Recording of gear noise, plus Gear oil smell.
Discussion in '5th Gen 4Runners (2010-2024)' started by RFB, Nov 20, 2022.
  1. Nov 20, 2022 at 8:32 PM
    RFB
    RFB [OP] New Member
    Jailbreak
    2019 trd pro
    metaltech slider, front bumper 4 in lift UCA/LCA panhard
    Take a listen see if you agree its the new rear ring and pinion. Please comment here as video is unlisted. Thanks
  2. Nov 21, 2022 at 5:53 AM
    Dobinson IMS Warn Bumper CaliRaised Sliders 265/70 K02s
    I’m no expert in gears, but that doesn’t sound like a noise that gears would make. My stock diff makes a tiny sound at around 60 mph on light throttle, but the noise is clearly a whine. In your situation, it almost sounds like something is rubbing or grinding.
    About the gear oil smell, is the smell “renewed” every time you drive it? If the smell gets worse every time you drive it, maybe they routed a breather into the cab? I’ve heard some people routing it into the cubby where the bottle jack is, unfortunately, that makes the inside stink. The other possibility is that a messy mechanic got some gear oil inside the cab when working on it, and the smell is lingering.
    Good luck, and keep us updated.
  3. Nov 22, 2022 at 9:17 AM
    RFB
    RFB [OP] New Member
    Jailbreak
    2019 trd pro
    exactly what im hearing is exactyly what he describes in first 60 seconds of video. never had noise get new gears fr/rear and suddenly after 2500miles i have noise. https://www.youtube.com/watch?v=KwoMUejhs_Q&t=22s
  4. Nov 22, 2022 at 5:42 PM
    I agree, it sounds similar to that vid. And I learned something new because I didnt know that’s what bad lash sounds like.
    Hopefully the place that did the install or who provided the differential will fix this for you. It’s definitely not right.
    But what’s up with the gear oil smell?
  5. Nov 22, 2022 at 7:20 PM
    RFB
    RFB [OP] New Member
    Jailbreak
    2019 trd pro
    well the second I started that video I said thats it, and I drive custom builts by me a lot this truck was at 17 in april its at 53k now not even a year, and i listen and pay attention the gear oil smell well i cracked it open this morning in MOAB and she was cold as ice and spiled quite a bit. I know the installer will make good. I just want it done with.
