Rear Locker Options?
Discussion in '5th Gen 4Runners (2010-2024)' started by ChrisHanson, Aug 5, 2025.
  1. Aug 5, 2025 at 10:39 PM
    ChrisHanson
    ChrisHanson [OP] New Member
    What are the options and challenges to adding a rear locker. I see Eaton has a product.
  2. Aug 6, 2025 at 1:06 AM
    2019 TRDP w/Kangs brah!
    There’s air, electronic and maybe lunchbox. I’d go electronic because air leaks and lunchbox (if available) is not selectable.
  3. Aug 6, 2025 at 8:04 AM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    I had the locker itch a few years ago. The Eaton e-locker seemed like the best option. There was a lot of brain bashing deciding if I really needed it. After wheeling ALF for a few years the ATRAC does everything I need. I never did get a locker. The vid below is from a Moab trip. Hells Gate. There are only 3 times that a locker would (may?) have been helpful.
    https://photos.google.com/photo/AF1QipM-SMtyoL1eN6Wngk-mJae_tFR8kee4TnF9G3Ic
    roooo and icebear like this.
  4. Aug 6, 2025 at 8:11 AM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Too bad Eaton doesn't have the Truetrac for the fifth gen. It's a fantastic limited slip.
    Toy4X4 and icebear like this.
  5. Aug 6, 2025 at 5:17 PM
    In increasing order of cost:
    Junk yard OEM e-locker third member wired to a switch on the dash with adapter harness: https://lowrangeoffroad.com/toyota-e-locker-wiring-harness-kit-low-pinion-rear.html
    Junk yard OEM e-locker third member actuated with push-pull cable replacing the locker motor: https://www.chilkatdesigns.com/product-page/toyota-8-e-locker-conversion
    ARB air locker
    Harrop e-locker
  6. Aug 8, 2025 at 12:30 AM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    Atrac is your lockers. That's why they don't offer them. They have limited slip rears. I haven't experienced any slip I can feel. I was looking at ECGS gear change. They offered lockers or limited slip. Limited slip is more dependable, works all the time. The old 4runners with lockers had a smaller ring and pinion than regular the regular 4runners. I watched the Atrac video on YouTube. I watched two calm older guys demonstrating calmly what's best to use in different terrain situations. Now I understand more what, why and when. I was going to get another limited slip installed if I was doing the stump swap with ECGS. Can't use locker or Atrac above 5 mph. Limited slip always working.
    5thToy and Toy4X4 like this.
  7. Aug 8, 2025 at 9:01 PM
    ChrisHanson
    So I'm leaning towards SR5/Limited. What is the largest ring gear that will fit the stock housing? Is there an issue will axel length? Is there a Toyota LSD?
  8. Aug 9, 2025 at 10:29 AM
    No rear LSD fitment for 5th gen 4Runners, period. (unfortunately - or at least, there is none that 4WP and the internet knows of)
    whippersnapper02 likes this.
  9. Aug 9, 2025 at 10:30 AM
    ^^^To add, Toyota uses the brakes to simulate a LSD. It’s cheaper for them.
  10. Aug 9, 2025 at 12:01 PM
    A-TRAC ≠ Lockers. My ORP has both A-TRAC and a locker. The main difference between a locker and A-TRAC is that the lockers are proactive, while A-TRAC is reactive. Don’t get me wrong. I’m not bashing A-TRAC, or any of the other ABS-based traction control systems. Downhill Assist Control/Crawl Control is amazing for descending the slippery slope, for example. But A-TRAC and lockers are different tools, and while some of their capabilities overlap, some of them don’t.
    ChessGuy and whippersnapper02 like this.
  11. Aug 9, 2025 at 1:51 PM
    What's this nonsense? You can leave the rear locker engaged up to the the top speed in 4low. A-Trac is useless in slippery terrain like sand, deep snow, and mud.
