Replaced rear passenger outer door handle replaced but doesn't open door
Discussion in '5th Gen 4Runners (2010-2024)' started by ScottRoxxx, Jul 21, 2025.
  1. Jul 21, 2025 at 6:50 PM
    ScottRoxxx
    ScottRoxxx [OP] New Member
    Scott
    2015 White Ltd
    none
    So my dog managed to break off the rear passenger door handle. I followed a youtube video and replaced the handle, making sure it actuated the latch inside. Everything looks right, but it does not open. I took off the drivers side to make sure everything looked the same and it does. When I put it in park I hear three loud clicks from the affected door. What did I do wrong?
  2. Jul 21, 2025 at 7:24 PM
    DJ022
    DJ022 New Member
    Dylan
    2019 4Runner TRD Off-Road
    I know you said you made sure all the cables/latches were actuated and installed correctly and that it looks the same as the other door, but there’s gotta be something wrong with the install.
    did the door lock/unlock regularly before replacing the handle? The three loud clicks makes me wonder if somethings is wrong with the actuator. OR the door handle is not connected to the actuator correctly
  3. Jul 22, 2025 at 8:03 AM
    if you've checked and double checked everything my guess is a defective part. Is it OEM or aftermarket
  4. Jul 22, 2025 at 11:27 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Checked to make sure child safety lock didn't get flipped on? I don't think that would result in the clicking but may explain why it appeared to work and now it won't open from the inside. Does it open from the outside?
    icebear and Slopemaster like this.
  5. Jul 24, 2025 at 11:00 AM
    ScottRoxxx
    Scott
    2015 White Ltd
    none
    It does not open from either side
  6. Jul 24, 2025 at 11:24 AM
    welcome. agree on the physical connection checks. it's a mechanical part, so it's either working or not.
