Rear OEM Brake Part Numbers
Discussion in '5th Gen 4Runners (2010-2024)' started by TrueTexas, Jul 1, 2025 at 10:37 AM.
  1. Jul 1, 2025 at 10:37 AM
    TrueTexas
    TrueTexas [OP] New Member
    The Woodlands, TX
    Hey folks,
    I am about to order the parts to replace my rear brakes at 29k miles due to some grooving in the rear rotors (assume I picked up some sand or rocks that got caught between the pads and rotors on the rear).
    I used this thread to come up with the part numbers. Thanks for documenting it @Gripster
    https://www.4runners.com/threads/brake-replacement-parts-list-5th-gen.34536/
    Im planning to buy:
    • Rear Rotor: 42431-60311, Qty 2
    • Rear Brake Pads: 04466-60140
    • Rear Disc Brake Pad Shim Kit: 04946-60141
    • Rear Disc Brake Anti-Rattle Clip Set, Pad Support Plates: 04947-22050
    • Rear Rebuild Kit: 04479-60030 (just in case)
    My issue is with the rear brake pad clips. Multiple threads say that this is the right part number
    04947-22050. However, the Toyota website (autoparts.toyota.com) list it as for the front.
    Can anyone confirm that this is fact the right part for the rear brakes?
  2. Jul 1, 2025 at 10:53 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    For whatever reason, the description is confusing by them using the word Front when that part number is for the anti rattle clips for the rear pads. Someone correct me if I'm wrong. I looked at Toyotaparts deal and a couple others.
