Replacement rims and tires questions
Discussion in '5th Gen 4Runners (2010-2024)' started by Tikka556, Nov 29, 2025.
  1. Nov 29, 2025 at 5:37 AM
    Tikka556
    Tikka556 [OP] New Member
    I found some new 17" TRD PRO style replica wheels with Falken Wildpeak 265/70R17 All Terrain tires.
    The Wheel size is 17x8 with offset +5 and 6x139.7 bolt
    My questions are will these fit and sit the same as my stock oem wheels and tires on my 2020 4 runner? I wasn’t sure the offset in stock 4Runners …. Also are AGP replica rims gtg? Thank you.
  2. Nov 29, 2025 at 5:53 AM
    The stock wheel offset for a 5th Gen 4Runner varies by trim, with the standard model (including SR5 and TRD Off-Road) being +15mm and the TRD Pro being +4mm. These differences can be seen in how far the wheel sits relative to the fender, with the TRD Pro wheels sitting about 11mm further out.
  3. Nov 29, 2025 at 7:04 AM
    Tikka556
    I have a 2020 SR5 premium 4x4
  4. Nov 29, 2025 at 7:36 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited
    OME Nitrocharger struts and shocks. OME 884X front springs, OME 889X rear springs, full RCI skids, RCI roof rack, RCI sliders with kickouts, Method Racing MR306 Mesh wheels.
    Might be time to educate yourself on wheel offset.
  5. Nov 29, 2025 at 5:36 PM
    Tikka556
