Removing Door Sill Trim
Discussion in '5th Gen 4Runners (2010-2024)' started by Chucklehead, Sep 29, 2021.
  1. Sep 29, 2021 at 4:46 AM
    Chucklehead
    Chucklehead [OP] Enjoy the ride! You only get one trip
    Fort Wayne, IN
    2021 4Runner Black TRD ORP
    Stock AF, with subtle personality tweaks
    Hey 4Runner community - has anyone removed the door sill trim on front and rear of a 5th Gen?
    If so, are there any 'tricks' or 'gotcha's' waiting in that process? Typically, these are just on with pound in friction clips that pop off when pulled/pry straight up but trim can sometimes have a lateral sliding component to them to come off.
    So before I went about it thought I'd ask the community first to try and avoid dickin up my new vehicle trim with guess work...
    Thx much all!
  2. Sep 29, 2021 at 6:15 AM
    Matt83
    Matt83 New Member
    Northeast
    See below
    kcunvong, Okc4runner and A&P like this.
  3. Sep 29, 2021 at 6:34 AM
    Chucklehead
    Fort Wayne, IN
    Hey Matt83 - thank you kindly sir!!!
    looks like it's held on to withstand gorilla use - wow
  4. Sep 29, 2021 at 6:39 AM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    It prys right up and off. Some popping sounds come with it but that’s all. Start on one end and work your way down. Takes about 30 seconds (that was my experience pulling the drivers door trim)
  5. Aug 21, 2022 at 12:04 PM
    Hans Moleman
    Hans Moleman New Member
    SF Bay
    I tried to remove my door sill cover and it’s like it glued on the outer edge. I guess I will try prying with a screwdriver like mentioned above.
    How’re the clips on the inside edge came undone easily when I pulled.
  6. Aug 21, 2022 at 5:51 PM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    Don't use a screwdriver. Get some plastic trim tools.
  7. Aug 21, 2022 at 6:18 PM
  8. Aug 21, 2022 at 7:57 PM
    Cowboy59
    N. Florida
    So you don't accidentally scratch up any paint. Also if you start at the front of the moulding you can just pry it up by you hands. Pull straight up, don't pull to the side or you risk breaking the tabs.
    Check out this video. While it is for installing a break controller, it shows how to remove the door sill plastic piece.
    https://www.etrailer.com/Trailer-Brake-Controller/Redarc/RED44FR.html
