Rear wheel wells…anything missing?
Discussion in '5th Gen 4Runners (2010-2024)' started by Tmiesowicz, Aug 2, 2022.
  1. Aug 2, 2022 at 8:51 AM
    Tmiesowicz
    Tmiesowicz [OP] New Member
    The better half of New York
    Just noticed the difference in both wheel wells on my 2022…wondering if this is normal or if they forgot a liner on my vehicle. Thanks y’all!
    Driver side
    Passenger side
  2. Aug 2, 2022 at 8:52 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    Yes, not enough mud. You're not using it correctly
  3. Aug 2, 2022 at 8:55 AM
    ESCT4R
    ESCT4R New Member
    2022 TRD ORP
    Don't know if they come like that, but my '22 is the same. Maybe someone can elaborate why they did this? lol
    Tmiesowicz[OP] likes this.
  4. Aug 2, 2022 at 9:01 AM
    Tmiesowicz
    If your 2022 is the same makes me feel better for now at least, just asked my mom to send me pictures of her 2019…Covid costs man Covid costs.
    ESCT4R[QUOTED] likes this.
  5. Aug 2, 2022 at 9:07 AM
    SCMountaineer
    SCMountaineer New Member
    Upstate South Carolina
    On my fourth 5th gen-- white 2024 TRD Off Road Premium
    None yet
    I noticed the same thing on my 21 this weekend!
    Tmiesowicz[OP] and ESCT4R like this.
  6. Aug 2, 2022 at 9:27 AM
    Tmiesowicz
    My mothers 2019 is the same as well
  7. Aug 2, 2022 at 9:30 AM
    2016SR5P
    2016SR5P New Member
    Massachusetts
    2016 SR5P
    2016 SR5P mine looks the same
  8. Aug 2, 2022 at 12:35 PM
    Most likely extra protection on the driver side due to the fuel filler neck being right behind that wheel well.
  9. Aug 2, 2022 at 2:22 PM
    beedee
    beedee Member
    That is the source of the Driver's Side Lean.
    Piney and glwood54 like this.
  10. Aug 2, 2022 at 2:39 PM
    Tmiesowicz
    That’s a Chevy thing lol…
  11. Aug 2, 2022 at 10:47 PM
    The pocket on the passenger side is there to catch sufficient quantities of mud to even out the drivers side lean. It’s on purpose.
    Trail Runnah likes this.
  12. Aug 3, 2022 at 2:18 PM
    Tmiesowicz
    Now onto the front…I don’t get it
    Passenger
    Driver
  13. Aug 3, 2022 at 3:58 PM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    Ya’ll worry about the weirdest stuff. Lol.
    The front passenger may have something to do with the air box being located on that side.
  14. Aug 3, 2022 at 4:05 PM
    Tmiesowicz
    Hey it’s just things out of the ordinary being noticed lol new to the 4 runner / Toyota thing
    7385 likes this.
  15. Aug 3, 2022 at 8:26 PM
    ecoterragaia
    ecoterragaia New Member
    Central Virginia
    2021 SR5 4WD
    My very first thought as well.
    As for the OP, I'm going to guess it's an access door for the fuel tank filler port. Gotta be able to disconnect the fuel port from the body of the truck if you're dropping the tank.
    7385 likes this.
  16. Mar 23, 2024 at 9:06 AM
    4RunnerNC
    4RunnerNC New Member
    Joe
    2019 Limited - Nightshade Edition
    I have a 2019 4Runner Limited. Has the same wheel well panel on the rear driver side. I have noticed a flapping noise for many months and could not figure it out until I had my wife drive and I sat in the back. After opening the Jack panel door I could hear the noise clearly. As it turns out, when in motion and especially on the interstate, this rear driver side wheel well panel has a little play in it causing it to flap against the well body making the noise. I just cleaned the area and there is no obvious way to tighten this up. My temporary fix will be to line the upper edge of the panel with some Exterior Silicone Sealant. Hopefully, that will stop the flapping noise on the 4Runner.
    ZippoMan and djwantke like this.
