
  11. Dec 2, 2025 at 5:34 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    I thought it was the frozen battleground of Chicagoland ? ;)
  12. Dec 2, 2025 at 6:19 AM
    lol. Its a beautiful city. Amazing museums, attractions and food. They mayor is a moron but i love the city. Now that i think about it, the last time we went we ALMOST (really really close) got carjacked. Had my wife not noticed what was about to happen we would have been. Trust me, she reminds me at least 3 times a week that she saved my life. :)
    2Toys and Nick B[QUOTED] like this.
  13. Dec 2, 2025 at 10:28 AM
    I have been coating mine the last few years but you can’t get to every spot on the chassis. Then there’s all the fasteners and clamps that rust out. I just had an issue while changing the spark plugs where one of the nuts holding the air pump tube on turned to dust and rounded over.
    4onto[QUOTED] likes this.
  14. Dec 2, 2025 at 5:08 PM
    shooter1231
    shooter1231 New Member
    2023 Mag Gray 4Runner Limited
    Here they pre-treat the roads with beet juice. Then dump shit tons of salt and cinders on the snow ice. It's a goddamn mess.
  15. Dec 8, 2025 at 5:42 PM
    dadley
    dadley New Member
    Rust isn't a big deal who's gonna crawl under your truck and complain about how it looks you can fix anything including the frame who cares
    jwctaco and djwantke[OP] like this.
  16. Dec 8, 2025 at 5:53 PM
    leftyfire
    leftyfire New Member
    Michael
    Colorado Springs
    2006 Limited V6
    Cool story bro! Super sick pic in your avatar too!
  17. Dec 8, 2025 at 6:41 PM
    Your avatar is a dude from down under, so they start by looking at the frame for hidden drop bears upload_2025-12-8_21-44-1.png
  18. Dec 8, 2025 at 8:35 PM
  19. Dec 9, 2025 at 8:24 AM
    Yup. Not a big deal. I’ll just swap my rusty frame with a new one in my driveway some Saturday morning.
    Nick B likes this.
