Rear window button stopped working
Discussion in '4th Gen 4Runners (2003-2009)' started by Dendad, Mar 14, 2022.
  1. Mar 14, 2022 at 7:31 AM
    Dendad
    Dendad [OP] New Member
    Bill
    2005 4Runner
    i did a thorough search here, but couldn’t find a solution. I have a 2005 4Runner. The button on my dash that controls the rear window just stopped working. The window works fine with my key fob remote and it works when I roll the window up using my key in the tailgate lock, but the dash button won’t work. Any help would be appreciated.
  2. Mar 14, 2022 at 7:33 AM
    Doubleduty
    3rd gen ltd and 5th gen SR5
    Maybe a fuse?
  3. Mar 14, 2022 at 8:56 AM
    Dendad
    Bill
    2005 4Runner
    Thank you so much. Now, all I have to do is figure out how to find the fuse. I love my 4Runner. 17 years old and never had to replace a fuse. Thanks again.
  4. Mar 14, 2022 at 9:30 AM
    jiveydude
    jiveydude New Member
    Micah
    OH
    06 SR5
    This happened to me after I disconnected the battery for a while. My fix was to hold the button in the up position for 10 seconds.
  5. Mar 14, 2022 at 9:39 AM
    Just remember, fuses don't just up and blow for no reason. If it is a fuse, don't be surprised it blows again at some point.
    Rear hatches, if used a lot, get breaks in the wiring harness that can cause shorts or non-working buttons.
    I really REALLY doubt it's a fuse. A blown fuse is going to disable the entire circuit and the window won't work no matter what you try. Anything else on that circuit won't work either.
    Depending on where that button goes, and what controls the window from that button, it could be a few things. Could be the button, a relay between the button and the window, and all the wiring.
    I would first figure that the button has gone bad. Then from there if the button connects through the harness at the back of the car, I would test where the wires go from the body to the tail gate.
  6. Mar 14, 2022 at 9:41 AM
    Interesting fix. That tells me the button may go through the computer and needed relearning?
  7. Mar 14, 2022 at 9:54 AM
    Dendad
    Bill
    2005 4Runner
    Thanks everyone. I’ll try jiveydude’s suggestion and if it doesn’t work, I’ll go to a mechanic. I am famous for breaking things when I get out my screwdriver and pliers.
  8. Mar 14, 2022 at 12:11 PM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    Its a 17yo switch. KISS. Keep It Simple Stupid. The most logical explaination is usually the correct one. Pull the rocker switch and check the connection.
  9. Mar 14, 2022 at 4:41 PM
    Dendad
    Bill
    2005 4Runner
    Are you a jerk full time, or just on this forum?
  10. Mar 14, 2022 at 9:56 PM
    KISS is a common acronym\phrase. He wasn't really calling you stupid. It might seem that way if you've never heard of KISS.
    Overland WT and A&P like this.
  11. Mar 15, 2022 at 6:03 PM
    Overland WT
    Bryan
    West Texas
    2017 TRD Off Road
    Again, showing your age. Its an old military adage. Did you check your switch?
  12. Mar 15, 2022 at 7:43 PM
    Doubleduty
    Check the FUSE!...there is a circuit between the front switch and the rear one. Just because it works from the rear, does not mean it's not a fuse.
    A&P likes this.
  13. Mar 15, 2022 at 9:43 PM
    Dendad
    Bill
    2005 4Runner
    So, full time. I thought so.
  14. Mar 15, 2022 at 9:43 PM
    Dendad
    Bill
    2005 4Runner
    Thank you. I will.
  15. Mar 16, 2022 at 6:00 AM
    Overland WT
    Bryan
    West Texas
    2017 TRD Off Road
    Thin skinned kids. Your parents must be proud.
    A&P likes this.
  16. Mar 16, 2022 at 6:04 AM
    Dendad
    Bill
    2005 4Runner
    That’s okay. I’m going to delete my account here. I came on here for help, not to be bullied by an old, grumpy, know-it-all, Internet troll.
  17. Mar 16, 2022 at 6:11 AM
    Overland WT
    Bryan
    West Texas
    2017 TRD Off Road
    I offered help, used a common term used for generations to help explain your situation. You got butt hurt becasue it was a term you had never heard of before. Fair enough. I and others explained it and the hurt continued. I am a complicated guy, but as others pointed out, there was nothing wrong with what I said.
    And I was close. It is a engineering term in regards to the engineering development of the SR-71 Blackbird project. The most badass plane ever developed.
    https://www.interaction-design.org/...imple,amongst many other notable achievements).
    A&P likes this.
  18. Mar 16, 2022 at 9:56 PM
    Sure, always worth a check, but it would be odd if a fuse works like that.
    When a fuse blows, NOTHING works on that circuit anymore. I don't see how, in this case, that it's a fuse unless that button is on a separate circuit from the motor. And if a fuse is blown, usually, many things are not working. Only other thing would be an in-line fuse for only that switch, and that would be nutty.
  19. Mar 16, 2022 at 10:17 PM
    Wow.
    I once put this:
    :worthless:
    on a new member's thread on a Jeep forum and he got so insulted that I called his thread worthless, he reacted like @^^^, then disappeared, and never came back...:sadviolin:
    A&P likes this.
