Removable Rear lights
Discussion in 'Lighting' started by Ripper238, Jan 22, 2023.
  1. Jan 22, 2023 at 11:10 AM
    Ripper238
    Ripper238 [OP] New Member
    2019 TRD OR
    I got a pair of Baja cornering lights for setting up camp and backing down narrow roads if needed. I mounted them to a magnetic mount so they can be placed in a few locations or rotated.
    The magnetic mount can hold 55+lbs
    And with the quick release i can move the lights around or disconnect and move them to the front of my 4R and use them as added ditch lights.
    I can rotate these forward and use them as added light forward from the back since they are super bright. So incredibly versatile, I am glad I went with the magnetic mount and the super small bright Baja's.
    Baja SAE's look nice too:
    SAE's I also decided to split them yellow high white low. Better for ground illumination as white and less harsh and better fog performance with yellow higher.
    Added Baja S2 ditch lights to the front. Bad pic but you get the idea.
  2. Dec 17, 2024 at 7:20 AM
    Ripper238
    2019 TRD OR
    Apparently the rear ditch lights can also be used as a Police countermeasure:
