Rear Sway bar or stiffer springs, 2019 Limited
Discussion in '5th Gen 4Runners (2010-2024)' started by Steve40th, Nov 5, 2025.
  1. Nov 5, 2025 at 3:26 PM
    Steve40th
    Steve40th [OP] New Member
    sTEVE
    Long story short, Limited that I use for work and travel. When I work, and drive a few states away, I will have about 300-400 pounds of extra weight in the rear.
    It doesnt go down much, but I notice it drives a little different under windy conditions.
    So, should I invest in new springs or a sway bar? The OEM sway bar is 21mm, probably hollow. Front is 31mm hollow..
    Other than that, crappy Sailun tires and factory XRAES system..
  2. Nov 5, 2025 at 3:53 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    stiffer springs for sure. Stiffer sway bars don't help with the sag and not much with the weight induced sway in windy conditions. In fact with stiffer springs you can run lighter or even no sway bars to avoid the rear being too sideways happy when unloaded.
    Steve40th[OP] likes this.
  3. Nov 6, 2025 at 5:52 AM
    Neither sway bar, front or rear, on a 4Runner is hollow.
  4. Nov 6, 2025 at 5:56 AM
    Steve40th
    sTEVE
    Okay. Did not know that. So many threads, so many answers.
    Hellwig and Addco make aftermarket. I imagine they are solid metal.
  5. Nov 6, 2025 at 12:53 PM
    hossler1788
    hossler1788 DADWAGON
    Joshua
    Central Pa
    2020 4runner
    Most heavier aftermarket springs will also raise/lift the rear. Look up rear airlift air bags. Its a extremely simply install and helps with added weight.
    Or your could delete ur xreas suspension system
  6. Nov 7, 2025 at 4:22 AM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    The Limited has the 2nd largest swaybar of the different models I believe. I used Energy suspension bushings w/greasable brackets. I have been learning about adjustable swaybar links. You can change your handling characteristics extending links and preloading the swaybars slightly, but it will change the ride. I put my tire on the white or yellow line on the interstate and it drives itself. You might check your alignment. Positive caster controls high speed stability. It's supposed to be set at +3.5° +/- 0.5° . When Xreas goes out, replace with $500 worth of Bilsteins andnew springs. Everything will be better. Bare in mind, it is a rolling refrigerator on a windy day. There's a paving seam under the lines, out of the traveled way too. Easier on a windy day for hand/eye coordination. I converted the metric to standard and ordered universal bushings from Energy. It's cheaper than their Toyota specific part number. I'm jacked on 33s and I don't get pushed around to much. The AWD on the Limited is awesome and you have full-time front and rear limited slip and traction control at all speeds in H4H. Hold the Trac/skid button for 4 seconds to turn off the system. You definitely want to off in snow and ice so it acts like a regular 4wd. The rear brake pads wear out faster than the front about +2/1. I now think it's because of the limited slip system run by the Trac/ABS computer through calipers. Anyhow, that's what I am learning.
  7. Nov 7, 2025 at 6:12 AM
    Steve40th
    sTEVE
    Thnx for all that. When I get ready to change the xraes, I will have a plan of attach. Definitley springs and shocks.
    Sway bar greasables are nice. Simple system that keeps the noise down.
    Shutting off traction control helps the AWD system work better? Even with ATRAC?
  8. Nov 7, 2025 at 9:02 AM
    Oscar
    Oscar New Member
    2022 Lime Rush TRD Pro
    First the 4runner has 4WD and that is not the same as AWD.
    https://www.edmunds.com/car-buying/awd-vs-4wd-whats-the-difference-and-which-to-choose.html
    https://www.kbb.com/car-advice/awd-vs-4wd/
    If you turn off the traction control, normally you WANT the wheels to spin (maybe to clear the mud out of the tires, maybe to generate heat in the tires with spin, maybe you need the wheel spin to maneuver.
    ATRAC is used for LOW speeds; for controlled climbing over loose or rutted terrain where a wheel might leave the ground. ATRAC is a mode / type of traction control.
    https://www.youtube.com/watch?v=4uM-BiJPl2I
    https://www.youtube.com/watch?v=DQ4XdXy4XgE
    ATRAC comes on/off - stopping the wheel that is spinning and sending the power to the wheel that is not.
    For the sake of thoroughness for rear sway bars, I copied the info out of the knowledge sharing document
    Different Sway Bar discussion
    https://www.4runners.com/threads/sway-bar-options.45979/#post-751841
    Limited/TRD Sport/Nightshade: 31mm bar.
    https://www.4runners.com/threads/sw...htshade-want-to-get-under-their-runner.20982/
    https://trail4runner.com/2022/11/08/replace-sway-bar-bushings-for-5th-gen-4runner/#comment-24632
    SR5/TRD Off-Road: 30mm bar.
    48811-35460 sway bar 31mm
    48811-35450 sway bar 30mm
    48815-35130 sway bar mount bushing 31mm
    48815-35140 sway bar mount bushing 30mm
    Nolathane - 29mm Sway Bar Mount Bushing Set
    https://www.nolathane.com/products/rev004-0248-sway-bar-mount-bushing
    https://www.amazon.com/Nolathane-REV004-0248-Black-Bar-Mount-Bushing-Front-29Mm/dp/B06XY7Z35V
    RSO Suspension Sway Bars Kit Front and Rear Adjustable
    https://www.amazon.com/Suspension-Adjustable-2010-2023-4Runner-2010-2014/dp/B0BXKQNYTV
    Hellwig reart sway bar 7988
    https://www.hellwigproducts.com/products/?partnumber=7988&gQT=2
    Addco rear sway bar
    https://www.addco.net/product/toyota-4-runner-2003-19-rear/
    SuperPro Suspension front sway bar 30mm
    https://www.suspension.com/superpro/rc0127fz-30
    https://superprousa.com/collections/sway-bars/2015-toyota-4runner-trd-pro-esi6539566
    Energy Suspension 9.5165R 1-1/4" Greasable Sway Bar Set
    https://www.amazon.com/Energy-Suspension-9-5165R-SWAY-BUSHING/dp/B000CN7C1A
    https://www.4runners.com/threads/rear-sway-bar-or-stiffer-springs-2019-limited.47269/#post-782308
    Steve40th[QUOTED][OP] likes this.
