Rear Spacer or taller coil??
Discussion in 'Suspension' started by jason2006, Jul 17, 2020.
  1. Jul 17, 2020 at 6:14 AM
    jason2006
    jason2006 [OP] New Member
    I have bilstein 5100's all around with fronts set at 2.5 and a 1 inch rear spacer. I have about 1/2 inch of forward rake. would like a bit more forward rake so when i have the back loaded it doesn't sag and create reverse rake. I was thinking of a 1.5 inch rear spacer or would a taller coil be better? Figure i would have a load of 350 pounds or so once 2 adults and gear loaded in back. which would be better to accommodate this type of load?
  2. Jul 17, 2020 at 6:46 AM
    RSG sliders, Yakima Megawarrior basket, Black Rhino wheels, SOS Streamline bumper and skids, Warn VR EVO10S winch, OME MT64, Bilstein rear lift coils, Rigid Dually SS ditch lights, SR light bar, and Diode Dynamics SS3 fogs.
    Most guys would prefer to lift with springs. If it was a constant load, I would go with heavier springs. But, in your case, a taller spring should suffice.
    Another option to consider is a set of air bags. You can adjust firmness to the load you're carrying. Firestone makes some affordable setups.
  3. Jul 17, 2020 at 7:01 AM
    jason2006
    Bilstein seems to have 2 options for rear coils. Any difference between the two? Which one would be better? I wouldn't be carrying 300-400 lbs often
  4. Jul 17, 2020 at 8:10 AM
    I believe they have a 1" standard load lift coil, 1.5" standard load, and 1.5" heavy load coils. If you're on 1" spacers, you could switch to the 1.5" standard load coils and gain 1/2".
  5. Jul 17, 2020 at 8:14 AM
    jason2006
    With this set up and having 300-400lbs in back, would this sag or at most be level do you think.
  6. Jul 17, 2020 at 8:34 AM
    I couldn't say for sure. I went with heavy springs because I am always carrying extra weight. I have no idea how the regular load spring respond to being loaded down. I'm sure someone here might be able to answer that question.
  7. Jul 17, 2020 at 8:45 AM
    jason2006
    Thanks for your help. I guess I can always get the heavy springs
