Remote start stopped working
Discussion in '5th Gen 4Runners (2010-2024)' started by HiddenShah, Jan 8, 2025.
  1. Jan 8, 2025 at 6:51 AM
    HiddenShah
    HiddenShah [OP] New Member
    Hey everyone,
    I have a 2024 4Runner TRD Pro with the factory remote start. I use the remote start occasionally (from the fob) and it has generally worked ok. However, last week it just ... stopped working. No matter how many times I try, I can't get it to trigger.
    Has anyone experienced this? Any tips or suggestions on what could be wrong? I have seen some posts on Reddit and other places mention that its unreliable, but nobody seems to have a fix for it.
  2. Jan 8, 2025 at 7:25 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Clearly this is a warranty problem. Take it to the dealer and let them figure it out.
  3. Jan 8, 2025 at 8:03 AM
    orcking
    orcking New Member
    Same thing happened to my 2020 limited
    Install the Toyota app, you have to agree to the free 10 years subscription of the Toyota service (forgot the exact name) and agree to data sharing with Toyota, and it will work again from the Fob....
  4. Jan 8, 2025 at 8:11 AM
    HiddenShah
    Are you sure about that? I never did that before and it worked for about 10 months just fine even without that.
  5. Jan 8, 2025 at 8:25 AM
    Imdav2u
    23 TRD PRO
    Mine works, but I also have the app. It's been great having the remote start. This morning it was 14° with a feel like temperature of 7°.
  6. Jan 8, 2025 at 8:28 AM
    orcking
    orcking New Member
    100% I used my remote for 4 years no issues and I had to do that lately as it stopped suddenly like yours....
    You do not need the app after you agree......
    The sub is called "service connect"...
  7. Jan 8, 2025 at 8:32 AM
    HiddenShah
    Interesting, ok I will look into that. Thank you.
  8. Jan 8, 2025 at 1:38 PM
    scanny
    scanny New Member
    Ontario, Canada
    I remember I wanted to start my truck remotely at airport parking when I was back from vacation in airport and app told me that function is disabled after I think 5 days if vehicle was not running. So I think if you didn't use you truck in few days keyfob remote start might not work as well until you start vehicle manually. Another thing is maybe battery in keyfob got depleted enough to make signal weak for remote start. But yes, since it's a new truck you can ask dealer to look at it, maybe it need new firmware or some settings got reset somehow.
  9. Jan 8, 2025 at 1:40 PM
    Did you happen to adjust any of the settings on the remote? That often seems to disable the remote's ability to lock/unlock the doors.
    djwantke likes this.
  10. Jan 8, 2025 at 5:31 PM
    Imdav2u
    23 TRD PRO
    We were in The Keys for 8 days before Christmas, when we landed it was 25° , I used the app to start my truck, no problems. Take it to the dealer, it's under warranty.
  11. Jan 8, 2025 at 8:56 PM
    KENTUCKYRUNNER
    KENTUCKYRUNNER New Member
    2006 sport to a2016 SR5 PREMIUM TO A 22 LIMITED
    i did that, but it still doesnt. i did get all my information back on the app tho
  12. Jan 9, 2025 at 7:43 AM
    The Pro version got the remote start from the fob (rather than from the app)?
    I'd like to have that on my ORP.
  13. Jan 9, 2025 at 7:47 AM
    orcking
    orcking New Member
    Post 2019.. even the fob goes through the same module as the app.. hence, the need to allow data sharing with Toyota otherwise the fob would not work..
  14. Jan 9, 2025 at 7:49 AM
    Foo.
    I'd really like to have remote-start from the fob, but I don't want Toyota and the cloud in between.
  15. Jan 9, 2025 at 12:35 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Interesting. My '22 ORP (Canadian) has factory fob remote start. I have no app on my cell no service connect or data sharing. Got to get lock button timing right though. Press, press, hold. It's a little finicky that way. Otherwise no issues. Subscription based features are a no go for me. If it's built with it. It needs to work period.
    vthoky likes this.
  16. Jan 9, 2025 at 12:47 PM
    Totally with you on that.
