Removing Black Badge Overlays
Discussion in '5th Gen 4Runners (2010-2024)' started by SCMountaineer, Nov 27, 2025.
  1. Nov 27, 2025 at 2:48 PM
    SCMountaineer
    SCMountaineer [OP] New Member
    Upstate South Carolina
    On my fourth 5th gen-- white 2024 TRD Off Road Premium
    None yet
    I don't like the black overlays on the "4Runner" and Sombrero on the rear of mine...I know those are just stuck on with 3M tape, has anyone removed them and found the original chrome below NOT ruined? IMG_1220.jpg
    siblue, Mr.DRZ and werlyb23 like this.
  2. Nov 27, 2025 at 2:59 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Watching thread, good question, dito
  3. Nov 27, 2025 at 3:05 PM
    Hulksquatch
    Hulksquatch New Member
    SR5 Premium
    None….yet
    Yes! I pulled them off gently on a warm day. Used my fingernails to get most of the tape sticky off, then put goo-gone on a paper towel and blotted it. Took a bit of time, but it’s good as new now. Be sure to wash the area afterwards as per the instructions.
    werlyb23 likes this.
  4. Nov 27, 2025 at 3:12 PM
    SCMountaineer
    None yet
    Great! I was hoping that would be the case, but didn't want to dig in blind.
  5. Nov 27, 2025 at 3:19 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Gently warm them with a heat gun first. The tape on them is very thin compared to regular badges. Should be able to pop them off and clean up any residual adhesive.
    Mr.DRZ and SCMountaineer[OP] like this.
  6. Nov 28, 2025 at 5:37 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    We bought wifey a gorgeous pre-owned Toyota Certified 2023 RAV4 XLE Premium Hybrid AWD last month. Only bad thing about it, it had those black overlays on the emblems. She wanted them gone.
    Second day of ownership I took them off. I used my heat gun to warm them up just a bit. They pulled off rather easily. I used mineral spirits (sparingly) to clean the gummy residue off. Looks great.
  7. Nov 28, 2025 at 6:24 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Should look like new after you take them off. Definitely do in warmer weather and heat them up.
  8. Nov 28, 2025 at 9:18 AM
    SCMountaineer
    None yet
    Took about an hour, but I got them off! (Except the sombrero, that's a job for another day, my fingers are raw.)
  9. Nov 28, 2025 at 12:35 PM
    Mach141
    Mach141 New Member
    Great question...ill be doing this too. Apparently someone installed them on a leased vehicle, which is what i bought. I prefer the chrome. Although the blacked out center front emblem is starting to grow on me...
    BTW, cool license plate
  10. Nov 28, 2025 at 12:51 PM
    SCMountaineer
    None yet
    Thanks! I wish my state offered a black background with white letters like so many other states seem to now. Tip for when you remove yours--let the car sit in the sun so they are nice and warm. That and a hair dryer were enough for me--I didn't trust myself with a heat gun! Be careful that you don't accidentally pry up the chrome letter below. Once you get a corner of the black part loose, carefully grab it with some needle nosed pliers and pull gently with one hand while you hold the chrome letter down with the other. I used a credit card to scrap off as much of the leftover adhesive as I could, and used Goo Gone on a microfiber towel for the rest.
    Mach141[QUOTED] likes this.
  11. Nov 28, 2025 at 1:32 PM
    Mach141
    Mach141 New Member
    How does one get a 3 digit plate
  12. Nov 28, 2025 at 2:58 PM
    SCMountaineer
    None yet
    In my case, I just requested it like any vanity plate. But where I grew up, the governor handed out the first 1000 numbers, and because my stepmother worked in the government, one of our family cars had #541. That car got handed down to me as my first one, and when I moved here I requested the same number.
  13. Nov 28, 2025 at 10:25 PM
    You mentioned in your other thread that these were port installed. Are you sure they're overlays?
  14. Nov 29, 2025 at 8:30 AM
    SCMountaineer
    None yet
    They were....granted they were installed a lot better than the overlays I did myself on one of my last ones.
