Removing excess brake fluid from Reservoir!
Discussion in '5th Gen 4Runners (2010-2024)' started by Lc200, May 24, 2024.
  1. May 24, 2024 at 5:34 PM
    Lc200
    Lc200 [OP] New Member
    Pre Facelift SR5P
    Hey folks,
    I noticed today that my brake fluid level is quite a bit over the max line. The fluid is new since I changed it last year when I got my brakes done.
    What's the best way to remove the excess brake fluid from the reservoir?
    I have been told use turkey blaster, dip paper napkin, small pump etc etc.
    Also, is it really that simple as opening the reservoir, removing excess and closing it? No air would enter the system like this?
    Thanks
  2. May 24, 2024 at 5:59 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Use a clean turkey batter…
    Or bleed the lines
  3. May 24, 2024 at 6:08 PM
    Lc200
    Pre Facelift SR5P
    I have a few brand new ones lying around.
  4. May 24, 2024 at 6:09 PM
    Yep it’s as simple as you think.
    Turkey baster, syringe, or by the spoonful if you so wanted.
    Open reservoir, remove, then close. Just don’t keep it open longer than you have to.
    Or bleeding works too.
    Lc200[OP] likes this.
  5. May 24, 2024 at 6:13 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    A turkey baster will work fine, no risk whatsoever of getting air into the system....unless you remove too much and leave the reservoir empty.
    There is one caution however, avoid getting any brake fluid on the paint, it can damage paint, if you do by chance get some on the paint clean it immediately with soapy water.
    SlvrSlug and Lc200[OP] like this.
  6. May 24, 2024 at 6:26 PM
    Lc200
    Pre Facelift SR5P
    Got it!
    I am going to cover the area with rags and have soapy water on hand.
    With my dexterity, I know I would be spilling that thing all over my bay and fender.
  7. May 24, 2024 at 6:55 PM
    like2lean
    like2lean New Member
    A straw works well too.
    Photon_Chaser and Lc200[OP] like this.
  8. May 24, 2024 at 8:22 PM
    Big syringe with rubber tube works good plus you don’t have to worry about spilling as much unless of course you hit the plunger. ;)
