Rear Window Stuck in Down Position
Discussion in '4th Gen 4Runners (2003-2009)' started by jcarder63, Feb 2, 2018.
  1. Feb 2, 2018 at 5:14 AM
    jcarder63
    jcarder63 [OP] New Member
    2005 Silver 4WD SR5 V8
    I’ve heard this is common and assure you that the following has been done with no success:
    • Window lock off
    • Rear wiper seated correctl
    • Fuses checked
    • Toyota Dealership tried new motor and Rear ECU with no success
    Any thoughts would be appreciated.
  2. Feb 2, 2018 at 9:02 AM
    Bob
    Bob Member Staff Member
    Bob
    First thing I was gonna suggest.
    Sub'd for any solutions (or updates from OP)
  3. Feb 2, 2018 at 9:15 AM
    jcarder63
    Everything listed in my original post had been tried. I’m at a loss outside of going to another Toyota dealership. Thanks for the input however.
  4. Feb 12, 2018 at 12:51 PM
    jcarder63
    Update: After two weeks, a new ECU, and window motor replacement without success, on a fluke the dealership decided to check the rear door lock cylinder and found a loose wire that was shorting out the back door.
    4runningMan, Bob and jester243 like this.
  5. Feb 12, 2018 at 8:14 PM
    Bob
    Bob
    :facepalm: Glad you guys finally solved it
    jcarder63[QUOTED][OP] likes this.
