River/water crossing in the back country - water leak?
Discussion in '5th Gen 4Runners (2010-2024)' started by Maxwell008, Jan 3, 2025.
  1. Jan 3, 2025 at 9:58 PM
    Maxwell008
    Maxwell008 [OP] New Member
    I'm looking to take my 2024 4Runner into the back country with a few other folks. They warned me that there may be some light river crossings, but nothing too crazy. Water levels may come up to the floor board height or maybe slightly higher.
    If this is the case, could water leak into the truck?
    Would be a pain trying to clean it all up after. Even worse, would hate for the water splash to make its way into the engine bay which could cause possible damage?
  2. Jan 3, 2025 at 9:59 PM
    Take a boat or find a bridge. Unless you’re willing to risk problems in the future.
    Imdav2u, LCJ77 and catbrown357 like this.
  3. Jan 3, 2025 at 10:19 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    At a minimum you’d want to have proper diff breathers installed. Stock breathers may cause water to be drawn into the differentials. Not expensive or difficult to do.
    Without proper breathers, after your trip you should plan on replacing the front/rear differential gear oil and replace the axle seals. You don’t want water sloshing around in the differentials.
    Breathers are cheaper.
    Saker, catbrown357 and Slopemaster like this.
  4. Jan 4, 2025 at 5:56 AM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    Front breathers are pretty high up as I remember, so you’re mostly worried about the rear…which isn’t even that big of an issue unless you spend a lot of time submerged or go through water that is cold.
    If you have an upcoming service, just have your diff oil changed then. It’s much cheaper at a dealer than local stand alone places, ironically enough.
    The only thing you really should worry about is making sure you don’t go to a level where the air intake is submerged.
    Also, don’t splash. Just go in nice and easy, and keep a steady speed.
    McSpazatron and icebear like this.
  5. Jan 4, 2025 at 6:24 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    If you're just going through the water and you're not parking in the water, then the seals on the doors are adequate to keep water intrusion out. I wouldn't want to linger in any water deeper than 2/3 up the wheels but going through it is no issue.
  6. Jan 4, 2025 at 7:31 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    That isn't deep enough to worry about anything but the splash. Splashing may get water into the engine bay, but not because of the water depth. Drive through the water under 10 mph and you'll be fine. The faster you go, the more splash. Go slow and steady.
  7. Jan 4, 2025 at 8:11 AM
    bassist
    bassist New Member
    Splashing, especially with mud, is how you end up with a clogged alternator or other sensors.
    Ask me how I learned this lesson!
  8. Jan 4, 2025 at 12:02 PM
    As long as you don’t crash into the water on entry, and as long as you maintain a slow steady speed, those depths are probably fine. Staying in the pocket behind the bow wave will help reduce the height of the water around the vehicle. Do the breather mod on the rear diff.
    The trick is maintaining your pace. But if you get stuck half way across…at those depths, you might be screwed.
    If nobody is sure about the underwater conditions, it’s probably be best if you and your buds are immediately ready help pull a vehicle at the first sign of trouble. That means having tow straps connected and at the ready on your vehicle, and somebody else willing to jump in the water to grab the strap and connect to a recovery vehicle that’s ready to go on shore. That will also require that you trust whoever may be pulling you out, because recoveries can be dangerous if you don’t know what you’re doing.
    Saker likes this.
  9. Jan 4, 2025 at 12:46 PM
    Typically the door seals will hold. The doors themselves take in water (through the drain holes). So your maximum fording depth is roughly the height of your door speakers.
    As others say, reroute your rear diff breather and avoid splashing. Pack a spare air filter along with the other parts and tools you normally take on wheeling trips.
  10. Jan 4, 2025 at 1:43 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
  11. Jan 4, 2025 at 2:02 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    I did this last March. One of a dozen-ish crossings. I do have the rear breather mod. It's a 10 min job. No issues at all. As you can see the water is to the bottom of the headlights. That's 37" deep. Keep the splashing to a minimum.
    nova and 3JOH22A like this.
  12. Jan 4, 2025 at 2:31 PM
    Forget about your floor boards. You need to make sure you don’t hydro lock the engine. And as others have said the diff breathers. Also remember 1 gallon of moving water has 6 pounds of force. Not trying to ruin your adventure but getting your floor boards wet would be my last concern.
  13. Jan 4, 2025 at 4:05 PM
    LetsTacoboutit
    Adobe
    ...And don't forget to make absolutely sure that your skirts/splash shields are 100% intact if you decide to ford that high.
  14. Jan 4, 2025 at 4:11 PM
    That’s an awesome picture. Do you have a snorkel? Anything you need to do to prevent hydro locking the engine? That’s such a cool picture. Nice job.
