rear wiper not working...
Discussion in '4th Gen 4Runners (2003-2009)' started by Toyota2008, Nov 23, 2022.
  1. Nov 23, 2022 at 6:52 PM
    Toyota2008
    Toyota2008 [OP] New Member
    I noticed my rear Wiper, rear window heater strips, and Rear wiper fluid sprayer aren't working -
    I recently replaced my battery-is there something special I need to do to reset these gadgets?
  2. Nov 24, 2022 at 7:46 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    Double check to make sure your rear window is up all the way. I did that once and it took a minute to realize I did that because it was only down a quarter inch and wasn’t easily visible.
  3. Nov 24, 2022 at 10:21 AM
    Hank69
    Hank69 New Member
    Hank
    2002 Blurple 4runner
    Until I got my forerunner, I never owned a vehicle with a rear wiper.
    And, I don't ever see a situation where I would ever use it.
    But then, I live in california.
    Maybe it works for snow?
  4. Nov 25, 2022 at 3:39 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Yes read your owner's manual, but basically you need to reinitialize your windows any time you disconnect the battery or your battery dies, you have to do this with your driver's door window, your hatch window and sun roof if you have one, basically you roll down the window and then roll it back up and hold the switch in the up position for a few seconds, do this for all I mentioned above and it all should be working correctly again, but as stated read your owner's manual as I might have the "how-to" described slightly wrong or maybe I remembered it correctly, I never know for sure since I have CRS!(Can't Remember Shit)
    spencermarkd likes this.
  5. Nov 30, 2022 at 7:03 PM
    Toyota2008
    Thank you so much. I did lower the window a bit and raised it back and now everything is working-who knew?
    AuSeeker likes this.
  6. Feb 11, 2023 at 5:05 AM
    Stoneboat
    Stoneboat New Member
    East Central Minnesota
    2007 SR5 4Runner
    None
    Same here my rear window must've dropped bit.
