Removing rockers leaves parts exposed
Discussion in '5th Gen 4Runners (2010-2024)' started by Cricky623, Nov 27, 2020.
  1. Nov 27, 2020 at 12:30 PM
    Cricky623
    Cricky623 [OP] New Member
    Ricky
    2010 4runner sr5
    Hi guys, I’m new to the 4runner family, long time mustang guy who is trying to get into some off-roading. I recently purchased a 2010 4runner sr5 4x4 and one of the first modifications I did was buy some running boards. I was installing them today and it’s mostly done, but the hiccup I came across was that when you take the bottom rockers you off, it leaves a part of the fender flare uncovered, and it leaves the section below the doors looking unfinished, do they make some sort of cap to remedy this? Do they make a prepainted one? Any help with products and links would be appreciated, thank you and I’m loving it so far.6AD59247-8002-4ED4-A085-A1AF691A23B6.jpg
  2. Nov 27, 2020 at 12:36 PM
    Dark Knight
    Dark Knight Get off my lawn
    Shrockworks makes a filler plate.
    Doglover2003, 7385 and SlvrSlug like this.
  3. Nov 27, 2020 at 1:03 PM
    welcome
    7385 likes this.
  4. Nov 27, 2020 at 5:50 PM
    Have you done a search for that particular Toyota rocker panel part for a 2010 Off Road model? That would replace the rocker panel you removed from your SR5 in order to install the rails, and would install in its place. There is also a cap for the end of the fender flare.
    This video on YouTube shows someone converting a later Limited to the Off Road rocker panel, which is basically exactly what you want to do on your 2010:
    https://www.youtube.com/watch?v=6xQ7bPfIOSw
    And this video shows the replacement fender end cap:
    https://www.youtube.com/watch?v=xCoBS-RRbs0
    Thatbassguy and Cricky623[OP] like this.
  5. Nov 27, 2020 at 5:59 PM
    4Runner170V
    4Runner170V New Member
    Tony
    Los Angeles
    2014 4Runner Trail
    Is this SR5 limited?
  6. Nov 27, 2020 at 6:03 PM
    Cricky623
    Ricky
    2010 4runner sr5
    It’s an sr5, and thank you guys for all the responses, really appreciated
  7. Nov 27, 2020 at 8:35 PM
    The earlier 5th gen SR5 had the same type of rocker panel trim as the Limited until 2014, I believe.
  8. Nov 28, 2020 at 7:26 AM
    Seapablo
    Seapablo New Member
    seattle
    5th gen limited
    Eibach pro lift, shrockwork rock rails, method wheels, 285/70/17 Nittos
    Schrockworks makes a rocker panel cover...I bought one for my 2012 limited.upload_2020-11-28_7-25-8.jpgupload_2020-11-28_7-26-23.jpg
  9. Nov 28, 2020 at 2:16 PM
    Cricky623
    Ricky
    2010 4runner sr5
    does this cover the bottom part of the fender flare? Or is that the separate piece people are talking about on here
  10. Nov 28, 2020 at 3:36 PM
    Seapablo
    Seapablo New Member
    seattle
    5th gen limited
    I comes with a separate cap that covers the end of the fender flare.
  11. Nov 28, 2020 at 3:38 PM
    Cricky623
    Ricky
    2010 4runner sr5
    Great, thanks!
  12. Nov 29, 2020 at 5:45 PM
    Oh, good to know! I may need this if I decide to take the mudflaps of my 2013 Trail, they're built into the bottom of the flare so it looks like it will have a similar result.
  13. Nov 29, 2020 at 5:46 PM
    OP, I don't know if rust is a problem in your area, but with the trim off and those holes exposed, it would be a great time to spray the heck out of the inside of the rockers with fluid film or some other rust preventative.
  14. Dec 2, 2020 at 4:14 PM
    Cricky623
    Ricky
    2010 4runner sr5
    I didn’t even think of that, thank you! I live in New Jersey so yeah I’m right in the middle of the salt belt
  15. Dec 2, 2020 at 4:29 PM
    I'm kind of inspired, maybe I should try to pull mine off this weekend and do the same.
    Last season I sprayed a bunch of WD-40 in the bottom of all four doors and hatch, I should do the same with the rockers when I hit them again this season.