  15. Jan 4, 2025 at 4:22 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Not to derail the thread, but where did you run your diff breather ends? I'll be doing mine in the next couple of months and I'm debating going up to the engine bay vs the tail lights or gas nozzle. 10 min sounds like a quick job staying near the back
  16. Jan 4, 2025 at 6:05 PM
    bassist
    bassist New Member
    Close!
    A gallon of water weighs 8lbs - actually a little more. A pint weighs around a pound.
  17. Jan 4, 2025 at 6:42 PM
    Maxwell008
    Thanks...I don't think I will be going that deep...but that looks pretty wicked!
  18. Jan 4, 2025 at 6:46 PM
    Maxwell008
    Thanks... That is what I was hoping for. Hoping the door seals will hold. The water level will not be too high, it could reach the floorboard level at worst is what I am being told.
    I intend to go in and out as smoothly as possible. Not looking to do any Dukes of Hazzard's stuff thru the water.
  19. Jan 4, 2025 at 6:55 PM
    Maxwell008
    Thanks & well noted. I was told about this from my friends as well. Good callout!
  20. Jan 4, 2025 at 7:08 PM
    Maxwell008
    Looking at the ARB breathers right now...
    By the way...how many breathers do I need for a 2024 5th Gen? Also seeing a Youtube video where they talk about the 2 diff breathers, transfer case & transmission breather? (ugh...).
    looks like I'm going down a rabbit hole....
    djwantke likes this.
  21. Jan 4, 2025 at 8:38 PM
    bassist
    bassist New Member
    If you haven’t noticed, videos often exist to convince you that you need to spend a stupid amount of money on things.
    Just remember that while mods produce some benefits, the cost/benefit analysis may not pay off, especially if you think about the potential for issues with your mods.
    Your front diff already has a breather placed high enough that you aren’t going to have an issue there before you get another issue.
    I forget what’s going on with the transmission, but look at the instructions - if you are modifying your transmission in any way, you need to seriously ask yourself if preventing all the stories you’ve heard of transmission failures are worth the potential for a denied warranty claim.
    And if you haven’t heard a bunch of stories, then perhaps it’s a solution in search of a problem.
    MeefZah likes this.
  22. Jan 5, 2025 at 4:50 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    You'll be fine. Of the approximately one million water crossings* I've done I've never had an issue. I also don't / didn't do the breather mod; again, for short duration submersion you'll be fine. Don't overthink it and just do it.
    *probably slightly higher than actual number
    https://youtu.be/-fVw9N4T6aI?si=jkhUH4Gn4WThBLF2
    bassist likes this.
  23. Jan 5, 2025 at 5:09 AM
    Startrek
    Startrek New Member
    airbag computer under center console. once you get water level inside cab on a floor, vehicle totaled. when water gets once inside frame, life expectancy of the vehicle dwindles down.
  24. Jan 5, 2025 at 6:27 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    The frame has probably a hundred places for water ingress (and egress) and water gets in there (and out) under normal operation like driving in the rain. I would make a similar argument to yours in that once you start the truck the first time the life expectancy goes down, too....
    bassist and Acesandeights like this.
  25. Jan 5, 2025 at 9:31 AM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    No, I do not have a snorkel.
    I ran the hose up the gas filler tube as far as it would go and zip tied it. Leave a 4-6" loop near the breather so the hose doesn't get pulled out under full droop. Here's the breather stud I used. Then get any 1/4" gas line hose.
    https://www.toyotapartsdeal.com/oem/toyota~union~no~4~90404-51026.html
  26. Jan 5, 2025 at 1:23 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Anyone else read that? There's nothing you need to do OP, but have a good time.
  27. Jan 5, 2025 at 2:39 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    Thanks, I've got hose from the ARB kit but need to see if I need anything else. I'll be running a breather for the locker too so will probably need a "T" at the very least.
  28. Jan 5, 2025 at 4:41 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    Yeah, with a locker you'll need a "T". I don't have a locker and forgot about it.
    This guy did the breather mod the right way. (i.e. more $$)
    https://www.youtube.com/watch?v=1MFW8YK9dx0
  29. Jan 6, 2025 at 6:03 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    So you're saying 1 gallon of water exerts 6lb force regardless of how fast it is moving? I find that interesting. If you put a gallon of water on a scale, it weighs 8.3lb...
  30. Jan 6, 2025 at 5:28 PM
    I think it makes more sense to say a gallon of water weighs around 8 pounds, at rest, meaning it’s to say it’s a dense liquid (which is non-compressible). Because of this, you need to enter it slowly enough to allow the water to flow around the vehicle. If you hit water at high speed, it will act like a dense, massive solid for a split second which can easily break plastics and bend metal. Once in the water, going too fast can also bend/break things through hydraulic forces. Point being, the combination of water and speed can break things.
    nova and Stoney Ranger like this.
