Rear window regulator wheel
Discussion in '1st Gen 4Runners (1984-1989)' started by JoCool, Oct 3, 2020.
  1. Oct 3, 2020 at 8:13 PM
    JoCool
    JoCool [OP] New Member
    '87 1st gen manual trans hard top
    Brought her home, happy Canada Day to me!!
    So I wired in the rear window regulator, it works great but when I went to add the glass I realized that one of the wheels was missing. I'm trying to find a new wheel that I could easily replace it with. So here is hoping someone else knows which ones fit... Or has figured out a fix of some sort??
  2. Oct 13, 2020 at 6:57 AM
    se7enine
    se7enine New Member
    1984 4Runner
    3RZ
    I cut a couple of those wheels off of a 2nd gen and gave them to a fellow out in BC to fix the same issue. Not quite sure how he did it, maybe with just a nut and bolt.
  3. Oct 13, 2020 at 8:31 AM
    JoCool
    Ya. We tried stealing they piece off of the spare part regulator that came with the vehicle and could get it off safely, so I ended up going to a window and screen door shop, grabbed a roller that was the right circumference to fit, just the length was off. I sanded it down until it was the same dimensions as the other roller, and then went to hardware store and got a chicago screw to attach it to the hole after I cut off the rusted piece. I was definitely excited when I finally got it installed
    Toyotaguy and se7enine like this.