  17. Mar 25, 2024 at 11:59 AM
    grizzlypath
    grizzlypath New Member
    2020 ORP-KDSS
    Side note, I HATE that stupid little mud/rock pocket right there. I've been considering 3D printing a filler piece or something to keep debris out of it. It always just fills with crap.
    Stoney Ranger and djwantke like this.
  18. Mar 25, 2024 at 12:50 PM
    crashdb
    crashdb How Did I Get Here?
    Dave
    Manassas, VA
    2022 TRD-OR-P
    Little Tree Air Freshener
  19. Mar 25, 2024 at 6:09 PM
    4RunnerNC
    Joe
    UPDATE - filled upper area of the panel in the wheel well with Alex 230 clear and the noise is gone. FINALLY!
  20. Mar 25, 2024 at 6:36 PM
    MKIVBB
    MKIVBB New Member
    2017 Super White 4Runner 4x4 SR5
    Volk TE37 Bronze Replicas, TrailFinder A/T Tires, Custom AV System, Etc
    Mine looks the same.
  21. Mar 25, 2024 at 6:44 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I did a Canadian redneck mud flap delete, literally cut the factory flap off with. Milwaukee Sawzall.
    Then the true genius, filled that rear mudflap gap/hole with black expanding foam, never looked back
    I'll have to listen for this drivers side noise tho
  22. Mar 25, 2024 at 6:45 PM
    This^
  23. Mar 27, 2024 at 5:36 AM
    Gracio
    Gracio New Member
    Blayne
    Cloverdale, CA
    I wanted to see what mine looked like compared to OP’s, found this at forward end of drivers side rear wheel well. At first I thought ‘Holy Moly’ they covered up some kind of Japanese bug, passenger side has the same thing. Anyone know what this is?
  24. Sep 4, 2025 at 8:37 PM
    ZippoMan
    ZippoMan New Member
    None stock 2011 4Runner Limited
    Our family has a 2011 4Runner Limited with that exact same issue. That plastic flap/guard is super loose and makes the most annoying squeaking and rattling noise at highway speeds. I wonder if it just needs new push pins or how the heck do you even get it off to see what is behind it?
    I am brand new to this community and glad to find information. I will be looking for solutions to a few other rattly noises that need attention but for now this is one of the most annoying ones. Especially for people who sit in the back seats.
    Anyways it is September 2025!! Wow our 4Runner is almost 15 years old and still a beauty! I will have to share some pics in the appropriate section.
    Have a good one!
    https://youtube.com/shorts/HBbD9i80zkA?si=tjKXphQ2cwkKfO5f
  25. Sep 4, 2025 at 9:08 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro, 2023 Tundra Platinum Hybrid
    Of all the automotive forums I'm on, across multiple makes and models, this forum is the only one that has so many questions about wheel wells.
    whippersnapper02 likes this.
  26. Sep 4, 2025 at 9:21 PM
    ZippoMan
    ZippoMan New Member
    Is that a problem? or just observation?!
  27. Sep 4, 2025 at 9:34 PM
    Many folks bought the 4Runner after drinking the kool-aid on Japanese quality, same plant as Lexus, etc. In the process they became hypochondriacs. Every little sound and vibration brings them anxiety.
  28. Sep 5, 2025 at 12:20 AM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    Problems are things like a dog running off or bills not getting paid. Problems are not comments about wheel wells on the internet.
    That makes a lot of sense haha. Coming up on a decade of ownership, I'm just thankful mine goes from A to B without any drama.
    alittleoff likes this.
  29. Sep 6, 2025 at 2:01 PM
    ZippoMan
    ZippoMan New Member
    It's just annoying and now I know why and how to make it better. Isn't that what this community is for? Sharing knowledge and helping other 4Runner owners no matter what the issues are?!
    You just make me laugh!! Thanks for being a wiseguy!!
  30. Sep 6, 2025 at 2:08 PM
    2019 TRDP w/Kangs brah!
    They can’t just drive their Runner. Oh no the shifter vibrates! Oh no there obviously molded holes in a panel! Oh no the engine makes noise when running! Oh no the tires spin when I drive! Oh no my gas disappears when I drive!