    JR7 and djwantke like this.
  17. Jan 9, 2025 at 12:50 PM
    summer breeze
    summer breeze New Member
    JOE
    2021 LIMITED
    i can not get app to connect in vehicle, mine does not work 2021 limited
  18. Jan 9, 2025 at 1:19 PM
    My 2022 limited can remote start with fob only. App is not set up on mine.
  19. Jan 9, 2025 at 1:27 PM
    AE1M
    AE1M New Member
    Bob
    2024 TRD Off-Raod Premium
    No kidding, called Off Road PREMIUM but no app or fob function to remote start.
    vthoky[QUOTED] likes this.
  20. Jan 9, 2025 at 1:57 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Man I’m happy I have a 2016, no app, and never returned to the dealer LOL
    And I thought I was quite inconvenienced this week solely cuz my key fob battery is dying haha
  21. Jan 9, 2025 at 1:59 PM
    Same here. No app for 2019, and don't miss it for a second.
    djwantke[QUOTED] likes this.
  22. Jan 9, 2025 at 2:02 PM
    I simply unlock and lock the whole truck with the rear hatch key slot, it’s one of the fancy features that sold me lol. I’m a simple man. I’ll Replace the fob battery, one day.
    Saker likes this.
  23. Jan 9, 2025 at 3:39 PM
    JR7
    JR7 New Member
    2021 TRD ORP
    Do the 21's have this same option? I downloaded the app at one time after purchase and just quit messing w/ it. Too much BS for just one feature in my opinion. Seats heat up fast enough for the wife...
  24. Jan 10, 2025 at 5:43 AM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    Read what you are agreeing to (Master Data Consent from Toyota). From Toyota Connected Services Privacy Notice:
    After instances of Toyota denying warranty for driving 85 mph , do you want them to have that data?
  25. Jan 10, 2025 at 9:21 AM
    orcking
    orcking New Member
    I agree with you.. however, it is the data age.... and if you want to have technical gimmicks you have to do that sometimes..
    I agree that the remote fob should have nothing with the external system, but unfortunately it does.....
    https://www.thedrive.com/tech/43636...tart-subscription-plan-after-massive-blowback
  26. Jan 10, 2025 at 1:05 PM
    STrooper
    STrooper Let’s Go Places!
    My friends 4Runner remote start stopped working as well. He removed the glovebox to get to the module, he unplugged it and replug, no issues ever since. It may be a simple solution as that.
  27. Feb 5, 2025 at 5:36 PM
    kjhgr01
    kjhgr01 New Member
    I have a 2023 Limited (purchase in Nov 2022) and I recently lost the remote start too. It worked even after I stopped paying for the Vehicle tracking subscription. In November 2024 I lost all access to my remotes, I had to plug a OBD2 dongle to reconnect my 2 remotes. I was able to unlock the doors by touch but not with the key fob buttons, somehow the key fob got turned off. I bought Vehicle tracking subscription for a month for a 3k miles road trip but I just noticed today that my remote start does not work anymore... really weird.
  28. Feb 6, 2025 at 5:26 PM
    kjhgr01
    kjhgr01 New Member
    I had that done but I turned off the location tracking to Never... I switched it back to when I use it and it restarted working all the sudden.
  29. Feb 7, 2025 at 3:26 PM
    TheGreekFreak
    TheGreekFreak New Member
    I tried using the remote starter for the first time this week and it didn’t work. Dealer is nearby so I stopped by.
    Guy just went into my Toyota app and I think he unselected/reselected the remote start service. It magically started working. He said alot of them are finicky and glitch all the time, even on the newer models.
    Really hate this Toyota connect bullshit. I purposely bought a 4Runner so I don’t deal with tech nonsense. Hope it doesn’t become a recurring issue or I’m just gonna throw in an aftermarket one down the road.
    Zero chance I’m paying a subscription for using a feature in my car.
  30. Feb 9, 2025 at 11:34 AM
    SilverRunner5ive
    SilverRunner5ive New Member
    2019 Silver SR5
    What's the method of locking/unlocking with with the rear hatch?
