Recommended Running Boards
Discussion in 'New Member Introductions' started by Sgt Bob, Jan 28, 2024.
  1. Jan 28, 2024 at 6:00 AM
    Sgt Bob
    Sgt Bob [OP] New Member
    Bob
    2024 4Runner Limited
    I just bought a 24 4Runner Limited. It came without running boards. Can someone recommend something of quality for a decent price or should I just buy from Toyota?
    Thank you in advance and it's nice to be here...
  2. Jan 28, 2024 at 6:15 AM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: Hefty and Bud Built. Tires: KM3. Switchpro.
    Check your local Facebook marketplace, etc. - Plenty of people remove them when they install sliders as part of preparing a rig for off-road usage.
  3. Jan 28, 2024 at 6:06 PM
    DesertSurfer
    Welcome to the forum!
  4. Jan 28, 2024 at 6:21 PM
    They don't fit a Limited.
    Limited requires a special part that has longer arms.
  5. Jan 29, 2024 at 2:26 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    Since you purchased the limited I would just get the ones that are for that model from Toyota. There are a few options out there but if you don’t have any build plans to make it an off-road warrior or have specific requirements stick with OEM and forget about it.
  6. Jan 29, 2024 at 3:02 AM
  7. Jan 29, 2024 at 3:06 AM
    Welcome from Wisconsin!
  8. Jan 29, 2024 at 8:18 AM
    shooter1231
    shooter1231 New Member
    2023 Mag Gray 4Runner Limited
    Welcome. I've got a 2023 4Runner Limited - so looked at all the stuff your thinking about a year ago when I got my 4Runner. I had Toyota running boards installed on my 4Runner a couple of weeks after I bought it. There are two choices when it comes to Toyota OEM running boards that will fit the Limited. The Limited has an extra trim panel below the doors that the other trim levels do not have. This requires special longer running board mounting brackets in order to get the running boards below this extra trim panel. Toyota p/n PT925-89110 is the normal Limited running board kit - black running boards with black rubber surface on the top. Edge of the running board has a chrome detail on it. PT925-89190 is the p/n for the Nightshade version of the Limited running board kit. Running boards look and fit identical - only difference is the Nightshade version are all black - no chrome strip on the edge of the running board - same black rubber surface on the top of the running boards. I had the Nightshade version of the Limited running boards installed on my 2023 Limited - just liked how they looked better. I can also tell you that both of these Limited running board kits are compatible with Toyota OEM mudguard kit PT769-89110 - they can be installed without interference with these mudguards - I have had the PT925-89190 Nightshade running boards and the PT769-89110 mudguards on my 2023 Limited for about a year with no issues. I originally wanted something like the Toyota Trail running boards - I had these on the Tacoma I had before the 4Runner and I liked them. Toyota doesn't offer a Trail running board with the Limited compatible longer mounting brackets. However, after getting the Limited Nightshade running boards installed I discovered I liked them better. The Limited running boards both have a grippy/rubbery material on the surface you step on. The Trail running boards are covered in a more slick plastic material. I never had an issue with the Trail boards on my Tacoma - but I do prefer the non-slip rubber material on the Limited boards.
    2018 Limited likes this.
  9. Jan 29, 2024 at 8:44 AM
    ATL4R
    ATL4R New Member
    2024 Limited
    I also recently purchased a ‘24 Limited. Though mine came with chrome edge running boards, I’ve used the following Toyota dealer’s parts and accessories site for other things:
    https://autoparts.mariettatoyota.com/
    They seem to have good prices and free shipping over $75. Could be a good option if you opt for OEM running boards.
  10. Apr 14, 2024 at 7:47 AM
    MENINBLK001
    MENINBLK001 New Member
    Peter
    2023 Toyota 4Runner Limited
    I just bought a 2023 4Runner Limited.
    It also came with the Chrome Edged Toyota Running Boards (PT925-89110).
    I DON'T HAVE THE ROOM TO PUT MY FOOT ON THEM !!!
    Is there any way to adjust the running board position so they sit farther out or a little lower than the bottom of the door?
    I am also looking at a set of iBoards IB20RIG4A.
    These are supposed to fit the Limited with the extended rocker panels.
    They claim they hold up to 500 lbs. also.
    Thanks in advance !
  11. Apr 14, 2024 at 1:36 PM
    DesertSurfer
    I have the Predator steps that came with the truck, they’re very sturdy but expensive. I see lightly used ones on Craigslist all the time for $250-300.
    MENINBLK001 likes this.
  12. Feb 21, 2025 at 5:43 PM
    Rocko
    Rocko New Member
    Virginia Beach
    96' Limited, 21' SR5P
    Where you located? If you're still looking I have my set of OEM Trail Running boards that came with my 21 SR5P. They have been collecting dust but still in great condition.
  13. Feb 22, 2025 at 6:34 AM
  14. Feb 22, 2025 at 1:43 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Welcome from SoCal
  15. Feb 22, 2025 at 1:44 PM
